ajamison's backwoods comanche build - Page 9 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > ajamison's backwoods comanche build
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 02-10-2013, 04:23 PM   #121
ajamison
ajamison's Avatar
1991 MJ Comanche
if the 35s werent brand new it would be a good possibility
ajamison is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 08:43 AM   #122
Jeepenjimmy440
nice pic of the shop buddie Iron Stone Custom's is looking good
Jeepenjimmy440 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 04:04 PM   #123
ajamison
ajamison's Avatar
1991 MJ Comanche
I'm picking up a waggy Dana 44 this weekend to replace the Dana 30 that has the disconnect housing, even though it has a full piece chromoly shaft the housing is a weak link, rather than spend money on another Dana 30 I figured ill be just as well off or better off with a waggy 44
Sent from my Comanche using my iPhone
Unread 02-14-2013, 05:37 PM   #124
blackouttj
You thinking about letting those chromo shafts go? I have a buddy that might be interested
2001 Sahara, mildly built, sold
2006 impact orange Rubicon, totaled
2001 sport constantly changing
blackouttj is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 05:54 PM   #125
rusty762
rusty762's Avatar
Looking good, waiting to see the 35's and lift!
Rusty
If I had eight hours to chop down a tree, Id spend six sharpening my axe.- Abraham Lincoln
My Build
My Videos
My Work
Have you hugged a Firefighter today?
rusty762 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 06:07 PM   #126
Moose340
Love it! Makes me wanna buy a Comanche......
Non timebo mala
Check out my build
[url]http://www.jeepforum.com/forum/f22/project-mooseicon-1459432/[/url]
Moose340 is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 07:35 PM   #127
gspup
My buddy used a waggy 44 on his YJ with SOA.
What's your plans for steering?
gspup is offline   Reply With Quote Quick reply to this message
Unread 02-14-2013, 08:37 PM   #128
ajamison
ajamison's Avatar
1991 MJ Comanche
Eventfully I will, but this axle is gonna be a slow build, ill probably run the Dana 30 all of this season
Unread 02-14-2013, 08:39 PM   #129
ajamison
ajamison's Avatar
1991 MJ Comanche
Most likely Ruff Stuff Y link kit w/ GM 1 ton tre's, and I will obviously integrate my current hydro assist system
Unread 02-15-2013, 05:33 PM   #130
ajamison
ajamison's Avatar
1991 MJ Comanche
i had off work today, since we started working 4 10's.. so off to the garage i went, got sterners 5.9 zj buttoned up and out of the garage. then i brought down the comanche and put in the 6" coils, and i used the 12" travel bilstiens up front... then i tore into the rear, the spring over axle conversion went well but i still have to finish weld the spring perches, mock up shock mounts, and re-route the brake lines. i ended up going with a JKS bomerang shackle (stock height for an mj) and the 3" alcan spring pack, which it is apparent that i need to remove 2 or 3 springs from the pack, the rear sits 2.5" higher than the front making it 8.5"
it flexes so much better with the new shocks, now the drag link is my only limitation. in these pics the driverside shock has 4" of more down travel available, and the passenger side has 0" of up travel. i am going to need to work with the suspension, maybe rebuild the upper shock mounts, and install bump stops.
Unread 02-15-2013, 07:21 PM   #131
blackouttj
Hot d@mn that thing looks like a race truck man all jacked up in the rear n stuff hahaha
Unread 02-15-2013, 07:53 PM   #132
ajamison
ajamison's Avatar
1991 MJ Comanche
yeah i gotta fix that tomorrow lol. we gotta get to trails or rausch soon man, its been too long since ive been wheeling
Unread 02-15-2013, 08:08 PM   #133
blackouttj
Yea man me too. You got my number. Just give me a shout whenever you guys head out. Hey how much do junkyards up your way usually charge for d30 axle shafts? I got a couple buddies down here looking to get their hands on some spares but the yards down here charge$30-40 per shaft which i think is crap.
Unread 02-15-2013, 08:11 PM   #134
ajamison
ajamison's Avatar
1991 MJ Comanche
eichelburgers you pull it in stoverstown charges $20 each for shafts, i havent been there in about a year so idk if their prices changed or not
Unread 02-16-2013, 09:17 AM   #135
ajamison
ajamison's Avatar
1991 MJ Comanche
Pulled the smallest and 3rd leaf from the pack... Much better
