99 Rusty Revival - Page 6 - JeepForum.com
post #76 of 147 Old 10-29-2012, 09:24 AM Thread Starter
sailsurf7713
Originally Posted by tjsean0308 View Post
whats your plan for the middle body mount? I need to fix that too. My frame is ok because of my insane cleaning but I missed the torque box.
Depends on how much the owner wants to spend. If he wants to go cheaper I'll bend up some 1/8" steel with a nut welded in and welded back in. If he wants it to look original, then these:
http://www.classicent.com/jeep.php
Mine is getting done the cheap way . I'll post up pictures as soon as possible. This stupid hurricane is putting a damper on progress.
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
My Rusty Revival
sailsurf7713 is offline
post #77 of 147 Old 10-29-2012, 10:48 AM
ben34mod
Great build!!...Subscribed...
ben34mod is offline
post #78 of 147 Old 10-29-2012, 11:19 AM Thread Starter
sailsurf7713
Picked up something that should help me finish up the lower plate on the crossmember
$80. I think I did alright?
My Rusty Revival
post #79 of 147 Old 10-29-2012, 11:20 AM Thread Starter
sailsurf7713
Thank you.
My Rusty Revival
post #80 of 147 Old 10-29-2012, 11:41 AM
G Beasley
That was a fair deal for a benchtop . When you start looking at hold down clamps do not buy the harbor fright one , it sucks . Try to find one at a weld or fabrication shop as a better one will stay clamped .
G Beasley is offline
post #81 of 147 Old 10-29-2012, 02:27 PM
tjsean0308
exactly, what i was looking for thanks!
tjsean0308 is offline
post #82 of 147 Old 10-30-2012, 12:07 PM Thread Starter
sailsurf7713
No problem. Let me know how it works out.
My Rusty Revival
post #83 of 147 Old 11-02-2012, 11:32 PM Thread Starter
sailsurf7713
Well. My buddy's unbelievably rusty jeep has been taking up my Jeep time, but I took a break from it and managed to get some little things done.
Got the Warn fogs wired up. The whole wireless control is a bit odd, but it saved me some time during installation. Gotta make it look up to my standards so no pictures of the wiring
Then moved to the back of the jeep to get the smashed tail lights removed and the license plate bracket deleted. All it took was a jig saw, a little liquid courage and some masking tape.
Big improvement in visibility over stock. Nice clean look and hopefully less likelihood of smashing them up on trees. Very happy with it.
My Rusty Revival
post #84 of 147 Old 11-19-2012, 12:46 AM Thread Starter
sailsurf7713
A build thread within a build thread
Continuing with the original "Rusty Revival" theme, here is some updates on the project I'm working on.
The victim:
1999 Sahara.
Tear down. This went quick, but revealed many more problems than ever originally imagined.
New junk. So far this rig is getting 2" BDS lift, new magnaflow/dynomax exhaust from header back, a repaired frame, 03-06 gas tank skid plate, and some other stuff later on.
Cutting out the cancer, this poor thing was probably a couple months from disrepair and a hair from a bad accident. It will be returned to its former glory though.
Frame side coil buckets fell off when I pulled the axle
Axle side buckets had mostly rusted off as well.
Making it safe again.
First bead ran. Eh. Not awful.
Mocking up the new Rusty's coil re-locators. Not bad, just had to re-make one of the retaining nuts because the nut was welding off center.
NEW...ish frame
Burned in
New front bumpstop extensions.
This side was simply bolted through.
This side we couldn't bolt through so drilled out the hole put a nut on top and created a void on the underside for it to clear.
Painted rear crossmember. Yeah bubblewrap to protect from over spray.
Wheels were oxidized so got away from cutting, welding and wrenching for a bit to bring them back to life.
More to come...
My Rusty Revival
post #85 of 147 Old 11-19-2012, 05:26 AM
responder
Nice work on both of the Jeeps! Keep the thread updated as we are watching.
I really like the design of your rear bumper. Can't wait to see it installed..........might need to copy that one!
responder is offline
post #86 of 147 Old 11-19-2012, 07:01 AM Thread Starter
sailsurf7713
Thank you. Many more updates on the way.
As for my jeep,
Picked up a new Antirock on ebay for 268 shipped. Crossmember will get finished and installed very soon.
My Rusty Revival
post #87 of 147 Old 11-19-2012, 10:46 AM
G Beasley
I am so thankful to have a clean frame . The repair looks good , probably stronger than it was from the factory .
post #88 of 147 Old 11-19-2012, 03:03 PM
Melissas6570
More to come...[/QUOTE]
Wow Great work. Im glad we dont have that down here. What prep did you do to the wheels, before painting?
I DO IT WITH MY TOP OFF!
Melissas6570 is offline
post #89 of 147 Old 11-19-2012, 05:21 PM Thread Starter
sailsurf7713
220 grit, wiped down a few times with simple green marine and painted with 4 coats.
My Rusty Revival
post #90 of 147 Old 11-21-2012, 02:07 PM Thread Starter
sailsurf7713
Some more progress on the Sahara. Front bump stop cup threads were rusted out so heres my solution:
What I'm talking about:
Taped a serrated 5/16" flange nut to a socket on an extension.
5/16" bolt and washer to secure bumpstop cup
Put together
Start threading nut onto bolt
Tighten adequately and finish install
Finished up the front suspension. Will need one more coat of touch up paint.
"Rust Proofed" the underside of the tub
State of the old axle side coil buckets
Axle now:
All ready for installation
Partially installed. Had to stop working.
Bumpstops will be cut down.
My Rusty Revival
frame repair , Frame rust , mce fenders , no lift , rear crossmember
Any rusty TJs out there? TJSunny1 Jeep Picture Requests 19 09-15-2011 09:58 PM
My rusty YJ Gets new life in it! ChromeWrangler Jeep Builds 6 10-23-2010 06:19 PM
Rusty Bottom bentleylacasse Jeep Picture Requests 6 05-19-2010 05:13 PM
Rusty before shots The_Blacksmith Jeep Picture Requests 9 10-29-2009 07:10 AM
Rusty Jeeps Edstu234 Jeep Picture Requests 10 08-06-2009 03:23 PM
