-   Jeep Builds (http://www.jeepforum.com/forum/f22/)
-   -   99 Flex-Jay (http://www.jeepforum.com/forum/f22/99-flex-jay-1263850/)
csouers 09-11-2011 08:48 PM
99 Flex-Jay
My beloved 92 was totaled in April of 2010. I moved on for a while, but got the bug to see what she could still do. After tinkering and playing with it since this past summer started (made a thread for that bit of time), I determined the body was toast. Nothing lined up and it was far too rusty to deal with. Yes, it could be fixed, but with the money I'd spend in steel, I figured I'd find a body and be done with it... that's exactly what happened.
The new rig's specs:
99 Sport
Blown 4.0 (overheated due to heater core pipe failure)
AW4
NP-231
D30/8.25 w/3.55s & open diffs
Lots and lots of missing parts.
The first stage specs to be:
Bolded = complete
Stock 4.0
AW4
NP-231 with SYE
Suspension
IRO 4.5" coils
IRO 3.5" leafs
Lift shackles
RC shackle relocation
Bilsteins with bar-pin eliminators
IRO double shear trackbar
4-link long arm front suspension
Bump stop according to tire+lift combo
Limiting straps
Axles
Coil sprung - Waggy 44 Front with ARB Locker, 4.88 gears, truss, and J10 flat top knuckles with hi-steer
Leaf sprung - 98+ Isuzu 44 Rear with Detroit locker and 4.88 gears
Table of Contents:
Initial Status and Engine Removal
Pre-engine install cleanup and initial fender trimming
Rockauto parts for engine transplant
Work prior to transplant of drivetrain
Drivetrain/784 neon injector install
Door molding adhesive removal (with eraser wheel)
csouers 09-11-2011 09:00 PM
Now with the goodies-
The taped up windows are due to a lack of any internals in the doors.
http://i474.photobucket.com/albums/r...J/DSC_0022.jpg
No...the PO did not mark the connectors. I spent an hour and a half with the FSM going through wire colors to figure everything out.
http://i474.photobucket.com/albums/r...J/IMG_0414.jpg
The valve cover, dshaft, and compressor are from the 99, the intake, tb and sensors are from a buddy of mine whose engine got swapped out.
http://i474.photobucket.com/albums/r...J/IMG_0417.jpg
Said no thank you to fender flares, so I ground the heads off the bolts and pulled the liner.
http://i474.photobucket.com/albums/r...J/DSC_0023.jpg
Ready for trimming.
http://i474.photobucket.com/albums/r...J/DSC_0024.jpg
Sallie approves. Look how happy she is!
http://i474.photobucket.com/albums/r...3_648100_o.jpg
Because I'm a boss, I pulled the drivetrains from both XJs in a 3 day span. It's surprising how easy it is to pull these things.
http://i474.photobucket.com/albums/r...J/IMG_0461.jpg
Got some goodies at the junkyard. The engine still needs misc gaskets, timing chain and cover set, motor mounts and an alternator. The body/interior needs window regulators, door panels, mirrors, switch panel, header panel with wiring harness, and a rear bumper. After that, she should be ready to drive.
http://i474.photobucket.com/albums/r...9XJ/photo1.jpg
I was bored one night and decided to candy the tail lights. Scuffed up...
http://i474.photobucket.com/albums/r...9XJ/photo2.jpg
Cleaned and masked off
http://i474.photobucket.com/albums/r...9XJ/photo3.jpg
3ish coats of color and 2ish coats of clear. Ran out of both when I redid the drivers-side light. Might need to pick up more and respray it.
http://i474.photobucket.com/albums/r...9XJ/photo4.jpg
Dad scored some 2x3 and 2x4 steel from work. Can you say new rocker panels? :)
http://i474.photobucket.com/albums/r...9XJ/photo5.jpg
csouers 09-11-2011 09:03 PM
Today, I cleaned the engine bay with Purple Power, trimmed and partially painted the front fender and cut and folded the rear fender. The lower quarter is next after I get some more paint and an orbital sander.
I'm guessing when the engine blew, it blew all kinds of oil and crap everywhere, hence the dirt.
http://i474.photobucket.com/albums/r...J/DSC_0025.jpg
http://i474.photobucket.com/albums/r...J/DSC_0028.jpg
After some time with the tire brush and a cloth. it's not perfect, but it's much much better.
http://i474.photobucket.com/albums/r...J/DSC_0035.jpg
http://i474.photobucket.com/albums/r...J/DSC_0039.jpg
Marked the top most body line as a guide to make sure that it matched the same line. My initial trim was rough, so I smoothed it out in relation to the top line. After it was smooth, I removed the marker lines and started to mask things off.
http://i474.photobucket.com/albums/r...J/DSC_0040.jpg
Under the white paint was SHINY red metallic. (Chili Pepper Red I believe) No sanding it seems. No wonder it flaked off so easily.
http://i474.photobucket.com/albums/r...J/DSC_0041.jpg
Trimmed and smoothed.
http://i474.photobucket.com/albums/r...J/DSC_0043.jpg
Masked and primed
http://i474.photobucket.com/albums/r...J/DSC_0045.jpg
Rear quarter with slits cut in between every 1 or so plug welds. Don't want to cut those as it gets rid of quarter rigidity.
http://i474.photobucket.com/albums/r...J/DSC_0047.jpg
Hammered over. This corner has been repaired so all the paint flaked off. I was going to pre-heat the paint, but said no to that as it'll get painted black anyways later on.
http://i474.photobucket.com/albums/r...J/DSC_0049.jpg
The best picture of this that I have so far. Once I get the whole Jeep done as far as trimming and paint, I'll whore it out. :)
http://i474.photobucket.com/albums/r...J/DSC_0052.jpg
1stblack97ZJ 09-11-2011 09:23 PM
sub'd :thumbsup:
csouers 03-01-2012 10:49 PM
After setting idle for 5 months, I FINALLY got going on the thing. All the parts from RockAuto have showed up. Install starts a week from Saturday (spring break). Hopefully everything will be in by at least the Wednesday after that. That's my goal anyways.
http://i474.photobucket.com/albums/r...J/DSC_0018.jpg
csouers 03-09-2012 11:42 PM
Day 1 of work began with a phone call from Mom telling me to take the dog to the groomers. Not how I expected to start my day. After dicking around with that for a couple of hours, I finally got going.
After doing miscellaneous stuff around the house, I got in the garage. So far, I've installed the injectors with new orings, throttle body with new gasket, and a couple trim pieces on the hatch. I also soldered the license plate light wiring together because the PO thought it'd be a good idea to cut it off (the guy's an idiot). Spent some time with the torch and ratchet getting the adjuster bolt out of the power steering/idler bracket. As usual, it wasn't moving very well and I was afraid it was going to break. All came out well and it should be good for the install.
Tomorrow, with the help of Dad, the plan is to get the timing set installed, exhaust manifold crack welded up as well as put in new downpipe flange bolts. If all that pans out, I can installed the new manifold gasket, install the accessory drive and bolt up the transmission.
http://i474.photobucket.com/albums/r...DSC_0047-1.jpg
csouers 03-10-2012 11:35 PM
Got some real work done today. Installed the new timing set, welded up the exhaust manifold, got the manifolds installed, got most of the accessory drive installed, and got the a/c compressor separated from the bracket. Will have to drill and tap that later.
The old timing set. The amount of slop in the chain was amazing.
http://i474.photobucket.com/albums/r...J/DSC_0053.jpg
This looks like a lot of wear to me. Could be normal but sure looks odd.
http://i474.photobucket.com/albums/r...J/DSC_0054.jpg
Here's the old cover. Notice the lack of a snubber or any place to mount it? Yeah. I reckon that the chain did that. Also, the nipple for the cam preload button is gone. We pulled the cover from the blown 99 engine, which was whole and had a snubber, cleaned it up and installed it.
http://i474.photobucket.com/albums/r...J/photo2-1.jpg
Dad cleaned up the head while I finished the timing set install.
http://i474.photobucket.com/albums/r...J/DSC_0055.jpg
Dad's attempt at welding. He's never had any instruction on any of this stuff, so this is how it turned out. I don't know much myself, so I could really offer any advice. Not to mention that's steel weld on stainless steel pipe... When it cracks badly enough again, I'll spend the cash on a new style manifold with flex joints.
http://i474.photobucket.com/albums/r...J/DSC_0057.jpg
The new hotness. Notice the lack of slop??
http://i474.photobucket.com/albums/r...J/DSC_0058.jpg
Here's most of the accessory drive bolted up. Test fitted my belt from the modded 92 setup and it's too long. Gotta order a goodyear 4060805 (80.5" long) belt tonight. The old is a 4060827 (82.75" long).
http://i474.photobucket.com/albums/r...J/DSC_0062.jpg
Video of the chain slop.
csouers 03-12-2012 08:45 AM
Got a bunch of stuff done yesterday. Got the engine mated with the transmission, transmission filter changed, put anti-seize on the tcase studs because all AW4 owners know how much of a ***** those can be, got the cb radio mounted up, reinstalled the rear brake line, put on rear brake drums, swapped the rear wheels from the 92, drilled and tapped a broken crossmember bolt (not so sure on the strength of that one), and last but not least, I installed my cruise control controls. Haha
http://i474.photobucket.com/albums/r...J/DSC_0067.jpg
Dad helping with the tcase studs
http://i474.photobucket.com/albums/r...J/DSC_0069.jpg
This is my location for the cb. If I hate it, then I'll move it. Seems like it should be okay for now, though.
http://i474.photobucket.com/albums/r...J/DSC_0085.jpg
Have to buy new engine mount bolts and she'll be in today (Monday, 3-12)!
http://i474.photobucket.com/albums/r...J/DSC_0087.jpg
End of the day, at 4:15am.
http://i474.photobucket.com/albums/r...J/DSC_0088.jpg
csouers 03-18-2012 01:53 AM
Big update time:
Bought the world's best fluids for it. I was going to put in 10w30, but they didn't have any single quarts left, so I opted for 10w40. The engine doesn't seem to care, so I'm not worried. At least it's CLEAN oil. Haha
http://i474.photobucket.com/albums/r...J/DSC_0099.jpg
Got the drivetrain installed Tuesday-ish. Went to fire it up and it wouldn't start, running on maybe one cylinder. After process of elimination, we narrowed it down to the injectors. One was firing, with another barely spitting and the others doing nothing at all. Great fuel pressure, just no flow.
http://i474.photobucket.com/albums/r...J/DSC_0104.jpg
The new Quadratec catalog sitting on the brake booster of course. Haha
http://i474.photobucket.com/albums/r...J/DSC_0107.jpg
I headed to the junkyard, Thursday, to get some parts. While I was there, I picked up a TPS (was throwing a code) and a set of 784 injectors. I installed them, of course, without the pintle caps because I didn't know what those were. So right now, there aren't any caps installed. Seems to be fine, so... yeah.
http://i474.photobucket.com/albums/r...J/IMG_1118.jpg
Here she is, smoking out the garage. Our hypothesis is that when the old engine blew, it poured coolant down the exhaust and, thus, into the catalytic convertor. The burning has gone down quite a bit, though I can still smell a hint of coolant in the exhaust. Also, the IAC is stuck in high idle mode and is idling at about 1700 rpm. If you blip the throttle it'll hold at 3k. Shut it off and restart, back to 1700...and it's been cleaned, so it's definitely not dirty. Corroded and rusty, sure.
I ordered an IAC from eBay tonight, so that should solve that problem. The idle sure makes getting the Jeep in and out of the garage quite interesting. :)
http://i474.photobucket.com/albums/r...J/IMG_1120.jpg
Pulled out of the garage for the first time under it's own power since we got it in august. Man do I love the sound of the 4.0l.
http://i474.photobucket.com/albums/r...J/DSC_0002.jpg
Took the air-snips to the front drivers fender. I think it turned out okay. Needs some smoothing out, then the lip painted.
http://i474.photobucket.com/albums/r...J/DSC_0019.jpg
Hooked up a set of battery tender ring terminals permanently to the Jeep because the battery is on its last legs, so keeping it plugged in should prolong its life somewhat.
http://i474.photobucket.com/albums/r...J/DSC_0029.jpg
Going for a different look this time around, I took off the roof rack. I'm kind of torn on how it looks, but think it's *different*. We'll see if it stays that way.
http://i474.photobucket.com/albums/r...DSC_0035-1.jpg
Went to complete the passenger rear quarter trim tonight. Thought to myself "I need to take this trim off so I can see if something in there could catch fire". Surely enough, a sealed bag with fiberglass insulation was in there (along with tons of dirt, rust, and rocks that somehow make their way up there). I'm assuming that the body shop, that fixed the body from a wreck, threw it in there to quiet it up before putting the trim back in.
http://i474.photobucket.com/albums/r...J/DSC_0071.jpg
1.5hrs or so, here's it *mostly* done. Still needs riveting/welding, filled, sanded (more) and painted, but it looks alright.
http://i474.photobucket.com/albums/r...J/DSC_0092.jpg
That's all folks. Heading back to Btown tomorrow for school. Should be getting the new IAC this Wednesday, then back home for a truck show and more work. I'll report back then.
XJ_Renegade 03-18-2012 07:35 AM
Now I remember how I was supposed to trim my rear fender wells. :facepalm:
Oh well. Looking good so far! Great to see it running under it's own steam. :thumbsup: What do you have planned for it?
csouers 03-18-2012 04:19 PM
Yeah. I saw that you didn't do the cut and fold on yours and I got immediately sad. You should get that seam welded up before the thing gets too tweaked. Your XJ's body is too nice for that.
The plan so far is Waggy 44/98+ Isuzu 44, 4.88s, 35" Treadwrights, 4.5-5.5" of lift, front Clayton 4link long arms, high steer with flat-top knuckles, hybrid cage, 2x4 rockers, custom inner fenders, and when all that has been achieved, Dana 300 with 4:1 and a stroker. :)
Maybe a bit ambitious, but hey, can't a man dream? :laugh:
XJ_Renegade 03-19-2012 08:09 AM
If only I had a welder or the willingness to pay someone to weld it. I'm thinking either a pop rivet or a small screw every inch or two where the inner and outer panels are still parallel. Individually they're weak, but a couple dozen of them should hold strong. Then I can respray bedliner over them to make them disappear.
csouers 05-10-2012 09:17 PM
Small update. More coming tomorrow
Used this:
http://i474.photobucket.com/albums/r...p/DSC_0262.jpg
...to go from this
http://i474.photobucket.com/albums/r...p/DSC_0261.jpg
...to this
http://i474.photobucket.com/albums/r...DSC_0260-1.jpg
Only pieces were the drill, the pad, and the arbor. The arbor is a standard 5/16ths piece, but I didn't have one, so I bought one. The pad just screws in and then put the arbor into the drill.
The pad: http://www.amazon.com/gp/product/B000IHK2TY/ref=oh_details_o01_s00_i01The arbor: http://www.amazon.com/gp/product/B000OH00K4/ref=oh_details_o01_s00_i00
Most definitely the easiest way to remove adhesive, and it doesn't scratch or wear the paint if you do it properly (move the side to side when in use). I love it.
I also painted the grille and bezels flat black and installed the wiring harness and turn/parking lamps.
http://i474.photobucket.com/albums/r...DSC_0267-1.jpg
Next up, bedlining the quarters, doors, and fenders.
robd2003 05-11-2012 12:57 PM
Jeep is lookin very good there buddy, I need to be doing some trimming on my rear fenders for the 35's lol, tires get stopped at the bottom of the fender :/ but no biggie, be doing it tomorrow along with fixing my leaf springs
csouers 05-11-2012 04:13 PM
Thanks Robert. Have you started a thread for that thing yet?
Bedlined the side today
Masked off
http://i474.photobucket.com/albums/r...J/DSC_0276.jpg
Light coat of primer
http://i474.photobucket.com/albums/r...J/DSC_0278.jpg
Second layer of primer. Spotted in the next layer.
http://i474.photobucket.com/albums/r...J/DSC_0283.jpg
Lined. I did a light coat the first couple layers. The third (and final layer I think) was more of trying to achieve the texture I wanted. It's not perfect, but it seems to be blending better as it cures.
http://i474.photobucket.com/albums/r...J/DSC_0286.jpg
The texture I was going for. I got pretty close.
http://i474.photobucket.com/albums/r...J/DSC_0272.jpg
http://i474.photobucket.com/albums/r...J/DSC_0008.jpg
http://i474.photobucket.com/albums/r...DSC_0035-2.jpg
RC shackle relocation. Makes me realize how badly I need new leafs and shackles.
http://i474.photobucket.com/albums/r...DSC_0045-1.jpg
My modified cb antenna mount. Was originally a hood-mount, but I made it work for the quarter panel. It's a little thin where the bend is, so we'll see how it holds. It's made of stainless, so I think it should be okay.
http://i474.photobucket.com/albums/r...J/DSC_0046.jpg
IRO front recovery. This thing is beef. Requires drilling a 1/2" hole in the front crossmember, but it should do the job nicely. The powdercoating on this is MUCH nicer than the RC crap. Never buying anything from them again. Great service, just crap for a finish.
http://i474.photobucket.com/albums/r...J/DSC_0056.jpg
The time now is 12:54 PM.
