So im starting this thread a little late but i figure better late than never, i bought my 1994 wrangler last 2 years ago around new years and i knew nothing about jeeps, i got a 4 cyl, which to my disappointment didn't do very well on the highway. So after a few blown transmissions and an engine or two my dad and i decided to undertake a complete "do over" of the wrangler
so i got a hard top from a friend in return for a stereo set up but my full steel doors are total **** and they arent even for a wrangler... but i did have a set of half doors so i decided to get some tj uppers and see how i can make it work
here are the upper tj frames from Rampage. ive had issues with their quality stuff in the past but these seem really sturdy, and i dont feel bad cutting them up
and here are the upper windows from smittybuilt (also kind of cheap since i didnt know if this would work) if i end up loving the tj uppers i may buy nicer parts in the future but for now these work
and here is one mounted. they are EXTREMELY tight to get on but thats standard and now i know they wont flap.
you can also see that they they don't sit all the way down on the doors due to the final pin not lining up
here you can see the position of the last pin verses the other pins
and here is how well the tj upper fits in the hard top opening. i did un bolt my hard top and push it back as far as i could then i bolted it back in to make room
ok so here goes the modification, unfortunately i wasn't able to finish tonight because the welder is buried in the other garage since the we are re doing the shop
so first you have to cut the furthest pin back off before the 90 degree bend
and this is how it will be welded back on so that the upper sits correctly
but even without that back pin you can see that it sits nicely in there
this is the only spot that has a gap which is due to the lack of a rear pin
i drove it around anyway though and the doors work great, they are totally silent and dont flap at all. also i cant feel any air coming from anywhere
this is deff near the top of my favorite cheap mod list
and for those curious as to why i have no garage right now
So does that filler hose use the stock filler location? looks like it, does that actually work with out the gas just flowing back out the filler when filling up> i want to do the same thing you did with the fuel cell but dont know what to do about a filler and would like to use the stock filler like it looks like you did. Can you post some more pics of the filler and fuel cell setup?
Ok, I just read through your build thread finally while being bored at work and I have to add my .02. I wish I could swipe the 5.9L V8 out of the '99 Durango I have sitting in my driveway for sale and toss it in my XJ. Your YJ is badass. I'm extremely jealous.
Ok, she's purty and a chick working on a Jeep is sexy. Get more pics of her in this thread either working on the Jeep or posing in, on, or under it. :2thumbsup:
Yea the cloaks were really just a fad, an expensive one of at that. I liked em while I had em but I feel much better about building my own stuff. Imo the cloaks make a rig look like your spending all your money trying to make it look good
I really liked the look of the metal cloaks on there....and still like the style, but making **** yourself is cooler, more satisfying, and way cheaper. I have bent tube from jeeptubes.com that I'll be welding up to make my tube fenders. Need more welding practice first though.
again..... more of this in your thread. Especially after it warms up. :cheers2:
I need to do the durango box upgrade too. Did you pick yours up locally or online somewhere? About how much? I have some play in my steering and thought it was the steering shaft, but might be the box. I need someone to help me locate the issue. Hard to do yourself while sitting behind the wheel. It's ridiculous that you can't replace the u-joint in the steering shaft and the borgensen heavy duty shafts are a bit too steep for me
and i started it up today because i just wanted to hear it... i love the way it sounds right now, once i have the gears all done ill have to take another running vid. next weekend me and a few buddies are headin out to the cliffs so ill deffinately have some shots of that
well i decided to get started on the gears since i was supposed to look at a guys car tonight but he never showed. first problem was getting the old carrier bearings off the carrier... i invented a new tool that included a clamshell type puller 2 bolts 2 nuts, a piece of square tubing from an old transfer case drop, 3 feet of threaded rod, plasma cutter, welder, impact wrench and a vice.
also had the issue that the rubi 5.13 thick cut gears use a 7/16th ring gear bolt and my carrier used a 3/8th i believe so i had to drill out 10 holes on each carrier to 7/16th and go to 3 different ace hardware stores to find 20 grade 8 7/16-20 bolts...
so today i had no school and my dad took off work so we decided to do gears. after spending like 2 hours trying to hone out the old bearings to make the setup bearings we remembered that our little lathe would work well so that was nice.
heres some pics... i didnt really like taking pics so after the first time taking the carrier in and out we kinda stopped with pics (carrier was taken in and out of each axle ~9 times)
after getting everything within spec we pressed on the real bearings and put it all back together. once together we found that we had 0 backlash. backlash needs to be between .006" and .010" so i pulled the new bearings off and we adjusted the shims and pressed them back on. all said and done the front axle has .007 backlash and the rear has .010 (which neither of us really liked being right on the edge but we had been working for 12 hours straight so we said good enough)
almost finished buttoning it up tonight but i need some seals so ill be finishing up tomorrow.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
