ajamison's 2005 TJ build on a budget - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > ajamison's 2005 TJ build on a budget
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 12-05-2009, 10:59 PM   #16
ajamison
ajamison's Avatar
1991 MJ Comanche
i finally got a chance to get out and do some offroading now that i got her lifted... heres some pics from the local trail...
at the trail head...
this is my buddy's jeep that we just lifted too
even though i know this trail like the back of my hand and have done it in the dark more than in day light, i can say the jeep had no problems with the new lift and tires, i even made it up the hill climb with no problems. we just had some snow here tonight and the new tires do a lot better than i expected
ajamison is offline   Reply With Quote Quick reply to this message
Unread 12-05-2009, 11:36 PM   #17
MisterO
jeep looks real great, looks real good flexin on the trail
MisterO is offline   Reply With Quote Quick reply to this message
Unread 12-06-2009, 08:35 PM   #18
ajamison
ajamison's Avatar
1991 MJ Comanche
thanks a lot man, i didn't disco the sway bar yet.. im sure the flex will be much better when i do
Unread 12-06-2009, 09:17 PM   #19
MisterO
ya like a real nice amount!! go for it.
Unread 12-17-2009, 05:20 PM   #20
ajamison
ajamison's Avatar
1991 MJ Comanche
today i had a chance to install the engine block heater i bought... i plan to do a write-up about it within the next few days
Unread 12-17-2009, 07:00 PM   #21
coolens98TJ
This jeep looks really good. And I am very interested in this engine block heater. Temperatures here can get real cold. And again the jeep looks great keep up the good work man!
1998 Wrangler|2.5L|Cragar soft 8's|Hella 500FF's|RC 2.5"|RC Disco's|BFG A/T's|RC Steering Stabillizer|Sony CDX|
[SIZE="4"]SUPPORT JF[/SIZE]
[url]http://www.jeepforum.com/forum/f6/support-jeepforum-equipment-drive-963790/[/url]
coolens98TJ is offline   Reply With Quote Quick reply to this message
Unread 12-18-2009, 05:01 PM   #22
ajamison
ajamison's Avatar
1991 MJ Comanche
instead of posting the block heater info here, i decided to make a new thread for it... here it is: Engine Block Heater Install
Unread 01-04-2010, 11:04 PM   #23
squigy123
Nice to see another PA jeep. We have the same plans for axles. I just need to locate a front axle.
squigy123 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2010, 10:47 AM   #24
ajamison
ajamison's Avatar
1991 MJ Comanche
i've been hoping to find an 8.8 with tj brackets ready to bolt in.. but the chances of that happening are slim.. i am probably going to just have to weld everything on myself
Unread 01-06-2010, 10:49 AM   #25
ajamison
ajamison's Avatar
1991 MJ Comanche
i got a chance to go wheeling last weekend.. i disco'ed and was impressed with the short arm articulation...
Unread 01-07-2010, 09:51 PM   #26
ajamison
ajamison's Avatar
1991 MJ Comanche
today i got around to installing a BDS adjustable track bar and steering stabilizer. on another note, for the past few days i noticed that my jeep hasn't been sitting level (driver side higher than pass. side). when i was doing the track bar and ss today i realized that my driver side coil spring clip was gone and the spring had un-seated. most likely happened in the picture above in my last post. im going back there this weekend, i'll do it again and hop out and make sure the spring goes back to where it should.
heres a pic of the ss and track bar:
Unread 01-14-2010, 03:56 PM   #27
ajamison
ajamison's Avatar
1991 MJ Comanche
Score!
i scored a ford 8.8 today for 100 bucks. 3.73 gears, lsd, and disk brakes
i plan to have it under my jeep by the end of the semester. will be matching it up with a D30hp with 3.73s from an xj. and will eventually throw in some 4.88 gears when the money tree starts growing again. more pics to come...
Unread 01-14-2010, 05:22 PM   #28
Martinsc
Sweet deal man.
Martinsc is offline   Reply With Quote Quick reply to this message
Unread 01-14-2010, 05:41 PM   #29
Imped
Imped's Avatar
Looks good. I'm gonna go out on a limb and say gears are next on your list.
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread 01-14-2010, 09:06 PM   #30
ajamison
ajamison's Avatar
1991 MJ Comanche
well, close... like i said im gonna grab a high pinion dana 30 with 3.73 to match for now, but after that 4.88 gears will be the next thing
