97 ZJ 'Ugly Betty' Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 97 ZJ 'Ugly Betty' Build
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 01-12-2015, 11:09 PM   #1
McColorado
I guess i'll start with the basics, she's a '97 ZJ Laredo with the 5.2, 42RE, and np249 combo. Back when I first bought it:
I Drove it and worked out a few bugs in the mechanical side of things, did a full tune-up fluid exchange etc.
The first 'Mod' was a 2" lift.
Before:
After:
Then I went and wheeled it.... Plenty.
McColorado is offline   Reply With Quote Quick reply to this message
Unread 01-12-2015, 11:24 PM   #2
McColorado
After a while I decided to pull the front plastic bumper cover, and while I was at it, I painted the rest of the trim black.
I took it wheeling more after that, and on this trip, popped a bead...
I ended up sliding about 40 feel down a steep mountainside and had to recover myself with a little 2klb come-along winch.
Open diffs with almost bald tires don't fare well with steep, icy conditions.
Later, I mounted some rack lights and a Hi-Lift Jack on my front bumper.
Then finally got some new shoes for the old girl. 31X10.50 Goodyear Wrangler Authorities
Did some early-winter wheeling
Broke my front driveshaft that trip trying to pull out that F-250...
Made Myself a PVC flagpole for ****s-n-grins.
I got a little cocky with my now rear wheel drive ZJ, and got her stuck in some mud...
Unread 01-12-2015, 11:35 PM   #3
McColorado
Here we are, spring of 2014, I went on a trip to Moab with my good friend, and went doorless just to try it out.
I Got myself a front driveshaft for this trip in Grand junction, and got to use it for a good hour or so before the CV blew up....
Ended up running it for a while in 2X4 as funds were short, but it still preformed very well for being a rear wheel drive rig.
Now here is where the story takes a bit of a turn. Late summer 2014, I decided to take a solo trip up in the mountains in rear-wheel drive of course.
I got caught on a patch of ice and before i knew it... BAM! Right into a tree. :
Now, at this point I was debating weather or not to try to recover the beast as I only had liability so I couldn't collect any insurance compensation. I decided it has been so reliable and still has such solid mechanics, I decided to keep it. The damage was not too bad, only about 3 or so inches of the frame on the passenger side got bent.
Got the broken fascia off - for the most part.
Unread 01-12-2015, 11:48 PM   #4
McColorado
I then began to fab a 'stubby' bumper/winch plate. Progress was slow as this is my DD and I need a way to get to work, but this is the beginnings of revival.
And now, here it sits, up to date.
Future plans:
Finish up the stubby bumper, possibly do some tube work to 'finish' it off more.
attempt to hunt down a header panel and maybe a 5.9 grille.
3.5" lift
Custom rock rails
Custom roof rack
Custom rear bumper/tire carrier
I've got a parts Jeep coming to my house around March with a np242 in it so when that comes i'll be pulling that apart and rebuilding it then replacing my blown 249 with it.
Unread 01-25-2015, 01:27 PM   #5
Onew1ckedzj
I like that stubby bumper idea! . . got any pics of how you mounted it? Im assuming youll add some protection to the front of it to protect the radiator? Sucks about the tree, they always seem to come out of no where lol . . nice build keep up the good work!
Onew1ckedzj is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 11:03 PM   #6
McColorado
TThanks! Its just mounted with some basic grade 8 hardware with nuts welded to the brackets. Nothing spectacular. I was going for max approach angle with a winch, so this is what i went with. Id also not seen many zjs with a stubby setup so i figured I'd give it a go. Hopefully I'll be getting a tuhe bender soon and finish it off more.
Quick update: I'll be getting the parts jeep in the next couple of weeks instead of march, so I'll have some fun with that... half doors, tcase, ujoints in the front end... some fun to be had.
Project Ugly Betty
http://www.jeepforum.com/forum/f22/97-zj-ugly-betty-build-2948561/
Unread 01-29-2015, 03:13 PM   #7
Onew1ckedzj
Nice! ill be watching for updates, interested to see how it all comes together!
Unread 02-15-2015, 10:21 PM   #8
McColorado
Got some work done on the Jeep over the weekend. First off, I found a Header panel with a grille in great condition, so I went and picked it up for a great price. Went to put it on and was a little disappointed with my miss-measurements on my bumper, and ended up having to cut off my light tabs. But overall, the jeep looks way cleaner now- The lights were going to be relocated anyway. Here's how it looks:
Then I did the marker lights mod with simple JY parts. Tail light pigtails out of a 94 zj and some markers off of a pre-96 ZJ. I ended up using a 2357NA bulb, and the voltage is perfect! No more fast blinker with the headlight on!
And a quick teaser of my next fab project.....
Found a brush guard for an absolute steal, so I've began cutting into it, and I will soon fit it to the bumper. I'll be doing a U-Joint front end swap when I get the time, and The next step will be a higher lift. (3.5-4.5") not 100% sure yet. That's all for now!
Project Ugly Betty
