97 tj college build - Page 29 - JeepForum.com
post #421 of 618 Old 07-17-2013, 11:06 AM
tyvanwie
Measure every coil under the vehicles weight. Stock coils are 12" front and 8" rear. And I'm not sure about the correct side coils, I didn't have to do that. But I don't think one would be longer, I think it would just have a higher spring rate. So if you're just measuring the coil out of the vehicle, that may be the problem.
tyvanwie is offline
post #422 of 618 Old 07-17-2013, 11:22 AM Thread Starter
wrscpc07
But I've had this lift in my jeep over two years with no lean..this is new. Why would it start now? I assumed one sagged so I replaced it, but the problem still exists.
97 Tj 2.5 4" skyjacker 1.25 JKS BL. 35x12.5x15 8.8 w/ 4.88s
wrscpc07 is offline
post #423 of 618 Old 07-17-2013, 11:31 AM
tyvanwie
Well then it could be something more. What shape are your control arms in? You didn't wreck it, or smack down on one side wheeling or anything?
Edit: take out ALL of your shocks. See if its level.
tyvanwie is offline
post #424 of 618 Old 07-17-2013, 11:46 AM Thread Starter
wrscpc07
I replaced my control arms and shocks with the lift. I haven't even drove it in a year so no damage as been done from wheeling. This started since my jeep has been parked for the year while I was at school. So nothing can be damaged like that, it wasn't like this when I was driving it. It's soo frustrating
wrscpc07 is offline
post #425 of 618 Old 07-17-2013, 11:54 AM
homeboy1991
On the front axle spring buckets their are these specials keys that the springs sit in. Make sure your spring are keyed in them correctly. I had the same problem when I first put my lift in. The spring will sit about a half inch higher if it isn't seated correctly in the bucket.
My TJ Build Thread -
homeboy1991 is offline
post #426 of 618 Old 07-17-2013, 12:02 PM
tyvanwie
I'd still take the shocks out and see. It could be a dead shock.
tyvanwie is offline
post #427 of 618 Old 07-17-2013, 12:07 PM Thread Starter
wrscpc07
Ya I thought about that too, but the lift has been in for over two years and this is new, so the springs are sitting correctly. Plus, it's more than a half inch difference
wrscpc07 is offline
post #428 of 618 Old 07-17-2013, 12:08 PM Thread Starter
wrscpc07
I'll look into that
wrscpc07 is offline
post #429 of 618 Old 07-17-2013, 12:12 PM
tyvanwie
I'll look into that
You could just remove the front first and see.
tyvanwie is offline
post #430 of 618 Old 07-17-2013, 12:25 PM Thread Starter
wrscpc07
Well I took the shock out of the passenger side when putting the spring in and it seemed like it was in good shape to me
wrscpc07 is offline
post #431 of 618 Old 07-19-2013, 07:58 AM Thread Starter
wrscpc07
So like I said not really a fan of the new seat covers because way they fit and the some grey parts of the seat are exposed. These will just have to last me a little while until i can afford a better pair. I guess it's better than my faded red/pink ones.
Also, painted my ring around my windshield lights red, painted my sway bar links from gold to black and paintd half my faded hi lift black. Much better
wrscpc07 is offline
post #432 of 618 Old 07-20-2013, 04:30 PM
jeepwrangler97
The seat covers don't look bad & hey, if they were cheap, then
Sent by a messenger bird
jeepwrangler97 is offline
post #433 of 618 Old 07-25-2013, 08:36 PM Thread Starter
wrscpc07
Cel came on, jeep drives awful. Sputters, bucks, backfires, high idle, horrible gas.
Tps code reads, replaced tps, problem not resolved at all, cel never even went away even after unplugging battery.
Searched several forums and found it could be clockspring, horn relay, bad wires...unplugged clockspring, cel till there and it ran th same. Same with taking horn relay out. I started to measure the voltage of the tps wires but I wasn't sure what I was doing, I followed other members advice but it was getting dark and pretty much the only thing I got to was about a 5.12 volt read from the middle tps wire..key in the on position...so that means the sensor is getting power?..
Anyway, I don't know where to look next. My o2 sensor was changed about a yer and a half ago, same with the fuel pump but it doesn't stall on me so I don't the itsnth fuel pump anyway. I don't know where to look next and im incredibly frustrated.
Any help would be great.
wrscpc07 is offline
post #434 of 618 Old 01-11-2014, 03:13 PM Thread Starter
wrscpc07
been a while. busy with work and school and moving. Pretty much the only thing I've done recently is pretty much replaced most of my front axle. New hubs, new ball joints, u joints. Had to do it all for inspection. Also, upgraded to 35s I bought a set of 3 a few months ago then ordered one brand new one online. Then after mounting them I found a set of 2 brand new ones for 200 bucks. So right now I have 1 new tire installed and 3 used with no spare but next weekend I'm gonna replace two of the used ones with the other two new ones I bought and mount a spare. The jeep does not drive much different from 33's to be honest..not as dramatic as people express around here..I think when I get the 2 new ones on I'm going to have them put the white letters out this time
wrscpc07 is offline
post #435 of 618 Old 01-11-2014, 05:17 PM
Bobsgym
Are you still running the 4:10 gears with the D-35 on those 35's? I bought some 4:88's but they are collecting dust until I can afford the install. How is the braking with the 35's and are they 35x12.50?
Bobsgym is offline
My College TJ Build Hobojo Jeep Builds 241 07-09-2013 08:09 PM
College Build madflyer72 Jeep Builds 15 05-22-2012 08:45 PM
A (Broke) College Students XJ Build jfsjr92 Jeep Builds 31 02-27-2011 12:38 AM
94 YJ College Build kirbatron Jeep Builds 0 02-09-2011 01:15 AM
The Slow College Build: 99 TJ Chiles Jeep Builds 5 01-24-2011 10:30 AM
