94 yj build...too broke to build a workbench - Page 7 - JeepForum.com
post #91 of 376 Old 03-27-2013, 08:47 PM Thread Starter
flashy
Originally Posted by Ripper3494 View Post
some day ill pull my tub off and beef up my frame. im amazed that your doing as much as you are with it
I figured the frame is the foundation and really only wanted to the majority, once....I also tend to overdo things.
flashy is offline
post #92 of 376 Old 03-27-2013, 08:52 PM Thread Starter
flashy
Before you finalize those rear hoops I would check the clearance with a tire flexed. You may run into some clearance problems. A lot of guys end up frenching the shock mount into the frame for that reason. I didn't and my shocks sit less than an inch from my frame and at fill flex my tire is about an inch away as well
Sent from AutoGuide.com App
Just out of curiosity if you have a inch between the frame, how much room is between the shock and the tire at ride height?
flashy is offline
post #93 of 376 Old 03-27-2013, 09:16 PM
Ripper3494
i cant quite fit three fingers between the shock and the tire, but my shock isn't mounted perfectly vertical like yours, mine are angled forward a bit to keep it out of the way of the tire
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #94 of 376 Old 03-28-2013, 02:58 AM Thread Starter
flashy
I was too excited, I couldn't wait!! Here is what I did tonight. I finished the hoop on the drivers side and then did some flex tests to see where I have clearance issues. I really think I will be alright once I get the 11/2" wheel spacers. The guy who helped me with my SYE kit has a junked jeep with them on so I got them for $50. He is supposed to have them off tomorrow.
After that whole pictorial and writeup of how to copy the marks from one hoop to the other and the flippin motor mounts are not exactly across from each other. I cut the hoop and then realized it....good thing I always cut long. I never thought of checking, I guess that's what I get for assuming.
Finally I pulled the fender flares...just to see if they were at all salvageable. And to my surprise they were easily adaptable. I had already trimmed that bottom lip off of them. I took the passenger side one and put it on the drivers side and it it was almost perfect! I trimmed off part of the lip on the back and made a few other relief cuts and within 10 minutes...well you can see how it looks...What do you guys think?
flashy is offline
post #95 of 376 Old 03-28-2013, 03:17 AM Thread Starter
flashy
sorry guys my puter is being stupid and I have to go to bed its 4am. Goodnight and I'll post pics tomorrow. Man, I honestly don't know if I can sleep! I am just so excited that all my planning is actually working out. I have thought many times that this thing my never drive again and if it does it might dog track or something. I really don't have a clue what I am doing. I have built and worked on many things and many vehicles but this is a new one for me. Next maybe Ill tackle that huge project sitting in the corner...the 1974 Honda Z50...it runs, Ive had it for years, saying Ill always restore it someday.
Oh just some numbers for you. I love numbers. Each tire comes off the ground 24" or more before another tire comes off the ground. I checked all four corners. The bottom of skid plate (if I had one, its on the list) went from 9" to 25"! That is significant. The wheel base went from 95 to 102. Give or take a little, I didn't have anyone to hold the other end of the tape.
One thing I never mentioned..When I came up with my build, I built adjustability in it. The wheelbase can be shorten by 6" by turning the leaf springs around and then the perches have the three holes for adjustability. I have mine in the middle. I can make it narrower by 3 inches with the wheel spacers. The height is a little more difficult but I can remove leafs and change shackle lengths.
flashy is offline
post #96 of 376 Old 03-28-2013, 06:40 AM
1hand
Flex monster! Looks great.
I know the feeling, "what have I done" "I wonder what scrap price is" I hope I get to where you are some day, where it could actually roll out of the garage on its own.
Project "Bugout"
1hand is offline
post #97 of 376 Old 03-28-2013, 12:01 PM Thread Starter
flashy
That is such a good feeling....Its so nice to be able to move it back and forth. working on the front...roll it back.
flashy is offline
post #98 of 376 Old 03-28-2013, 12:04 PM Thread Starter
flashy
Still cant post pictures on here...I can on Facebook and I can do everything else. I will figure it out soon.
flashy is offline
post #99 of 376 Old 03-28-2013, 12:11 PM
1hand
I use flickr, pretty easy and you can post what ever size you want. I can help you if you need.
Project "Bugout"
1hand is offline
post #100 of 376 Old 03-28-2013, 02:51 PM Thread Starter
flashy
Just got done talking to Kimmer and he got the spacers off...2 are 2" and the other 2 are 1 1/2" so the 2" will go on the back and will make up for the slightly narrower 8.8 and give more than enough room for the shocks..
flashy is offline
post #101 of 376 Old 03-28-2013, 02:54 PM Thread Starter
flashy
I haven't had problems until last night and it keeps telling me its the Jeep forum that is having the problem...I will try at work and if that doesn't work, then I will try something different!
flashy is offline
post #102 of 376 Old 03-28-2013, 04:22 PM
1hand
That should work nicely.
Project "Bugout"
1hand is offline
post #103 of 376 Old 03-28-2013, 05:08 PM Thread Starter
flashy
Here is the picture of the fender flare.
I didnt do anything in the garage today. My head was cloudy again, I barely made it to work. Maybe after work I will get an hour or two in.
flashy is offline
post #104 of 376 Old 03-28-2013, 08:03 PM Thread Starter
flashy
Does anyone know what D30's have 3.73 gears?
Time and budget build...lots of pics::::
94 YJ slightly modified
00 WJ stock
flashy is offline
post #105 of 376 Old 03-28-2013, 08:09 PM Thread Starter
flashy
I figured it out. I feel dumb. I was posting them to facebook from my phone and then when I was at work I would download them from facebook to my pc. The reason they werent working last night is cause I was trying to upload them right from my phone
00 WJ stock
flashy is offline
