Alaska Night Crawler - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Alaska Night Crawler
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 03-23-2014, 01:50 AM   #1
MPjeeper
2011 JK Wrangler
Thought it was about time that I start a build thread.
2011 JKU Rubi
44s 4:10 Locked
315/70R17 Goodyear Duratrac
4inch lift w/ RC adj control arms
with armor and light lol
11 JKU Rubi - http://www.jeepforum.com/forum/f22/alaska-night-crawler-2246225/
MPjeeper is offline   Reply With Quote Quick reply to this message
Unread 03-23-2014, 02:39 AM   #2
MPjeeper
2011 JK Wrangler
Ok..... enough with the cute pictures,time for the fun.
Unread 03-23-2014, 02:46 AM   #3
MPjeeper
2011 JK Wrangler
Pulling the HP44, in prep for .... drum roll...
Unread 03-23-2014, 03:13 AM   #4
MPjeeper
2011 JK Wrangler
Day 1, pulling that 44 and transport it over to my bros place for an axle party woot woot
received_m_mid_1395561799584_7dbd4ce8caf0d82736_0.jpeg   received_m_mid_1395561799584_7dbd4ce8caf0d82736_1.jpeg   received_m_mid_1395561799584_7dbd4ce8caf0d82736_2.jpeg   received_m_mid_1395561799584_7dbd4ce8caf0d82736_3.jpeg   received_m_mid_1395561799584_7dbd4ce8caf0d82736_4.jpeg
Unread 03-23-2014, 03:27 AM   #5
MPjeeper
2011 JK Wrangler
BAM! At my bros place, let the fun begin. Found her a nice front row seat. Than began to take some of her weak parts off with a cut off wheel. Followed up with mocking the truss. Before I begin grinding her down in prep for welding. While I was giving the axle a once around noticed my ball joints are done. So, did a road trip to the parts store. New ones all around.
received_m_mid_1395561845590_8a16e17a958dade814_0.jpeg   received_m_mid_1395561845590_8a16e17a958dade814_1.jpeg   received_m_mid_1395561845590_8a16e17a958dade814_4.jpeg   received_m_mid_1395561845590_8a16e17a958dade814_3.jpeg   received_m_mid_1395561845590_8a16e17a958dade814_5.jpeg
Unread 03-23-2014, 03:56 AM   #6
MPjeeper
2011 JK Wrangler
Going to leave this here, calling it a night. Plus uploading these from my kindle has been kinda annoying lol.. picture uploader just doesn't want to connect.
received_m_mid_1395561889408_aa8bc578518942d490_0.jpeg   received_m_mid_1395561889408_aa8bc578518942d490_4.jpeg   received_m_mid_1395561889408_aa8bc578518942d490_2.jpeg   received_m_mid_1395561889408_aa8bc578518942d490_1.jpeg   received_m_mid_1395561889408_aa8bc578518942d490_5.jpeg
Unread 03-24-2014, 02:43 AM   #7
MPjeeper
2011 JK Wrangler
Let the welding begin.. starting with truss. Then working to the trackback bracket, c- gusset, finishing with control arm brackets.
received_m_mid_1395645906185_e310e6c58423d5e720_0.jpeg   received_m_mid_1395645422770_19b6c39676de085630_3.jpeg   received_m_mid_1395645665788_e7bbf7043ab865e104_0.jpeg   received_m_mid_1395645980739_74efbc8dba6c57d083_0.jpeg   received_m_mid_1395645853356_e61f974214080c4908_0.jpeg
received_m_mid_1395645800655_6dadb5588f03637d01_0.jpeg   received_m_mid_1395646021545_b97713584044914f86_0.jpeg   received_m_mid_1395645942928_240f094386cb55c742_0.jpeg   received_m_mid_1395646142724_c416e0ffab2a903a78_0.jpeg
Unread 03-24-2014, 10:34 AM   #8
MrSundays
Looks good so far. Id like to do axles at some point while Im up there.
[URL="http://www.jeepforum.com/forum/f22/syd-tj-slower-than-molasses-2368441/#post22540729"]Syd the Sloth Build[/URL]
[B]F-22 Specialist[/B]
MrSundays is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 11:09 AM   #9
MPjeeper
2011 JK Wrangler
Like replacing your Dana 30 front and Dana 35 rear?... my recommendation find the axle you want in the lower 48, you will get a better deal. Have it shipped up with your household goods.
Which route do you plan going in the-- Rear Dana 44,10.25,8.8, 9inch, Dana 60 or 1ton, 14bolt
--Front HP30,HP44, Dana 60 etc
Unread 03-24-2014, 12:40 PM   #10
MPjeeper
2011 JK Wrangler
Welded up the other side.. Giving it time to cool, then will start tackleing the trackbar bracket.
Unread 03-24-2014, 05:59 PM   #11
MPjeeper
2011 JK Wrangler
Welding the trackback bracket that thing is beefy
received_m_mid_1395701742547_ea9d69111ff612c860_5.jpeg   received_m_mid_1395701742547_ea9d69111ff612c860_4.jpeg   received_m_mid_1395701742547_ea9d69111ff612c860_3.jpeg   received_m_mid_1395701742547_ea9d69111ff612c860_2.jpeg   received_m_mid_1395701742547_ea9d69111ff612c860_1.jpeg
Unread 03-24-2014, 06:22 PM   #12
MPjeeper
2011 JK Wrangler
Welding the c-gussets ..... so far everything going smoothly.. heat the gusset with a torch and clamped them down to get a better fit. Yes, I am replacing the ball joints
received_m_mid_1395701692190_91082bb5d3ae2e0371_1.jpeg   received_m_mid_1395701692190_91082bb5d3ae2e0371_0.jpeg
Unread 03-24-2014, 11:05 PM   #13
MrSundays
Originally Posted by MPjeeper
Like replacing your Dana 30 front and Dana 35 rear?... my recommendation find the axle you want in the lower 48, you will get a better deal. Have it shipped up with your household goods. Which route do you plan going in the-- Rear Dana 44,10.25,8.8, 9inch, Dana 60 or 1ton, 14bolt --Front HP30,HP44, Dana 60 etc
Depends on what I can get my hands on. Maybe HPd44 front and 8.8 or 60 rear
Sent from my pocket brick
Unread 03-25-2014, 09:09 PM   #14
MPjeeper
2011 JK Wrangler
Happy Hunting.. when it comes to 8.8... Look for the ones with dics brakes.
Unread 03-25-2014, 09:56 PM   #15
MPjeeper
2011 JK Wrangler
Paint paint paint :d
