99tjsahara's Build - Page 6 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 99tjsahara's Build
Unread 12-10-2009, 09:19 PM   #76
TreeFrog1
Originally Posted by 99TJSahara View Post
Its the cv joint going bad, it sounds like angry birds,
I was going to ask the same question. I "think" I started to get that same sound today. It was really weird, it's like every time you get closer to where you need to shift gears, it started making a strange, high-pitched sound (like a cricket that never breathed -- it just kept one giant, continuous chirp).
What causes that? By chance would the weather have any play in that? (I know I'm not far from you and we are both experiencing same crazy cold temperatures right now.) I mean, the weather didn't cause it but could it have aggravated the problem? I didn't have that sound in the morning, but by mid-day and for the rest of the day, I kept getting that high-pitched (almost painful) noise.
TreeFrog1 is offline   Reply With Quote Quick reply to this message
Unread 12-10-2009, 10:25 PM   #77
TreeFrog1
How easy is it to overhaul the DC(cv) joint on the front driveshaft, anything I should look out for tomorrow when I do it?
I'm guessing you've seen this already:
TJ Front Driveshaft Overhaul - http://www.stu-offroad.com/axle/driv...iveshaft-1.htm
and this:
TJ Front Drive Shaft CV Assembly Overhaul - http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
I think they answered some of the questions in my previous post.
Unread 12-11-2009, 06:17 AM   #78
99TJSahara
TJ Front Driveshaft Overhaul - Front Drive Shaft Overhaul - 1
and this:
TJ Front Drive Shaft CV Assembly Overhaul - TJ Front Drive Shaft CV Maintenance
Yea, I've read those a bunch of times, it seems to be a straight forward job, I have to go pick up the new u-joints and ball centering kit after school today.
-Joey
99 Wrangler Sport
04 Grand Cherokee Overland
99 Wrangler Sahara-sold
99TJSahara is online now   Reply With Quote Quick reply to this message
Unread 12-11-2009, 10:50 PM   #79
99TJSahara
I did the CV overhaul tonight, It took about 2.5-3 hours, it was really easy, but I did smash my thumb real good with the hammer, I probably could have had it done in 1.5, but I was working with 1 thumb.
-Joey
99 Wrangler Sport
Unread 12-12-2009, 09:00 AM   #80
99TJSahara
Just put the front driveshaft back on, no more sparrows.
-Joey
99 Wrangler Sport
Unread 12-13-2009, 02:02 PM   #81
99TJSahara
What a good time to try out 4lo
-Joey
99 Wrangler Sport
Unread 12-13-2009, 02:32 PM   #82
MisterO
^^ Sweet Picture, btw what top is that? def not stock....
MisterO is offline   Reply With Quote Quick reply to this message
Unread 12-13-2009, 02:33 PM   #83
99TJSahara
Bulldawg.....
-Joey
99 Wrangler Sport
Unread 12-14-2009, 08:56 PM   #84
99TJSahara
I got tired of sitting on my worn out front seat( I sat on the frame), So I ordered this.
Baja SS Fixed-Back Seat by Corbeau and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware
Has anyone dealt with 4wd, I haven't gotten conformation yet, how long does it usually take?
-Joey
99 Wrangler Sport
Unread 12-14-2009, 10:40 PM   #85
MisterO
why did you get the Fixed one??
Unread 12-15-2009, 02:16 PM   #86
99TJSahara
I'm switching my order to quadratec because 4WD can only ship in pairs, and I decided it would be cheaper to buy 2 now than 1 now and another later, Quadratec is cheaper for pairs. I got the all black vinyl.
http://www.quadratec.com/products/24226_X0X0_PG.htm
QTEC said 2-3 weeks, does this sound right?
-Joey
99 Wrangler Sport
Unread 12-16-2009, 10:58 AM   #87
TreeFrog1
CORBEAU Baja SS Suspension Seats - Quadratec
I realize you only want one (which shows $319.98 from Quadratec, + $44.99 for shipping = $364.97), but you may want to check out Offroad Overstock.
While they only ship a minimum of two, you can get both (including free shipping) for $358. It's like getting a free seat, plus a free lunch.
Hopefully, this link will take you directly to it:
Corbeau Baja SS Suspension Seat
Cancel Quadratec due to the delay you don't want to endure.
EDIT: Or, to keep your business, ask them to match Offroad Overstock.
Unread 12-16-2009, 12:29 PM   #88
MikeRi24
great looking Jeep! How do you like the RC lift? I am thinking about doing the same thing as you, but considering adding a spacer in the front to level it out. Did the 2.5" RC springs level it our or does it still have the rake?
Mike
2003 Jeep Wrangler X
My Build Thread:
http://www.jeepforum.com/forum/f22/my-2003-tj-685257/
"My Jeep helped win a war....You're Honda just mowed my lawn"
MikeRi24 is offline   Reply With Quote Quick reply to this message
Unread 12-16-2009, 12:53 PM   #89
99TJSahara
I like the RC lift, the springs did not level it out on mine, which I'm glad because I like a little bit of rake.
-Joey
99 Wrangler Sport
Unread 12-16-2009, 12:58 PM   #90
99TJSahara
Thanks, for site I will definitely be checking them out in the future, I called Qtec today to confirm my order and they said that it probably will take less than a week. It would still cost around $500 including the brackets.
-Joey
99 Wrangler Sport
