97 Red XJ Build - JeepForum.com
post #1 of 13 Old 04-06-2014, 08:35 PM Thread Starter
Aschmied25
97 Red XJ Build
Hey guys, I bought my first Jeep last week! I bought a 1997 red xj, 8.25 rear axle, dana 30 front, 231 TCase, AW4, 4.0, 180,000, no rust on floors or rockers. The Jeep needs some work, but I only paid $1500 for it. My plans for the future are a 4.5" lift, 31s or 32s, bumpers, sliders, skids, and maybe a rear locker.
Aschmied25 is offline
post #2 of 13 Old 04-06-2014, 08:36 PM Thread Starter
Aschmied25
Changed oil, trans fluid, transfer case fluid, throttle position sensor, and idle air controller, and painted the wheels black earlier this week!
post #3 of 13 Old 04-06-2014, 08:36 PM Thread Starter
Aschmied25
The pictures:
post #4 of 13 Old 04-06-2014, 08:38 PM Thread Starter
Aschmied25
Today I decided to fix the only rust on the jeep. It is the notorious roof rust by the windshield frame frame from the gutters holding water. I started by sanding the spots down. Then I cleaned them and sprayed with a rust primer. After letting that cure overnight, I sprayed on some regular primer. I sanded the regular primer down and applied the topcoat. I did my best to blend the paint. I the next week I am going to wet sand the paint lines and buff them. Hopefully that will help blend that paint better. I will post pictures of the finished product tomorrow!
post #5 of 13 Old 04-06-2014, 09:37 PM
AppleDevKevinG
Looks good!
2013 Jeep Wrangler Unlimited Rubicon, Commando Green
2005 Jeep Wrangler Unlimited, Impact Orange
"Well thats an interesting sound"
AppleDevKevinG is offline
post #6 of 13 Old 04-06-2014, 11:00 PM
melx3
Looks, nice. I've secretly always wanted one of these....
melx3 is offline
post #7 of 13 Old 05-09-2014, 11:42 AM Thread Starter
Aschmied25
I've done a lot since I have updated the thread. I waxed the jeep and got it tinted!
post #8 of 13 Old 05-09-2014, 11:48 AM Thread Starter
Aschmied25
I order my lift and tires too. 3.5in RE super ride, RE1600 track bar, Skyjacker 7000 series shocks, full leafs, pro comp steelies with 3.75in backspacing, and 31x10.50R15 General Grabber AT2s!
post #9 of 13 Old 05-09-2014, 11:51 AM Thread Starter
Aschmied25
Just some of my stock wheeling pictures I though I would put up before the lift pictures. Stock XJs are very fun!
post #10 of 13 Old 05-09-2014, 12:02 PM Thread Starter
Aschmied25
Today was lift day and let me tell you, it was a long one. My brother and I were going to do it. We have a torch and welder so I didn't expect it to take too long. It seemed like every bolt fought us even with the torch. 2 shock tower bolts broke. Ended up knocking the broken part out and putting a nut and bolt through the hole. One of the worst ones was the driver side leaf spring front bracket. The weld nut inside the unibody snapped. I ended up having to cut a hole in my unibody to get a nut behind it. The lower control arms bolts were spinning in the metal sleeves/bushing. We had to melt the bushing with the torch to get the bolt out. Went with a tcase drop until i can get an SYE. Welded the nuts to the stud and just backed them out. All in all the lift took around 15 hours to do. It was a pain but well worth it! I love the way my XJ sits and rides. I took both the front and rear sway bars off. Even without the sway bars, the RE coils make it stable on the road, and it is flexy as could be! I would definitely recommend this kit to anyone. Very good quality.
Hole in the unibody I cut
post #11 of 13 Old 05-09-2014, 12:04 PM Thread Starter
Aschmied25
Here are some post lift pictures!
post #12 of 13 Old 05-09-2014, 12:07 PM Thread Starter
Aschmied25
Found someone in my area selling a bumper and I ended up buying it. I paid $85 for it. I put a painted the bumper and had to bend one of the brackets back with the torch. I can't seem to sell what kind of bumper it is. Just a simple one with D ring and receiver mount. Here it is!
post #13 of 13 Old 05-13-2014, 05:05 PM
Project1
lookin nice man
Project1 is offline
