96XJ Forest-Cruiser build - JeepForum.com
 12Likes
post #1 of 94 Old 01-24-2016, 09:37 AM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
I am finally putting my build up on here to document my progress and swap ideas and advice. I first got into jeeps and fourwheeling with a 00 XJ I wrecked. The goal is to turn it into a reliable weekend xplorer and camping vehicle. I picked this one up on craigslist for a 1,000$. It didn't run and has a bit of rust I am trying to fix. The no start issue happened to just be a blown fuse. So on to the Jeep its a 96 with a 4.0 HO with 211,000 miles an AX15 transmission NP231 D30 and D35 axles
kzim93jpz is offline
post #2 of 94 Old 01-24-2016, 10:08 AM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
Here is pic of it in stock form. Its gonna take me awhile to catch up to my current progress.
post #3 of 94 Old 01-24-2016, 10:56 AM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
The first thing I did was gut the interior. Headliner was sagging so took that out and the carpet so I could fix the floor. Both rear corners were rusted thru and the front passenger side floor pan is bad here are a couple pics of fixing up the rear and herculining the inside. If you wanna see anything special let me know I have alot of pics.. I won't be posting them all
20141222_165400.jpg   20150124_171744.jpg   20150311_181730.jpg   20150613_163151.jpg
post #4 of 94 Old 01-24-2016, 11:18 AM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
After reading others builds on the forums for months. I decided to go with a 4.5in lift and 33s. I went with rubicon express short arm 4.5in with monotube shocks which to my surprise are actually bisteins. I also swapped out the d35 for a Chrysler 8.25 I got off craigslist...not sure of the gear ratio but ill be doing a regear soon enough. I also wire wheeled the underside and primered and painted it with rustoleum black.
post #5 of 94 Old 01-24-2016, 12:23 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
Putting the lift kit on wasn't overly difficult. Only two of the upper rear shock bolts broke off so I drilled and tapped them. Drilling out the upper trackbar mount was tough. The lift only had ubolts for the 35 so I had too order some others for the chry. The rear leaf springs were shot a couple leaves were broke in half. We aligned it with a tape measure for the time being. I also cut the front bumper and the fenders really opens it up nice
post #6 of 94 Old 01-24-2016, 12:33 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
It looks really goofy with the little donuts under it..I've been contemplating whether to go with 31s or 33s and between the BFG km2 or mickey thompson mtz. I was also checking around on craigslist. The rear of the xj sits about 2in higher than the front and the shackle angle is terrible gonna deal with that later on
post #7 of 94 Old 01-24-2016, 12:42 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
Ordered some goodies from summit. New distributor cap,wires and plugs a felpro valve cover gasget and the real winner... advanced adapters np231 sye. Everything went together smoothly now I need to order a driveshaft
post #8 of 94 Old 01-24-2016, 12:54 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
I went to the Jeep Show at York Fairgrounds what a blast except it rained in the morning...the first show I've been to I bought a front bumper, all the brackets,bolts and steering box spacer for 250$ from Creepy Fabrication. Can't beat that...it is a solid bumper and I had been eyeing DIY bumpers from JCR and Dirtbound Offroad previously
seaweed88 likes this.
post #9 of 94 Old 01-24-2016, 01:06 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
What do we have here???? I ordered gloss black steel procomp wheels with 3.75in backspacing in 15" and 33x10.5r15 BFG KM2s from 4wheel auto parts...they came mounted and balanced .. I went with the narrower tire in hopes it may help fuel mileage also sold the old wheels and tires on craigslist and recouped 200$ for more Jeep parts btw I weighed the tires to see how much weight I was adding. The new wheels and tires added bout 100lbs total over the stock ones and weighed around 75lbs ea.
post #10 of 94 Old 01-24-2016, 01:20 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
I ordered a double carden driveshaft off ebay..got my bumper painted and installed it..and put the tires on.. I had to trim the inside of my fenders alittle..I would like to put bushwhacker or napier flat flares on someday?
post #11 of 94 Old 01-24-2016, 01:48 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
After doing alot of research I decided to order gears for the rear and since ECGS was running a sale. The front will wait for alittle bit...ordered a 4.56 motive gear r&p which they didnt have in stock so I got upgraded for the same price to a nitro set!! Also got a master install kit, wheel bearings a magnetic base and dial indicater. And while your doing all that may as well put a locker in huh so I also ordered a detroit truetrac. .I know a selectable is the way to go but so many $$$
post #12 of 94 Old 01-24-2016, 02:05 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
Awhile ago I ordered a passenger floor pan from z&m jeeps. I cut out the floor, now I just need to finish welding it in. Btw I hate rust; but being's i was looking for a 5spd. manual for cheap i couldn't be picky. In hoping to have it on the road by spring. Till then I have to keep busy.
post #13 of 94 Old 01-24-2016, 02:14 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
I also did a zj tierod swap and new rod ends.It is a good bit beefier, aught to do the trick for now. And finally to fix the shackle angle and level the heep. Ordered the no lift shackle relocaters from H.D. Engineering; these things are massive
post #14 of 94 Old 01-24-2016, 02:21 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
Got the shackle relocaters finished this weekend...seems like it definitely improved the flex..I need to get more black paint to finish them up..cant wait to take it around the block
post #15 of 94 Old 01-24-2016, 02:31 PM Thread Starter
kzim93jpz
Junior Member
kzim93jpz's Avatar
Now things to be done yet!!!
Finish the floor pan & herculine it all, put the interior together somewhat
Setup the gears and locker, put Speedo gear in
Drop it off at the shop for exhaust & alignment
Do some engine maintenance and get it inspected once
Keep posted because there is a never ending parts list..need to get it on the road so we can start the fun
