94 yj build...too broke to build a workbench - Page 23 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 94 yj build...too broke to build a workbench
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsSave at JeepHut on Smittybilt Soft tops
Unread 09-02-2013, 07:02 PM   #331
flashy
http://www.driveshaftsuperstore.com/...and_spline.htm
Im putting this in here so when it comes time to make a decision on the front drive shaft I have the link....check them out, seem to be fair priced. Especially if you arent looking to spend $400-$500 on a DS
Time and budget build...lots of pics:::: [url]http://www.jeepforum.com/forum/f12/94-yj-build-too-broke-build-workbench-1499127/[/url]
94 YJ slightly modified
00 WJ stock
flashy is offline   Reply With Quote
Unread 09-07-2013, 12:50 AM   #332
flashy
I finally got my parts!!! I had to make a trip to the JY to get a cap for the reservoir and I ended up picking up an original bracket out of a camanche 2.5L. I trimmed up the bracket and then welded it right to the core support/grill. I also think I have a pretty slick way of hooking up the TPS...I started on the bracket but cant find any bolts to attach the TPS to the bracket so Im stuck on that until the hardware store opens.
I have been working on the shifters, I don't have any pics but I will take one when its all done.
My buddy came over to check out the jeep so I wanted to show off a little so we pulled out the cherry picker and did a flex test on all four corners.
A couple things resulted in this.....I get slight tire rub on the rear shock when the front tire is all the way up and the rear tire is stuffed. Minor rub but it will need to be adjusted.
My drag link hits my passenger side leaf spring when that corner is stretched. If I get a flatter pitman arm it will be alright.
Finally, I don't know what everyone is talking about needing 10 inches of slip because I have reverse shackle.....I can only get 4 inches....the only thing I didn't check was if I have both front tires at full droop. But its getting closer everyday. Tomorrow I am going to the UP to look at house to buy!
00 WJ stock
Unread 09-07-2013, 04:49 PM   #333
'92 vegas YJ
R.I.P. Ratmonkey
'92 vegas YJ's Avatar
Looking great man. Can't wait to see it finished and on the trail.
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
'92 vegas YJ is offline   Reply With Quote
Unread 09-07-2013, 06:31 PM   #334
flashy
That means a lot to me. I have read your build thread many times, I have imitated some of your ideas. Thank you!! I also cant wait!!
00 WJ stock
Unread 09-15-2013, 02:06 PM   #335
flashy
Life got in the way again.....for a while we have been looking for some land to buy so we can park our camper on it and have a little weekend spot. Well we found it. 10miles over the state line in the U.P. MI. 4 acres of Maple Hardwoods with a 4 bedroom house. The pipeline and the highline border the back of my 4 acres, so I can wheel and snowmobile right from my land to the 1000 miles of trails. The bad news is that for the last 3 weeks we having been saving money and working on getting this place....so the Jeep is still sitting there.
I did work work on it a little, ended up trying to cut my thumb off. No Dr, toughed this one out. I had a hard to keep it from bleeding for 3 days.
I did finish the TPS and it has a full range of motion, no chains, I think it will work well.
00 WJ stock
Unread 09-15-2013, 02:09 PM   #336
flashy
here are the pics of the TPS
00 WJ stock
Unread 09-15-2013, 04:19 PM   #337
skyj
Awesome bro my uncle has a place in Iron Mt we would visit almost every weekend when I lived in GB it was fun to just escape my cousin has made quit the trails on their property with his tj.
build thread: http://www.jeepforum.com/forum/f22/skyj-eccentric-build-1467426/ '90 YJ 5.2 magnum MPI, AX15, NP231 SYE, Dana 30 4.56 open/ 8.8 4.56 detriot locker. 1" shackles
skyj is offline   Reply With Quote
Unread 11-24-2013, 07:24 AM   #338
flashy
I just wanted to say SORRY!!! I have been busy. Officially got married, bought a house, switched jobs. Now its time to finish the jeep.
00 WJ stock
Unread 11-24-2013, 09:45 AM   #339
MNmilitaryGUY
Congrats man glad to see you're still workin the jeep.
MNmilitaryGUY is offline   Reply With Quote
Unread 11-24-2013, 10:07 AM   #340
flashy
Its sitting there taunting me!!!
00 WJ stock
Unread 11-24-2013, 10:53 AM   #341
nagel
Originally Posted by flashy View Post
Does everyone who has a red jeep paint them black?
ROFLMAO I think so! My 89 YJ was red and the PO painted it black. They also put a TJ hood on it from a red TJ, and also painted THAT black..
Just had to comment since this I the first I've seen this thread and your comment made me laugh..
nagel is offline   Reply With Quote
Unread 01-08-2014, 08:13 AM   #342
Peety
Looks Great !! Congrats on getting married too...
So many ideas now, need...to...keep...focused...AAAAAARGH
Peety is offline   Reply With Quote
Unread 01-11-2014, 11:00 PM   #343
flashy
Its been a while but I am finally finishing up the Jeep!! I finished wiring the TPS. I put the drag link back on. I bought that Jb 4x4x bracket but I either need heim joints and mis alignment spacers or I need to thin out my leaf pack because it is right in the way. So for today it is back to the stock steering setup. My Drag link is at a horrible angle but at least I can turn the wheels. I also replaced two wheel studs...put the airbox back in. I bought a TJ head pipe and I think I have everything figured out for the exhaust but I am going to take another look at it in the morning and finish it up. Should be driving after that.
I do still have to finish the 4x4 shifting linkage, lengthen the front driveshaft, bolt drivers seat, bolt in all the seatbelts, fit the doors and the top one more time.
00 WJ stock
Unread 01-11-2014, 11:01 PM   #344
flashy
Thanks for taking the time to read through it!!
00 WJ stock
Unread 01-11-2014, 11:02 PM   #345
flashy
Thanks I appreciate it!! Can you believe we are still together!! LOL
00 WJ stock
