95 zj dd - Page 3 - JeepForum.com
post #31 of 61 Old 04-29-2013, 10:15 AM Thread Starter
PeteNnewburg
Thank You!
I got my order from The Fastener Wharehouse.com! New screws, wireing loom retainers, trim panel retainers, spring & clip nuts, rocker & bumper trim retainers, trim screws + more... almost like a mini Christmas! I hate trying to reuse the OE plastic retainers and rusty screws.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline
post #32 of 61 Old 04-30-2013, 08:35 PM Thread Starter
PeteNnewburg
A few too many Yuengling Lord Chesterfields and I ordered a header & 3" exhaust system including a cat from SUMMIT..
Kolak does not have a mandrel bent down pipe, or it could be I pissed him off!?.
I'll adapt the stock down pipe for now and order a 2.5/ 3" mandrel tubing kit.
My impact ball joint/ tie rod seperator tool set arrived along with the bulk purchase of K&N oil filters. The transmission pan drain kit alsoo arrived. Looks like my work todo list is piling up!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #33 of 61 Old 04-30-2013, 09:39 PM
GCjunkie93
Nice man! But why would Kolak be pissed at you?
1993 ZJ 5.2 V8-Some Stuff/Beater
1984 CJ7 258/Auto/Dana 300/Daily Driver
GCjunkie93 is offline
post #34 of 61 Old 05-02-2013, 07:21 AM Thread Starter
PeteNnewburg
idk, bought the rest of the exhaust elsewhere. I was under the impression he had mandrel bent header to cat pipes..
I ordered the 3" cat backsystem & 3" cat from SUMMIT, 5PM on 4/30, it arrived @ 10AM the next morning. $237 shipped to my door in 17 hours, crazy fast shipping. The OE exhaust has a 1 7/8 tailpipe, makes the 3" look huge! The headers are supposed to be here Monday - Wednesday. I'll have to get moving and clean up the 99+ intake and 703 injectors!
I have her up on stands to do swaybar bushings, control arm & bushing replacement along with the 2" BB and new Bilsteins. I have a bunch of other stuff lined up and it looks like a good time to do the fuel filter and a little rust removal too.
I soaked everything in PB Blaster overnight, I hope it helps!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #35 of 61 Old 05-02-2013, 07:59 AM
ThatONeJeePeR
1991 XJ Cherokee
Can't wait to see how this will turn out!!! Good luck!
Originally Posted by misterpookie View Post
*sigh* using a controller for an FPS is like trying to jump start your car with nipple clamps: simply not the right tool for the job.
ThatONeJeePeR is offline
post #36 of 61 Old 05-02-2013, 06:53 PM Thread Starter
PeteNnewburg
Pretty productive day today all things considered, rear upper & lower control arms replaced on the passenger side, track bar at frame mount disconnected and swaybar half removed. I got a used swaybar from SQUAZZ a month or so ago, good thing 'cause the OE swaybar was almost rusted through!!
On to the left side in the morning. I had sprayed/ juiced all fasteners with blaster yesterday. Biggest issue was the Chinese Lower control arm. The bushing sleeve was 1/4" larger than the bracket. I checked it against the original sleeve and a Prothane bushing sleeve. Horray the bench grinder works! The track bar Torx Cap screw, lubed, heated, and then the cap screw head fell off. I was able to draw the bolt out from the other side by adding washers and tightening the nut as the bolt was rusted tight to the inner metal sleeve. 2 freaking hours between the two. My little sister showed up just in time with Brooklyn Lager!!
I did not get as much done as desired, BUTT, HHHMmmmm tasty beer!! I like hops!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #37 of 61 Old 05-03-2013, 09:09 PM Thread Starter
PeteNnewburg
Another productive day!! All rear control arms are now new!! Even the track bar bushings have been replaced! I still have a good bit of work to do, wire brushing of surface rust to prep for POR15, R&R rear sway bar to avoid rubbing on the ABS lines, clean and re-atach P Brake cables & metal brake lines. pics to follow!
I did have "fun" with the track bar fasteners. As mentioned before, the first was drawn through by adding washers, the lower required turning the left over bolt (from grinding/ cutting the head off) with the impact wrench while hammering with the air hammer bit. Why we were we not born with 4 arms I'll never know!! Oh Yeah, WTF torx bit suspension parts??
I did get to play with a lot of tools that had been growing dust! It is awesome to have the tools you need to do a job! It was a PITA to remove both upper & lower track bar bushings, but getting them out of their brackets was the real PITA.
To remove the OE bushings from the track bar, I used a 3/16 drill bit to start the process, drilling a half dozen holes on both sides of the rubber bushing. I used a Mapp Gas plumbing torch to burn out the rubber. Once the rubber part of the bushing was pretty much gone, I used a steel rod to push the inner sleeve out. Once the sleeve was out, I used a flat screw driver to loosen and remove the remaining rubber. I then used a carbide burr to grind a slot in the bushing shell, It was easy at that point to collapse the shell and push it out of the track bar.. I had a 8" C clamp ready to seat the new polyurethane bushings, but they went in nicely with just the supplied silicone grease.
I used new grade 8 fasteners where ever I could fit them, (Tractor Supply), (Side note!! Stock up on these as they are doing away with selling them by weight!!)
BEST PART!! I now have a 2" BB in the rear, complete with Bilstien shocks, poly bushings for both sway & track bars. The rear suspension is now very TIGHT, it was down right sloppy/ floppy when it was first lowered. I am looking forward to a much quieter ride, there was a LOT of slop back there!!
The drivers side upper control arm was SO rusted, you could see light through the flakey rust.
I did take some pics that I will post, but the process is best as described.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #38 of 61 Old 05-03-2013, 09:22 PM
ThatONeJeePeR
1991 XJ Cherokee
Glad to here that it was all do able!!! I absolutely hated the track bar bolts!!! Good job!
post #39 of 61 Old 05-03-2013, 09:27 PM Thread Starter
PeteNnewburg
Due to time and cash restraints, I bought the "Walker Brand" down/ exhaust pipe so I can get her back on the road ASAP. I'll do a mandrel bent pipe via kit when time allows.
The "wALKER pIPE sUCKS". It is a shame to turn a peice of 2.25 pipe into that monster restrictive crap. They should be ashamed of them selves. I'll post pics of the new pipes vs OE pipes.
SOAP BOX MOMENT --- SUMMIT Racing is awesome!! With a little bit of heads up, their prices can be the cheapest around, shipping is insanely fast and they stand by everything.
I got my stainless steel header today from Ebait. Looks good, install will tell! Though not mentioned, they incuded gaskets & fasteners!
While her rear is still up in the air I'll start hanging the new pipes!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #40 of 61 Old 05-04-2013, 07:16 PM Thread Starter
PeteNnewburg
A bit of a "day off".
I washed down my work area.
I did get a few of my OE lights polished today, they look like new! I also tried cerium oxide(?) polish for glass on the OE glass fog lights. I used a low speed 3" orbital polisher, kept the lens wet to prevent cracking, it did start getting hot! It did not seem to remove many pits, but after 5 minutes or so I could see that the edges of the deeper pits were being smoothed out. The lens I worked does look brighter.... I'll give them another 15 minutes each then done.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #41 of 61 Old 05-08-2013, 01:14 PM Thread Starter
PeteNnewburg
JY trip!
I finally made it out to the JY today! I picked up a few front signal harnesses, some extra vacuum lines, tee & elbows. I also got a '96 style power steering pump with bracket, fasteners, lines and a nice antenna. $35 for all.
I got the '96 PS pump & brackets to do the 99+ intake & 703 injector swap while I am putting the header and new exhaust on.
I had gotten a front drivers door and rear hatch off a '94 at a different JY, I went back today to get the 2 back doors and rear privacy glass. That ZJ had been crushed so I got just the privacy glass from two other doors as well as the rear glass from a '96. That ZJ had a decent hatch, (it has a dent) but with the flipper rear glass! I paid $100 for all the glass and the hatch.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #42 of 61 Old 05-14-2013, 05:28 PM Thread Starter
PeteNnewburg
Moving up front!
Well, the rear end is off the jack stands! I finished up the CA, Shock, 2" BB, track bar & sway bar link install. I will need to do more cleaning, rust repair and brake work under the rear, but I'm gettn itchy to do the front lift, exhaust/ intake/ injector up grade and suspension work.
I want to sand blast the Parking Brake bracket, replace brake lines and cables, but it can wait till the fun stuff is done!!
PICS COMING!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #43 of 61 Old 05-17-2013, 04:03 AM Thread Starter
PeteNnewburg
Cleaning & Prep
OK, I spent yesterday cleaning the ZJ, I spent a good part of today cleaning again, a lot of it seemed to be on me. However, the control arm replacement front and rear is now done! The LH front was trying to PMO, but 4 sessions of blue wrench followed with PB Blaster, and a 18” extension on my 16” breaker bar… I also replaced the track bar bushing, that was the most time consuming! I really did not want to deal with a broken bolt there! The LH axle bushing was a PITA! I hit the RH axle bushing with some heat and the impact hammer sent the bushing flying!
I hope to finish the 2” BB and shock swap in the AM, exhaust/ intake swap is next!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #44 of 61 Old 05-19-2013, 09:50 PM Thread Starter
PeteNnewburg
Moving along!
My project is moving along. I am doing a bit of a write up for each stage of the process. I am taking pics, but a lot are blurry. I need to use a tripod . I will give a step - by - step process that even I can follow!
The 2" BB, CA replacement, track bar bushing, sway bar bushing/ link is almost done. I just need to re-attach the RH caliper, LH upper shock mount, lower track bar mount and sway bar links. Then it will be "torque" time!
Next on tap - - - '99+ Intake, 703 injector & exhaust upgrade!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #45 of 61 Old 05-20-2013, 08:25 PM Thread Starter
PeteNnewburg
I got everything buttoned up on the BB, torqued to spec and back on the ground today. I kept a log of tools used and will add them to my write up along with the FSM torque specs.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
