93 Iowa YJ multi stage restore - JeepForum.com
post #1 of 168 Old 09-16-2014, 02:29 PM Thread Starter
IA93Javert
So the long and short of it is on of my best buddies bought a two year old jeep in 1995. His wife and him used it for quite awhile. Then his two boys had it through high school. The last stopped beating on it... I mean graduated in 2009 so it hasn't seen a ton of use since then and enjoying life in the barn. We dragged it out of the barn with the tractor about a month ago due to a blown wheel cylinder. I replaced it in his driveway and drove it the 25 miles home with the calipers and other rear wheel randomly locking up. It is my first jeep and I am hooked. I thought that best thing to do was start throwing money via parts at the problem. My last project was 49 Ford moved to an 85 Monte Carlo frame so while not a novice I was about to start a new experience. I am not looking to do a lot other than original replacement parts so I though that might help some folks and me with my sanity to show myself progress. So here is the list.
Radiator
Water pump
Inlet and thermostat
Shocks (originals in place currently)
Remove Track bars (so it rides more like a deuce and a half than a tank)
New front brakes (pads, rotors, calipers)
Radio (current doesn't work and one blown front speaker)
Replace or rebuild from drive shaft
Posi-lok (replace vacuum system 4WD)
Seatbelts (currently locked fully out)
Bushing Kit (and lots of new bolts...)
Spare tire
Seats
SYE
Replacement soft top
Hard top
Full steel doors
Frame of fenders and tub rust fix and repaint
Restore the frame and seal with undercoat
IA93Javert is offline
post #2 of 168 Old 09-18-2014, 07:11 AM
responder
Sounds like a typical YJ, you know, rust and all!!
Going to be a fun project for you, let's see some pictures of that YJ
responder is offline
post #3 of 168 Old 09-18-2014, 06:20 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
I am about an hour down the road from you. Just wondering if you have hooked up with cedar valley jeep owners? Alot of great people in that group.
I heard you mention rebuilding the axles in other thread. Please dont spend a dime on the dana 35. Run it till it grenades or grab an 8.8 from explorer, or a dana 44 if you can find. The 30 up front is a good axle FWIW. I will be more than happy to help guide you along with the jeep. Is it roadworthy? Saturday/sunday is the Iowa jeep show and a bunch of us are heading up there. Nevada IA. If she will run that far we are leaving Cedar rapids at 8am from the target on 30. Let me know.
Dan
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #4 of 168 Old 09-19-2014, 05:12 PM Thread Starter
IA93Javert
So we start with this...
post #5 of 168 Old 09-19-2014, 05:13 PM Thread Starter
IA93Javert
Discovered an issue with the radiator mount that is supposed to be spot welded to the brackets...
post #6 of 168 Old 09-19-2014, 05:19 PM Thread Starter
IA93Javert
Got radiator in but still had a coolant leak. Traced it to the water pump and the inlet both leaking. So off they came... make sure to put cardboard between the fan and the radiator so you don't ding up your brand new radiator... and no you can't be careful enough..
post #7 of 168 Old 09-19-2014, 05:21 PM Thread Starter
IA93Javert
Took longer to get the old gasket off then the parts. I plugged the holes up and bought a wire wheel attachment for the Dremmel for $5 and it went much faster after the big chunks were gone. Next new parts on.
post #8 of 168 Old 09-19-2014, 05:24 PM Thread Starter
IA93Javert
Figured I should replace the leaky valve cover since I had all this open real estate.. AND you need to be able to tell when it leaks again sooo... with a little paint and some clean up..
post #9 of 168 Old 09-19-2014, 05:27 PM Thread Starter
IA93Javert
That was the second weekend of owning the jeep. I also changed out the tranny fluid since I was having some shifting issues with 3rd gear. It was gear lube and very gray. I used Rottella T5 and it is working much better.
post #10 of 168 Old 09-19-2014, 05:31 PM Thread Starter
IA93Javert
Btw this used to be my daily driver and I put it up for sale and the jeep is my daily driver now. So I guess you could say I am hooked... So this all was about three weeks ago.
post #11 of 168 Old 09-19-2014, 05:37 PM Thread Starter
IA93Javert
Now the big part of the project has begun. Got most of my parts by last Friday... Shock,Rotors, pads, Calipers, track bar removal, new front drive shaft, posi lok to replace the vacuum and all fluids except coolant, new stereo, and Thor speaker boxes.
post #12 of 168 Old 09-19-2014, 05:40 PM Thread Starter
IA93Javert
Last Saturday morning into the work shop we go..
post #13 of 168 Old 09-19-2014, 05:43 PM Thread Starter
IA93Javert
Learned some valuable lessons on day one. First and foremost twenty year old wheel locks SUCK!!! Broke two different "keys" and spent two days off on trying to get it off. Finally go my hands on a lug out tool that would fit the damn thing and it came off Tuesday night. Second, when removing track bars I knew that a sawsall was required. I would add angle grinder to that list..
post #14 of 168 Old 09-22-2014, 09:54 PM
mike134
Nice upgrade! Although we are all biased towards wranglers, your old DD looks like a fine utilitarian car but sooooo boring.
Do you think you gave it up a bit too early though? Hopefully all the rest of your upgrades will be single day jobs!
mike134 is offline
post #15 of 168 Old 09-25-2014, 08:57 PM Thread Starter
IA93Javert
Exactly. This is much more fun. And I don't need to use my MIS degree to figure out whats wrong.
