98' XJ - Gettin her trail ready - Page 13 - JeepForum.com
post #181 of 488 Old 02-10-2013, 10:14 PM Thread Starter
straightsixjeep
Originally Posted by Project1 View Post
Really clean work
Thank you
Originally Posted by 8pitcher View Post
I have some wheels here I'd sell you
Pics?
Originally Posted by MattBillyTayloe View Post
Do it
Why you mad?
straightsixjeep is offline
post #182 of 488 Old 02-10-2013, 10:20 PM
8pitcher
8pitcher's Avatar
Originally Posted by straightsixjeep
Thank you
Pics?
Why you mad?
Is your lug pattern the same as a cj?
8pitcher is offline
post #183 of 488 Old 02-10-2013, 10:27 PM Thread Starter
straightsixjeep
No
post #184 of 488 Old 02-10-2013, 10:33 PM
8pitcher
8pitcher's Avatar
No
Well then I don't have wheels for you.
8pitcher is offline
post #185 of 488 Old 02-10-2013, 10:44 PM
MattBillyTayloe
Dumb ***.
I be mad cause that cut and fold is sexy
MattBillyTayloe is offline
post #186 of 488 Old 02-10-2013, 10:58 PM Thread Starter
straightsixjeep
Dumb ***.
Haha It came out real nice like for my first ever body work (other than bondo on different vehicles). I cant wait to build a rear wrap around bumper. Il get pictures of the Curt hitch I installed with its d-ring receiver next. It doesnt hang as low as I thought it would which is nice. Im tempted to angle the rear bumper until I build one. What Id build would essentially be my front, might do d-rings not sure. Then rock sliders before my rockers get chewed up to bad. Found some dings
post #187 of 488 Old 02-10-2013, 11:01 PM
MattBillyTayloe
Just take the ball out of your Reciever and put a d ring in and save 30 bucks
post #188 of 488 Old 02-11-2013, 12:03 AM
8pitcher
8pitcher's Avatar
I'll help ya build one man.
8pitcher is offline
post #189 of 488 Old 02-11-2013, 12:50 AM Thread Starter
straightsixjeep
Already have a d-ring receiver.
Just need to get some $$.
post #190 of 488 Old 02-15-2013, 06:31 PM Thread Starter
straightsixjeep
Decided to do the cowl intake. I went to the local auto parts store and picked up Spectre 3in flexable air duct tubing, the plastic mount, 4 self tapping screws, rtv ultra black, and a 3in hole saw bit. I had trouble getting the whole saw bit to cut through the firewall or the airbox, it just wanted to jump all over the place. After if jumped off and cut my finger, I decided to use my dremel and reciprocal saw which worked perfect. First unhook your stock air intake tube where it hooks onto the air box cover. I use a flat head screw driver to pry the plastic hose clamp open, pop the air tube off the cover, un clip the 3 metal hold downs, remove the hose that runs from the valve cover to the side of the air box cover, then remove the entire airbox cover. Next remove the air filter, then you can get at the air box mounting nuts/bolts. 3 total, 2 bolts and 1 nut, all 13mm.
This is the 3in Spectre tubing -
Next cut/drill a hole in the backside of the airbox. I used my dremel for this. You want the air duct tube to fit very snug, so trim and little then test fit, trim more... (the inner circle was for the 3in hole saw bit, the outer was the duct tube actual diameter.)
Heres the tube inserted snuggly into the hole -
I trimmed a portion of the tube so I didnt have to trim the air filter -
Heres the whole setup including the end plastic mount (Dont forget to use some type of sealant around the air tube where it goes into the airbox, I used rtv ultra black.) -
For the front of the airbox I inserted 4 screws in the factory air intake area to help secure the plastic blocking material that I used -
I cut a piece out of my factory rear bumper end caps to block the old air inlet (I used rtv ultra black on the insde and outside of the box around the perimeter of the plastic piece to make it air tight -
I next coated the plastic air duct mount with rtv before I screwed in into the firewall -
Here it is in place -
Here it is complete -
Very easy mod and for $25 total its one of the cheapest mods yet. I dont get the loud noise upon start up that many do however at idle I can hear a very faint suction sound which I like. Also at WOT is sounds good! I have been cruising around all day because the Jeep feels and sounds like it has more pep. Ontop of now being able to go through deep water.
post #191 of 488 Old 02-15-2013, 07:04 PM
thenewguy79
Nice mod!
thenewguy79 is offline
post #192 of 488 Old 02-15-2013, 07:14 PM Thread Starter
straightsixjeep
Originally Posted by thenewguy79 View Post
Nice mod!
Thanks! Picked up hockey pucks going to extend the front bump stops. Really torn between flares or the cut and fold right now. Almost need to do the cut for the tires to clear no questions asked.
post #193 of 488 Old 02-17-2013, 12:48 AM
Project1
Clean work ... Damn, you did a good job
Project1 is offline
post #194 of 488 Old 02-17-2013, 12:48 AM
Project1
I like the plate a lot .....
Project1 is offline
post #195 of 488 Old 02-17-2013, 01:38 AM Thread Starter
straightsixjeep
Much appreciated buddy! I figured if Im going to start hacking the Jeep up I might as well try to make it look good. Jeep is on stands right now, new Moog front axle u-joints going in tomorrow. Going to the parts store as well to hopefully pick up new hub assemblies. Then bump stops and I might go through with fender trimming.
Trail ready beadlocks jjeeper Jeep Picture Requests 5 04-05-2011 03:29 PM
trail ready rear bumper 98cherokee19 Jeep Picture Requests 5 07-29-2009 08:24 PM
Trail Ready *One Pic* thejafe Jeep Builds 7 04-11-2008 05:40 PM
Trail Ready Beadlocks Why J? Jeep Picture Requests 2 01-08-2007 10:01 AM
99 WJ - Lift - Trail Ready? Xenarchy Jeep Picture Requests 1 03-24-2006 12:33 AM
