99TJSahara's Build 2.0, Here we go again - Page 4 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 99TJSahara's Build 2.0, Here we go again
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! The Original 3/8" Ruffstuff Diff Cover!
Unread 05-31-2013, 03:56 PM   #46
99TJSahara
Took advantage of Rokmens memorial day sale and bought some much needed upgrades, one came in this morning, I got it installed and did a quick alignment, I'll bring it to work next week for a real alignment.
image-3051140227.jpg   image-744592177.jpg   image-3575349768.jpg   image-1220160549.jpg   image-2050983895.jpg
-Joey
99 Wrangler Sport
04 Grand Cherokee Overland
99 Wrangler Sahara-sold
99TJSahara is offline   Reply With Quote Quick reply to this message
Unread 06-03-2013, 06:05 PM   #47
99TJSahara
Did an alignment after work today, toe was only .1-.2 degrees out so not bad for a quick tape measure alignment, now its dead on and drives almost perfect.
-Joey
99 Wrangler Sport
Unread 06-03-2013, 06:50 PM   #48
wranglerTX
looking great!, is that the currie steering? What do you think of it? feel any difference in the ride?
wranglerTX is offline   Reply With Quote Quick reply to this message
Unread 06-03-2013, 08:14 PM   #49
99TJSahara
Thanks and yup it's the currie steering, I think it's awesome, the quality is top notch, And I did notice the steering did tighten up a little bit after the install.
-Joey
99 Wrangler Sport
Unread 08-11-2013, 05:34 PM   #50
99TJSahara
Time for an update, so since I bought the jeep my rear axle has had excessive endplay in the axle shafts, so I finally decided to do something about it.
Here's the shafts that were in the jeep, they appear to be superior brand based on part #
Here's a stock shaft
The answer, alloy usa 30 spline
Removing old bearing/seal
New bearing
New seal
Studs installed
Shafts installed
-Joey
99 Wrangler Sport
Unread 12-14-2014, 05:10 PM   #51
99TJSahara
Wow been over a year since last update! Today I started doing some very overdue maintenance on the jeep, since I don't drive it during the winter I'm in no rush. Removed the old leaking, bent to the point it was rubbing on oil pan exhaust.
Removed the worn out and leaking tcase for a rebuild.
I will likely also replace the clutch, rms, front axle seals and a bunch of other stuff I'm forgetting.
-Joey
99 Wrangler Sport
Unread 03-17-2015, 06:44 PM   #52
99TJSahara
Work has been slow on the Jeep, I removed the oil pan to replace the RMS and pan gasket. I also found very worn out motor mounts. I got the tcase disassembled to inspect for worn hard parts, found a shift fork was worn past the pads and into the fork itself(shouldn't be a problem as I have an extra from my old tcase). I removed the trans to replace what I believed to be the original clutch(purchased from original owner who said he never replaced it, 150k+ on the odo) Looks like it may have been replaced, it is stamped Sachs and IIRC LUK made the factory clutches for 99MY TJ's, either way the TOB was on its way out and everything will be replaced Evidence of RMS leak So I have ordered: 1'' Brown Dog mounts, rubber Luk gold clutch kit RMS New oil pan Oil pan gaskets Tcase rebuild kit from AA
-Joey
99 Wrangler Sport
Unread 03-20-2015, 03:01 PM   #53
99TJSahara
Worked on rebuilding the tcase today, ended up having to order a new range fork as my extra was worn also, so I'll have to wait for that to show up.
-Joey
99 Wrangler Sport
