93' Jeep YJ build...LS3, linked with ORI's and Currie D60's. - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 93' Jeep YJ build...LS3, linked with ORI's and Currie D60's.
Jeep Wrangler Wheel Bearing & Hub - FrontJeep Grand Cherokee Window RegulatorComponent speaker deal for your dash - NalinMFG
Unread 08-08-2013, 11:09 PM   #1
DLWRUBI
Just thought I would go ahead and start a build thread. I think it's something a little different than norm so hopefully others will find it interesting or helpful in their builds. I'm no expert so I will be learning as I go here but have a decent understanding of what I need to do.
So on with the build. I'm starting off with a 93 YJ of which I have owned for 18 years and has about 111K miles. It's exceptionally clean already so no major repair type work needed. The Plan is to do an LS3/4L60E/Atlas swap, link it front and rear, Use ORI air struts, and do Currie D60's front and rear with 37's. Will be temporarily using 35's initially (maybe) though since I bought them already when I had a different plan.
Here is how it stood before I started with an RE 4.5" lift and 33's. Unfortunately, as soon as I was done doing this, I changed my mind.
I Have all the major parts already in the garage with exception of the rear end which I have a full floater ordered up and should be here in a month.
DLWRUBI is offline   Reply With Quote
Unread 08-08-2013, 11:12 PM   #2
DLWRUBI
On with the progress. Out comes the stock motor/trans/TC.
Unread 08-08-2013, 11:13 PM   #3
DLWRUBI
Got the front fenders and all the junk out.
Motor mount and shock brackets are cut off.
Unread 08-08-2013, 11:16 PM   #4
DLWRUBI
Motor mounts burned in.
Motor/trans/TC ready to go.
Motor is in. Will be working on the custom trans mount soon.
Unread 08-08-2013, 11:18 PM   #5
DLWRUBI
Made room in the garage where it will be spending some time.
Made some progress on the trans cross brace. Had to use square 1.5"x 1/4" wall tubing and do pie cuts for the bends. Just not enough space for the universal kit I bought since I have the super duper short trans to atlas adapter. Just have to notch the ends and weld in the sleeved bushing kit I got from ruff stuff.
Unread 08-08-2013, 11:22 PM   #6
DLWRUBI
Today I went from this.
To this...Pulled all the D30 front out, steering springs, etc. and cut the last 2 brackets off.
Time to start prepping and installing the 3 link for the front.
I can see I will have some challenges with the exhaust and upper control arm.
Was hoping to put the upper control arm on the driver side on top of differential but looks like the alternator will be in the way...Plan B.
Unread 08-08-2013, 11:33 PM   #7
AmmitOsiris
What are you doing with the d30?
AmmitOsiris is offline   Reply With Quote
Unread 08-08-2013, 11:42 PM   #8
DLWRUBI
Don't know yet. I doubt anyone will want to pay half of what I put into it, so might find another YJ and put the D30 and 8.8 in that.
Unread 08-08-2013, 11:54 PM   #9
AmmitOsiris
Ahh smart move
Unread 08-09-2013, 12:02 AM   #10
Joe Dillard
Electric Chair Operator
Sweet build!
As you know, I recently finished putting a new RJ D60 & mid arm 3/4link in a friends Jeep LJ. The rear already had a RJD60. We finished another mid arm 3/4 link on another LJ today. It had a Rubi 44 up front, RJD60 rear.
We had some exhaust challenges as well on both rigs - nothing that a sawzall & some creativity couldn't overcome. We used & tweeked a custom truss on the front differentials of both of them for the front upper.
We needed to clearance the bottom of the driver side motor mount on both rigs so that we could get the desired up travel we wanted to get. The engine skid braces on both LJ's needed to get some tweeking too, but they both came out real nice too.
Joe Dillard is offline   Reply With Quote
Unread 08-09-2013, 03:37 AM   #11
AZdEvilYJ
Garage Junkie
AZdEvilYJ's Avatar
Ah the day has finally came!! Dreams do come true! sub'd for this jeep porn...
'95 YJ 2.5L
March '13 & '14 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
http://www.jeepforum.com/forum/f22/a...nally-1575209/
AZdEvilYJ is online now   Reply With Quote
Unread 08-09-2013, 08:49 AM   #12
jrhdpaintball
very clean
jrhdpaintball is offline   Reply With Quote
Unread 08-09-2013, 09:28 AM   #13
Randonexplosion
Trailer Queen
Randonexplosion's Avatar
Awesome. Can't wait to see more...
5.3/4l60e swap
August YJOTM
Exiled Offroad - Colorado
Randonexplosion is online now   Reply With Quote
Unread 08-09-2013, 10:43 AM   #14
jagular7
Is there build history on the leafer setup? I'd be interested in the reverse shackle and ubolt flip setup info.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline   Reply With Quote
Unread 08-09-2013, 11:42 AM   #15
DLWRUBI
Sweet build!
Good info Joe.
I have this nice little bracket from Gen Right that would have been nice to use on the currie diff fro upper CA. I took some measurements and with the frame bottom set at 30.5" and the D60 set at 17.5" centered, I only have about 6.5" before the D60 gets into the engine block. Now, I haven't stretched the front yet since I don't how far I can go until I get the steering and trac bar on it, but if I can go 2" then I gain about another 1" in that clearance. I may have to relocate the alt if I decide to do upper CA on Diff. if that is even possible.
BTW, what do you normally set your up travel for? I'm thinking 6" up and 8" droop for the ORI's. Mainly because minimum for ORI is 5.5" up.
The exhaust I get to do from scratch, just have to make sure there is a route for it to go without hitting something during flex.
