97 TJ on 35s - Page 23 - JeepForum.com
post #331 of 337 Old 08-01-2013, 02:33 PM Thread Starter
Jay12
I got some tie-downs and ratchet straps from Lowe's the other day to be able to secure the spare and other things in the tub. I put a tie down in each corner of the bed.
Also because of a shipping error I am missing my clubs annual wheeling event to RC this weekend because my Metalcloak CA's won't be here, and I don't want to risk ripping my other front lower axle side mount off with the RC arms. Sucks because that was my only chance to wheel this summer.
Jay12 is offline
post #332 of 337 Old 08-09-2013, 04:41 PM Thread Starter
Jay12
Got the MC arms in the other day.
I was able to swap out the front 4 arms Wednesday. As the following pictures will show, the RC arms flex-joints and bushings gave out within the 3 years they were on, even with being greased.
It's hard to tell in this picture but this bushing is all cracked and ruined.
This is a video showing the play in the driver side upper flex-joint. Obviously this contributed to my rough ride.
My front driver side UCA bushing on the axle end isn't helping:
Front arms in:
I took it for a test drive Wednesday night with just the front set swapped. It was a dramatic difference in ride quality. The front end floated over bumps in the road, and the rear still took jarring hits.
Yesterday I was able to swap the rear arms out.
Here is a picture of the old, POS RC arms.
Also, an interesting difference between the arms. Look at the size of the shank for the RC UCA's vs. the MC. I always thought they looked small, but figured it may just be that way for all manufacturers. Obviously not..
After getting the rear arms in, I drove it again and the difference is amazing. I finally feel like I have a great ride and it just absorbs the bumps in the road. I don't receive jarring shocks each time I go over a pot hole. The Duroflex joints provide a much better ride than the RC poly bushings and X-Flex joints. Also, I probably won't have to worry about ripping a CA bracket off now because these are softer than the poly bushings in the RC arms. I can ride comfortable in the Jeep now.
Jay12 is offline
post #333 of 337 Old 11-12-2013, 10:07 PM
TexasTJ
No Longer DD
TexasTJ's Avatar
Looks good man
May TJ of the Month 2015
TexasTJ is offline
post #334 of 337 Old 11-14-2013, 10:57 PM Thread Starter
Jay12
Originally Posted by Cavasar View Post
Looks good man
Thanks
Haven't done much lately since being at school. Switched the soft top out for the hard top when I went home a few weekends ago.
Jay12 is offline
post #335 of 337 Old 02-25-2015, 11:06 AM
MMWrangler
I wanted to paint my YJ fenders with the duplicolor aerosol paint cans also. How many ounces did u need to paint 1 fender?
MMWrangler is offline
post #336 of 337 Old 04-16-2016, 04:13 PM Thread Starter
Jay12
It's been a long time since I've updated this. I think it was about a year ago I had another case of DW with the front track bar. Got a new bushing and new bracket and that fixed it. I'm really wanting to start driving the Jeep more again in the summer and actually wheel at least once this summer. Recently, I sold the hard top, bought the Currie JJ front housing kit, and a new Metalcloak front track bar & stock pitman arm to get rid of the RC crap. That will leave one piece of the RC suspension left on the Jeep (minus the springs) - the rear track bar, but I haven't had any problems with that.
I'm trying to get the front end all tightened up to cure any problems and prevent future issues. Today I got the Currie front housing JJ kit in:
I think the clevite bushings would've lasted a lot longer Now my arms are entirely MC Duroflex or Currie JJ's
Next up is taking the RC front track bar, drop bracket, and drop pitman arm off to be replaced with the MC piece and stock pitman arm. The trackbar is supposed to be here Monday, and I'm busy next weekend, so I'm shooting for two weekends from now hopefully. The 5/8" frame side hole seems like it'll be fun to drill so we will see.
This summer I may also try to replace the ball joints and I think I need some new TRE's in the steering.
Jay12 is offline
post #337 of 337 Old 05-15-2016, 04:18 PM Thread Starter
Jay12
Yesterday my dad and I swapped out the Rough Country front track bar/drop bracket and drop pitman arm for the Metalcloak track bar and stock pitman arm. What an adventure. Got everything off without any problems and drilled the lower hole for the Metalcloak bar to 9/16" without issue. I read about all the nightmares getting the pitman arm off so I started to cut it with a dremel since I wouldn't be reusing it, but I ended up getting it easily with the pitman arm puller...guess I was lucky.
So, we go to drill out the frame side bracket to 5/8". It was already drilled to 1/2", so we start with a 9/16" bit. That goes through without too much fight and then we put the 5/8" bit in the drill. Start making progress and probably get about 1/4 to 1/3 of the way through the hole and the drills motor burns up. It was my dads drill given to him by his father so it was about 40 to 50 years old...I think it was about time for it to go.
So we go to Home Depot and buy a new Milwaukee drill and put the bit in there. Finished up the hole fine and go to try the new bolt. It doesn't fit...hm weird. Try cleaning up the hole with the bit with a few passes through and then again try the bolt and no luck. Try a handful of other 5/8" bolts we had and none fit...weird. Try running the drill bit through the hole a bunch more and no dice. We decide the bit must be out of tolerance and too small. This was a brand new never before used bit so that sucks since these huge bits aren't cheap. Not only that, but we cant loosen the chuck on the brand new drill to get the bit out.
So, I go buy a new 5/8" bit and luckily it has a 3/8" shank. So we check and sure enough it won't fit in the hole we drilled with the other supposed 5/8" bit. So we get out the 3/8" drill and pass it through, and it fits no problem. Got everything buttoned back up and then test drove it this morning. It drives great and steering seemed to have tightened up. I had all of it off and retightened and greased everything so I'm sure some of that helped. I think the pitman arm nut needs to get on there further but it was not budging any further with my torque wrench so I may need to just take it to a shop to tighten it quick.
Jay12 is offline
