98 XJ -The TJ's brother build - Page 2 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 98 XJ -The TJ's brother build
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 03-15-2012, 12:54 PM   #16
DezertTJ
Shackles for rear and a 1" spacer for front. That's pretty cheap... The TJ needs more than cheap little things right meow to make it where I want it
DezertTJ is offline   Reply With Quote Quick reply to this message
Unread 03-15-2012, 01:57 PM   #17
Tenshots1
You said somethin about fenders....im thinking those wont be cheap
2005 Jeep Sport 4" lift With plenty of goodies
My Build Thread: http://www.jeepforum.com/forum/f22/budget-jeep-1151796/
Tenshots1 is offline   Reply With Quote Quick reply to this message
Unread 03-15-2012, 04:17 PM   #18
DezertTJ
Stock flairs I found a set for front and rear for $20
Unread 03-16-2012, 04:53 PM   #19
Tenshots1
I still don't approve! BTW There is a Tj Dana 44 with 3.73 and LSD for sale for $500 in SD
Unread 03-17-2012, 08:11 PM   #20
DezertTJ
I saw that! And I was in SD at the time but don't have 500 to spend. Those km2s need to be paid off
Unread 03-17-2012, 08:54 PM   #21
Tenshots1
o yea thats true! Forgot about that little detail
Unread 04-04-2012, 02:09 PM   #22
DezertTJ
New Transmission mount today. Its a pretty simple task. I took pics just in case anyone needed to find out how to replace one
The mount was ordered from RockAuto and the brand was Anchor. I wasn't expecting quality but this one seemed nice when I opened it up
But first, Secure your XJ in a good location to work on it. Mine was in the garage, but I couldn't fit all the way
Here is the new mount
The old mount, still mounted
Lift the jack up to the transmission with a piece of wood to keep the transmission and tcase from crushing you
Unbolt the 4 bolts at the transmission mount and the 4 bolts that hold the crossmember up. Its not that heavy, use your arms and a knee to catch it
Remove that. The bolt sizes should be 13mm for the mount and 15mm for the crossmember bolts
Now you've got the mount still mounted to the transmission by 2 18mm bolts
Remove that and put the new mount in the same way you took the old one out. The mount is side specific, so make sure you remember how the old one was mounted.
Bolt up the new mount
It's good to use 2 jacks for this. One where you are keeping the drivetrain up, but the other to push the crossmember up so you can bolt it all together. The stock jack that came with the XJ works just fine for this job if youve got a 3.5" lift like I do
All done once it's all bolted up. I noticed that my mount was old enough that it was sagging the drivetrain. With the new mount on there, It looks like I brought it up an inch or so
The old mount was long gone. only 3 studs were actually in place when it was mounted
And there you go. New trans mount all finished up. Hopefully this helped someone
Unread 04-04-2012, 02:33 PM   #23
csouers
Very nice. I put the same mount in my XJ. Install went well and it fits...so I guess that's good??
That missing stud looks sketchy.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s - The DD
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s - The Rig
My Photography
csouers is offline   Reply With Quote Quick reply to this message
Unread 04-05-2012, 03:14 PM   #24
RacerX
1989 XJ Cherokee
Nice. looks pretty simple
what does the stock XJ jack look like? - I don't have one, never seen one
4-wheeling is about going where others can't won't or don't think it's safe.
Freedom. Exploring the wilderness, or nature, whatever... - NOT paying to go on someone's roller-coaster ride, or go-cart track!
"The price of freedom is eternal vigilance." - Thomas Jefferson
RacerX is offline   Reply With Quote Quick reply to this message
Unread 04-11-2012, 10:12 AM   #25
DezertTJ
That black one holding up the crossmember was the jack. It was located underneath the back seat on the passenger side
Unread 04-13-2012, 03:08 AM   #26
RacerX
1989 XJ Cherokee
so, it's hydrolic? Nice.
I'd like to try and find one at the Junk Yard
Is there any identifying marks on it? (I can only see the top)
Unread 05-08-2012, 11:27 PM   #27
DezertTJ
Picked up 2" shackles for the rear and 2" spacers for the front. putting the 33" km2s on after i install the extra lift. I cant tow the TJ back for the summer, so this'll be my summer wheeler until I get back to Flagstaff
Lift should be put on either tomorrow or friday
Unread 05-11-2012, 08:10 PM   #28
DezertTJ
Finished it up for now. Could only put on the front 5.5 while the rear stays 3.5 because of a shackle problem. I'll get that fixed once I get different shackles and modify the exhaust. But for now, it does the job
Unread 05-22-2012, 10:36 PM   #29
DezertTJ
Finished up the rear. Netted 6" of lift with the shackles
Took it wheelin real quick today for a test to see how the lift does
Unread 06-03-2012, 01:51 PM   #30
Dirt22
Looks good kid!
How's school going?
[url]www.InlandJeepFreeks.com[/url]
LCG TJ Build ---[URL="http://www.jeepforum.com/forum/f22/dirts-98-tj-runt-lcg-build-thread-1093900/"]http://www.jeepforum.com/forum/f22/dirts-98-tj-runt-lcg-build-thread-1093900/[/URL]
DD XJ Build --- [URL="http://www.jeepforum.com/forum/f22/dirts-98-xj-build-thread-1183599/#post11184995"]http://www.jeepforum.com/forum/f22/dirts-98-xj-build-thread-1183599/#post11184995[/URL]
Dirt22 is offline   Reply With Quote Quick reply to this message
