93 yj wrangler build - Page 2 - JeepForum.com
post #16 of 43 Old 03-20-2012, 07:00 PM Thread Starter
frankul2003
good day of sandblasting and priming .. windshield frame is ****...
frankul2003 is offline
post #17 of 43 Old 03-23-2012, 10:19 PM Thread Starter
frankul2003
here are some up to date from 3/23/12 pics .. paint coming soon....
post #18 of 43 Old 03-24-2012, 10:02 AM
KLiK3xs
looking good!
no need for the door lock I see.... just jump right in!
Kim
KLiK3xs is offline
post #19 of 43 Old 03-24-2012, 10:20 AM Thread Starter
frankul2003
the door handles and locks and pretty much every other hinge were rusty so i just hit all of them with a sandblaster and hit them with primer... waiting on some final sanding and good weather.. soon.. hopefully by 2nd week in april if all goes well... im just waiting on my keith black .30 pistons from summit then tearing down the 4.0 and getting it bored and installing my stroker setup.... the weather here has been amazing since march.. 20 out of 24 days have been 60+....
post #20 of 43 Old 03-26-2012, 06:43 PM Thread Starter
frankul2003
well .. weather changed ahhhhhh.... 45-55 degrees for the next 2 weeks man says.. puts a big hold on my painting... i knew it was going to happen... i rushed and rushed to get it painted and then after the weekend its raining and 48 degrees out.... shibby.....well maybe some engine work in process this week .. all depends on my pistons coming in ....
post #21 of 43 Old 03-26-2012, 06:50 PM
DNFJ
WANNABE DESERT RAT
DNFJ's Avatar
Awesome! Where in PA are you?
'00 XJ Locked on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline
post #22 of 43 Old 03-26-2012, 07:33 PM
mike_breaker_5
i'm into any yj resto. speak up if you need parts. i have a few laying around from my v-8 swap. and that includes a sub 100k mile 4.0l ho that was in my 94 prior to the swap. bell housing i think i have mostly a complete np231 (all it needs is a rear case half (it esploded when the rear pinion u-joint went bye bye). and a few other hard parts.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #23 of 43 Old 03-26-2012, 08:38 PM Thread Starter
frankul2003
philipsburg pa about 20 miles from state college
post #24 of 43 Old 03-27-2012, 06:58 AM
mike_breaker_5
you are just over an hour drive from my doorstep. definitely post up if you need parts.
post #25 of 43 Old 03-27-2012, 07:42 AM
1997YoungJeeper
great work man
1997YoungJeeper is offline
post #26 of 43 Old 04-24-2012, 09:05 AM Thread Starter
frankul2003
well... its april 24.... still not painted.... but.. good news is the engine has been removed bored.030, head machine work done... new KB pistons pressed on 4.2 rods.. 4.2 crank cleaned up polished... engine put together... engine installed back into jeep... started up runs good... had a fuel leak from the rubber hose that goes to the tank tightened up the clamp on it... still doesnt have any miles on the new rebuild since no paint... started working on the soft top.. installing 06 sunrider top on my 93 .. fun stuff.. gonna work nice.... after looking at my radiator went to summit racing and got a new aluminum one installed that.. got two new rancho shocks for the rear.... also bought dc-2 wheels for it...... this weekend ill work on the top and just hope for good weather so it can be painted and i can finally drive it...
post #27 of 43 Old 05-16-2012, 12:11 PM Thread Starter
frankul2003
finished,,,, semi....
post #28 of 43 Old 05-16-2012, 12:12 PM Thread Starter
frankul2003
another
post #29 of 43 Old 05-16-2012, 12:14 PM Thread Starter
frankul2003
painted.... blew the belt off.. master cylinder junk.... front calipers locked up....... awesome day.... shakes like a *****.... smells bad .... smoking.... fresh rebuild rings still not seated or something... cat catalyst bust in pipe rattling.... awesome..time... going broke replacing things ..lol... jeep...
post #30 of 43 Old 06-06-2012, 11:37 AM Thread Starter
frankul2003
ta da........ stickers here...
wrangler cj7 build clemmotors Jeep Builds 0 08-30-2011 10:22 PM
My 97' Wrangler Build TJsRedTJ Jeep Builds 8 08-27-2011 05:59 AM
97 Wrangler build Battle9200 Jeep Builds 84 07-05-2011 03:10 PM
97 wrangler build shawnconboy Jeep Builds 2 05-23-2011 10:27 PM
97 Wrangler Build up rrmckinney Jeep Builds 3 02-15-2011 06:55 PM
