'98 ZJ slow build - Page 3 - JeepForum.com
post #31 of 42 Old 12-01-2013, 06:06 PM Thread Starter
CGlaser
I haven't been moving very fast on the Jeep as I would like. I have not tackled the Pinion seal and Bearings in the Dana 35 as of yet, Hoping to do so sometime this month, but I'm learning not to make any promises on the jeep. Until Then, Just checking the oil in the Rear End and keeping it to small Excursions around here.
Decided I was tired of the Lights being Chrome.. with specks of rust. So I removed the Top lights, sanded, and painted them, with a Little help of KDStewart. threw them Back up there. Look good, pics to come.
Exhaust leak has gotten worse. I think its time i finally address that issue.
http://www.jeepforum.com/forum/f22/98-zj-slow-build-1484672/
CGlaser is offline
post #32 of 42 Old 03-20-2014, 01:32 AM Thread Starter
CGlaser
Been A while since I've been on here. Spring Break. Woo Hoo! That means, time for some repairs. Decided to finally tackle the Rear Dana 35, rather than just keep adding oil to the diff, Thinking that the Pinion bearings were bad, and that's why My pinion seal was leaking yet again. With Help from My Father, and some Help from KDStewart, we got this project Underway. (I've been only able to work on it a few hours a night before I go to work, so The help is appreciated.)
Started Off By taking off all the tires and rotate them, Just left the Back ones off.
After we got the front wheels Back on, We went to work on the Back, Cracked the diff open, Drained the oil, all the normal stuff, Pulled the Axles out of the shaft. (went a little overkill on this side and disassembled the Parking break on this side.)
took out the Ring and Pinion, And this is where we found the real issue with not only the rear end leaking, but the growl I've had since I had since I had bought the Jeep.
The Bearing that are on the Ring have been worn, causing it to be a tad crooked. this has caused a little wear on the pinion (growl, and why it was leaking). took a torch and cut the bearing off pretty easily. Some wear on the Pinion Bearings. Overall the diff. Wasn't too bad, Ordered a Rebuild Kit from Oriley's.
End of day two.
When taking it apart, we also found the Driver's wheel Seal to be leaking, Pulled it out, (Pain to get out). Figured we Would replace Both sides, while we have it all taken apart.
Parts didn't come in today like I thought they were going to, so, the time we spent today working on it were spent examining the Headers that are leaking Up front.
as you can see from Underneath the Jeep, The headers have cracked, It looks the same way from the top. Going to have to Pull the headers off to weld them, broke them completely, Hopefully we can do this Friday.
Decided that while we were waiting on parts, I would Deep clean the interior of the Jeep. took out the front seats, and rear bottoms.
Did this so that I could clean the Carpet in the Jeep.
Door Panels are still off on the front, Still need to put the New bushing set in to fix the door sag. That will be at a later date though.
CGlaser is offline
post #33 of 42 Old 03-20-2014, 01:33 AM Thread Starter
CGlaser
Sorry for the Large *** Pictures, I tried to Cut them down a little.
CGlaser is offline
post #34 of 42 Old 04-01-2014, 02:59 AM Thread Starter
CGlaser
Got the jeep done last week. Didn't get it done in time to take it wheeling by the 19th. The 20th. Had a break calipar lock up on me. Replaced that this weeked. This past saturday me and KDStewart took our ZJs to SMORR in Seymour, Mo. Good trip. Minor on trail damage (not on my rig). Overall sucessful weekend. Attacking the header problem next. Along with the door pins. Plan on bedlining the front bumper since the weather is getting warmer.
CGlaser is offline
post #35 of 42 Old 05-13-2014, 12:10 AM Thread Starter
CGlaser
Got the headers welded back together, found that i had broke. The rear trac bar off... again. Got that welded back up as well. Still need to.do the door pins. But at this point might just leave the front doors off..or see if cant get/make some tube doors for the summer.
CGlaser is offline
post #36 of 42 Old 07-13-2014, 05:12 PM Thread Starter
CGlaser
Took The Panty Dropper to Kansas Rocks offroad Park, Did pretty well considering I have open Diffs, a Dana 35 rear. Butted up against a Tree and dented in my rear Hatch. Went Back last weekend, Hit a different tree and Broke the rear glass and broke the hatch more. Looking for a new one, and repairing the brake the is locked up on the drivers side this week.
CGlaser is offline
post #37 of 42 Old 01-14-2015, 02:38 PM Thread Starter
CGlaser
Tranny finally died on me...
CGlaser is offline
post #38 of 42 Old 01-14-2015, 11:45 PM
McColorado
Thats a bummer! Is this going to be the end of this.... or are you throwing in a nv3500?? a 42re would be acceptable too..
Project Ugly Betty
http://www.jeepforum.com/forum/f22/97-zj-ugly-betty-build-2948561/
McColorado is offline
post #39 of 42 Old 01-15-2015, 12:01 AM Thread Starter
CGlaser
The ZJ will live again. If I get the money. I would like to do a 360 swap with a sequential transmission. But that may just be dreams lol
CGlaser is offline
post #40 of 42 Old 02-25-2015, 02:49 AM Thread Starter
CGlaser
Ordered a rebuild kit.
CGlaser is offline
post #41 of 42 Old 03-03-2015, 04:11 PM Thread Starter
CGlaser
Overhall kit came today!
CGlaser is offline
post #42 of 42 Old 02-24-2016, 03:23 PM Thread Starter
CGlaser
Got the Tranny back. Have to get it into the Jeep.
CGlaser is offline
