92 yj build - Page 9 - JeepForum.com
post #121 of 607 Old 11-17-2008, 12:23 AM Thread Starter
bigsquat
Originally Posted by snkwired View Post
LOL yes well i am already to far in debt on the CC's. do you happen to have the dimentions for your rear shock mount bracket you made?
no , but i could crawl under there tommorro and take a few.I just winged it and used stuff i had laying around. You will need some square tube , eyes from an old shock,and a little 1/4 flat bar, and some 1/2" hardware
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #122 of 607 Old 11-17-2008, 12:49 AM
snkwired
looks like you welded nuts on to the back of the smaller brackets, is that right? so it is just solely supported by the original shock mounts
snkwired is offline
post #123 of 607 Old 11-17-2008, 08:54 AM Thread Starter
bigsquat
that is correct. I did get some air over the top of some dunes in pismo and it held up fine
bigsquat is offline
post #124 of 607 Old 11-17-2008, 05:04 PM Thread Starter
bigsquat
help! What did i do wrong? I took the jeep down the freeway today and i had some bad vibrations out of the rear drive shaft. I pulled over and i couldn't understand why my rear pinion angle was now way off? The welds didn't break, and when i set it up i was real careful. Instead of angling down 2 * it now is up about 3-4* ? Did my springs settle into a new position. I had full weight on it when i did it. The rear yoke straps are stretched and the yoke is damaged. I'm lucky to make it home. To top that off my ignition sw or something went out and i had to jump across the solenoid to get it started.
bigsquat is offline
post #125 of 607 Old 11-17-2008, 06:41 PM
snkwired
well you took out my first thought of making sure full weight was on it. Hmm
snkwired is offline
post #126 of 607 Old 11-17-2008, 07:06 PM Thread Starter
bigsquat
im not going to cut the welds just yet. Im thinking of changing the shackles in the rear to 5" instead of 6", then add shims if needed
bigsquat is offline
post #127 of 607 Old 11-18-2008, 10:16 AM Thread Starter
bigsquat
anybody with some thoughts on this?
bigsquat is offline
post #128 of 607 Old 11-18-2008, 10:57 AM
champelite210
I would say your axle tubes spun. This is probably why the rtv was tore on the inside of the axle and the leaking of fluid out of the tubes.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #129 of 607 Old 11-18-2008, 11:16 AM Thread Starter
bigsquat
thanks i didnt think of that, that would be a good explanation, i was going to weld them like on the 8.8 people do , but i thought the 44's where ok in that area.
bigsquat is offline
post #130 of 607 Old 11-18-2008, 08:25 PM Thread Starter
bigsquat
I looked at the pumpkin and it didn't spin. I'm a little baffled as to why my drive shaft angle is off.
The nose of the rear end must be really moving a lot under load and i don't know why. The u joint to rear end yoke straps were all stretched out and that was letting the drive shaft flop around a little. The yoke apparently moves up so much that the little 5/16 bolt heads got tore up when hitting the drive shaft yoke.
i should wire up a video camera under there so i can see it under load.
I put new straps on and added some shims on the leaf springs and it helped a little. I still think I'm cutting down the shackles one inch to help the angle. ill only lose a !/2" of lift
While i was at it i welded the pumpkin any way
bigsquat is offline
post #131 of 607 Old 11-19-2008, 08:49 PM Thread Starter
bigsquat
I took a little brake from the jeep this morning and went fishing at loon lake ,which just happens to be at one of the entrances to the Rubicon trail. The jeep is almost ready to tackle the trail. I think ill try out an easier trail first. Caught a limit by noon and went home and changed the rear 6" shackles to a set of 5". It angled the nose done a lot. i test drove it and i think its going to work. I might lower the front to. I didn't notice any driving control difference . I still think i get lot of axle wrap up under load, which i don't know how to prevent. Anybody with ideas?
bigsquat is offline
post #132 of 607 Old 11-21-2008, 06:28 AM
richmond1273
well since your sua you shouldn't really need to worry about axle wrap, even if that was it it usually returns back to normal unless you bent the springs. you could make an anti-wrap bar but i can't say i have seen one on a sua jeep. u-bolts all still nice and tight? where the springs new and just settled a lot? i don't know, just talking out loud, this is a good one. i got tired of those straps messing up so i replaced them with the u bolt style, all you have to do is drill out the holes in your yoke. part # pcn-534-10 from summit, $6.
1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears
3" Rough Country suspension 33x12.50 Mastercraft MT
2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears
richmond1273 is offline
post #133 of 607 Old 11-21-2008, 07:46 AM
treky67
Hey where did you get the sleves for invert your tie rods? P.S great looking jeep. Thanks.
treky67 is offline
post #134 of 607 Old 11-21-2008, 10:04 AM Thread Starter
bigsquat
Im really thinking that the axle wrap is the problem, I got the nose down of the yoke and under full load in first it still starts to vibrate but not as bad as before. The bolt heads arnt hitting any more. Maybe if i had used the longer perches it would of helped. I used the shorter one from the don-er 44.I was afraid the longer one would flatten the springs to much but i think they might of been the way to go.
any pics of a anti wrap bar?
Thanks to the part# , i was was going to do a search for some of those today, good timing.
bigsquat is offline
post #135 of 607 Old 11-21-2008, 10:18 AM
bradyman1
Are those perches welded on to the axle?
Jason
Originally Posted by BLS33 View Post
I find that my hobby of strangling people to death really collides with my hobby of not being in prison.
Originally Posted by duayne77 View Post
I beat my dog every chance I can get, and you know what, I enjoy it.
bradyman1 is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
