94 YJ build - JeepForum.com
post #1 of 34 Old 01-22-2010, 01:13 AM Thread Starter
RedWind
94 YJ build
When I got this jeep all it had was a 3" body lift and thats about all the pros it had going for it. the cons where bald 33x12.5 BFG AT, cracked windshield, shot body bushings, bad rust in 7 places, warped springs, broken zipper on the soft top, no hatch for the hard top, oil leak at the rear main seal and at the valve cover gasket, and they never did a gear swap after they put the larger tires on so had a lose of power.
a couple months I got it I had fixed the oil leak in the rear main seal and the valve cover. I also put on a pair of hella lights I forget the model but I think its 600, and also got new 33x12.5 BFG ATs
This is more recent after I made a mount for my HiLift jack on the hood, installed a Rough Country 4" suspension lift and regeared it with 4.10. I also broke the housing for my light trying to adjust it. a;sp my piston rod snaped and sliced my oil pan in half.
Well now that my jeep has some down time til I get an engine I decided to do some body work
My holes
I started grinding down for the first day
Now I have the entire interior riped out and working on the roll cage right now so I am capable of getting to all the places I need to with the grinder. my planes are to herculine the inside when after the body is taken care of
RedWind is offline
post #2 of 34 Old 01-22-2010, 07:19 AM
thetrashman
hey mannn nice yj!
reminds me alot of my first yj, in fact it was a 94 too!
good luck with the build up/cancer repair!
95' Little Red Yj.
"My Jeep Doesnt Leak, Its Just Marking Its Territory"
Mostly Stock,With A Few Things
thetrashman is offline
post #3 of 34 Old 02-04-2010, 04:32 PM Thread Starter
RedWind
I finally got a chance to take her out and clean her out a bit a couple days ago when it was warm.
Today I got in my floor pan I ordered from quadratec now its just a waiting game on the government so I can buy a welder and an engine
RedWind is offline
post #4 of 34 Old 02-10-2010, 08:41 PM Thread Starter
RedWind
Finally got my money from the government so I went out and bought myself a hobart 140 mig welder and looking for a place around here that sells 18g steel but I went and finished pulling out my motor
it has a small problem
RedWind is offline
post #5 of 34 Old 02-10-2010, 08:50 PM
99XJon
after looking at your pics i would say you might have a small hole in your oil pan. You might be able to get past by putting a little rtv on it for temporary use, but you might want to replace the whole pan with in the next few thousand miles
99XJon is offline
post #6 of 34 Old 03-04-2010, 01:53 AM Thread Starter
RedWind
I got the new engine in finally, it was a ***** to get the tranny to line up
Also get the hole on the front driver side and floor pan patched up
RedWind is offline
post #7 of 34 Old 03-04-2010, 03:29 AM
BeepTheJeep
I want to buy this car....lol
BeepTheJeep is offline
post #8 of 34 Old 03-04-2010, 09:23 PM Thread Starter
RedWind
Did you just call a jeep a car tisk tisk
RedWind is offline
post #9 of 34 Old 03-04-2010, 09:29 PM Thread Starter
RedWind
I got my new exhaust, a magnaflow universal cat and a flowmaster 40 series muffler
The new and old exhaust
also found rust under the door stops so I cleaned them up and sprayed them with rust inhibitor
RedWind is offline
post #10 of 34 Old 03-04-2010, 09:44 PM
Hurley91
Man, I gotta fix the rust on my driverside Jeep stamp out, it is gonna be a ***** to do. Looks like your doing good so far
Hurley91 is offline
post #11 of 34 Old 03-04-2010, 09:57 PM Thread Starter
RedWind
yeah it is but hopefully yours isnt as bad as mine was
My Jeep Build -->
RedWind is offline
post #12 of 34 Old 03-04-2010, 10:04 PM
Hurley91
Its about the same if not a bit worse. But nothing a little blood, sweat and tears can't fix
Hurley91 is offline
post #13 of 34 Old 03-04-2010, 10:10 PM Thread Starter
RedWind
I hear that, good lick trying to find the 18g sheet metal I couldnt and settled for 16g just have it setting back further cause I am going to herculine, no one will know
My Jeep Build -->
RedWind is offline
post #14 of 34 Old 03-07-2010, 07:31 PM Thread Starter
RedWind
got the exhaust welded together yesterday but didn't get any pics before I put it up but I am waiting on my tailpipe to come in before I can fully finish up the exhaust.
I also filled in the holes for the step side I figure they ae kind of pointless with 8 inches of lift on it
and started on patching up the wheel well
My Jeep Build -->
RedWind is offline
post #15 of 34 Old 03-07-2010, 10:11 PM Thread Starter
RedWind
just went out and filled in the holes on the passenger side for the step
My Jeep Build -->
RedWind is offline
The Build! XJWren Jeep Builds 17 07-23-2014 10:27 PM
88 XJ Build up Giviner Jeep Builds 10 09-09-2009 09:20 PM
My TJ Build TellicoTJ Jeep Builds 7 01-08-2009 01:40 AM
my 2.5 build up Sh4dowRac3r Jeep Builds 24 02-13-2008 10:41 PM
