99 WJ build with 35', 4" lift, twin winches, tank lift etc - JeepForum.com
post #1 of 9 Old 10-02-2015, 03:16 AM Thread Starter
leighroy692000
Hey guys, first time posting anything build related but I'v learnt so much from this site so I thought I better give back.
Its nothing flash and always done with a budget but should do the job.
I'm building a 99 WJ 4.7 V8 for mostly off road only and will try update as I go through it. Any ideas would be greatly welcomed too.
Build list
4" rough country lift kit. Done
35" mud tyres. Done
Tow hooks front and rear. Done
Air intake Done
On board air using AC pump To do
Front behind bumper 9500 lbs electric winch. Currently doing
Rear 9500 lbs electric winch with own battery Currently doing
Spare tyre holder?
Bildge pumps. lol
ZJ Washer bottle install Done
Here's a few random pics I've taken so far.
20151002_152038.jpg[/ATTACH]
leighroy692000 is offline
post #2 of 9 Old 10-02-2015, 03:54 AM
paulhead
I overtighten stuff
paulhead's Avatar
I got a 99. You're giving me great ideas of what to do when I'm done with it as a daily driver.
paulhead is offline
post #3 of 9 Old 10-03-2015, 03:30 PM Thread Starter
leighroy692000
So I'm just trying to figure out how to isolate my rear mounted battery and connections to the winch away from the fuel tank? They are damm close but I realy want to keep the weight low and try utilise the space well too and bearing in mind I still have a 35" tyre to fit on top of it all. Once all mounted I will make a removable cover for over the winch and a seperate platform over that which will span the entire space where the tyre will be mounted down too anchored down with a rod from the plate the battery is sitting on. So I guess I'm just going to have to make a secure battery box out of aluminium with rubber lining and also make a couple of aluminium plates to try seal off the fuel tank from inside the truck best I can? The battery will be 100A fused as close the the positive terminal as possible. Any ideas from anyone?
Here are the latest pics
20151003_125236.jpg   20151003_125248.jpg   20151003_145656.jpg   20151003_125558.jpg   20151003_145706.jpg
post #4 of 9 Old 10-14-2015, 03:30 AM Thread Starter
leighroy692000
Latest pics of the rear winch and wiring etc. I've plated as much as I can to seperate the tank from the inside on the truck and have decided to mount the battery on the right and the air tank on the left. I plan on building a plywood platform that will house the winch and ropes etc while the spare wheel will mount on top of it.
Love to hear anyones feedback or ideas?
post #5 of 9 Old 10-14-2015, 09:36 PM
lovett86
Nice work your doing there, keep it up
its a rusty one
http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/
lovett86 is offline
post #6 of 9 Old 10-20-2015, 11:46 PM Thread Starter
leighroy692000
Managed to install the front winch and modify the bonnet catch.
Photos from today.
post #7 of 9 Old 11-05-2015, 03:08 AM Thread Starter
leighroy692000
Well its all ready for its first test run although I havent finished the onboard air system yet. I did have some road test run issues developing a misfire once its warmed up. I seemed to have narrowed it down to either the cam or crank sensors and seems to be fine now after replacing both. I hope to hit the trails in the next week or two. Here are the latest pics.
20151031_102811.jpg   20151031_102820.jpg   20151031_102841.jpg   20151031_102848.jpg
post #8 of 9 Old 11-05-2015, 08:51 AM
VARIABLE9
Dig it!
VARIABLE9 is offline
post #9 of 9 Old 11-05-2015, 08:53 AM
paulhead
I overtighten stuff
paulhead's Avatar
Beast
paulhead is offline
