Whats up JF, This is going to be a somewhat slow "build," however Im always working on her trying to get as much preventative maintenance done as I can. This is my second jeep, my first was a 87' YJ that I fixed up and sold for this 98' Cherokee Sport. Spent some time looking before I found this one. 4.0, ax15, np231, chrysler 8.25, 4dr, and Im the 2nd owner! Getting her reliable before I start adding trail goodies. Things Iv done since purchasing the XJ around a month ago.
-New Dist Cap
-New Dist Rotor
-New Spark Plugs (Champions)
-New Spark Plug Wires
-Flushed Radiator
-New Water Pump
-New t-stat w/ gasket
-New Intake/Exhaust Manifold Gasket
-New Throttle Body Gasket (Cut one out of a sheet of gasket material)
-New Air Filter (K/N drop in)
-New Oil Pressure Sending Unit
-New Coolant Temp Sensor
-Changed Oil and Filter (Rotella T 10w30, PureOne Purolator Filter)
-Changed Trans Fluid (Pennzoil Synchromesh)
-Changed t-case fluid (Dex 3)
-Changed Rear Diff Fluid (80-90 weight gear oil)
-Replaced Both U-joints on rear driveshaft
-Replaced Leafs with Crown Heavy Duty Leaf Springs W/ Poly Bushings.
-Rugged Ridge Leaf Shackles
-Fat Bobs Garage U-bolts
-Replaced Trans Mount
-Replaced Rear Shocks (Monroe Sensa Trac)
-Replaced Tires (Bridgestone AT Dueler Revo 2 tires, 235/75/15)
-Replaced OEM rims with 98' Limited Tear Drop Rims
-Wired in a new usb/cd/aux JVC radio
-Rugged Ridge floor mats
-And last but not least, my first mod. Aussie Locker for chrysler 8.25 29 Spline
When I first bought it -
Doing Work -
Aussie -
XJ with friend XJ -
Current -
Mod #2 is in the mail, the d-ring bumper should be here in a few days. Thanks for reading all of this, once I get a paying job and wear these tires down a bit, Il be looking to get a lift and some 32s. Its a DD with the intention to occasionally wheel. We all know that its easy to go extreme with Jeeps. Stay Tuned :wave:
-New Dist Cap
-New Dist Rotor
-Flushed Radiator
-New Water Pump
Doing Work -
Aussie -
XJ with friend XJ -
Current -
