92 yj build - Page 8 - JeepForum.com
post #106 of 607 Old 11-04-2008, 07:32 PM Thread Starter
bigsquat
thanks,i spent 30 years bending 1/2 to 4" pipe as an electrician so it wasnt that hard. the bender isnt as good as im use to. It tends to kink the pipe. I only took 3 trys to get two good bends. I had the outer rollers to close on the first attempt. For the price of the bender it works just fine.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #107 of 607 Old 11-06-2008, 08:53 PM Thread Starter
bigsquat
Today I made a temporary mount for the jack, wired the Motor home for electric brakes,and crammed the jeep on the trailer. At first it wouldn't fit, but a little throttle in low and it did go. its so tight i probably didn't need to strap it down.
92 jeep day before pismo 003.jpg   92 jeep day before pismo 005.jpg   92 jeep day before pismo 004.jpg   92 jeep day before pismo 002.jpg
bigsquat is offline
post #108 of 607 Old 11-07-2008, 07:42 AM
richmond1273
front bumper looks great, keep us updated
1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears
3" Rough Country suspension 33x12.50 Mastercraft MT
2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears
richmond1273 is offline
post #109 of 607 Old 11-09-2008, 09:08 PM Thread Starter
bigsquat
Back from pismo, Its a long drive but it was fun. All the people who were supposed to go with me, or should i say they invited me to go with them ,all were no shows! My son and i had a great time anyway. Pulled down the beach about 5 miles and tried to park as close to the ocean without having high tide swamp us. I ended up 5feet to close, whoops! The jeep did great and didnt break down. The fenders rubbed a little under full power when hitting the bottom of the dunes. There were a ton of landcruisers and i wish i had gotten picks of them launching through the air,trying to out do each other.
92 jeep  pismo 003.jpg   92 jeep  pismo 001.jpg   92 jeep  pismo 013.jpg   92 jeep  pismo 015.jpg   92 jeep  pismo 014.jpg
bigsquat is offline
post #110 of 607 Old 11-09-2008, 09:24 PM Thread Starter
bigsquat
more pictures , i didnt take enough.
bigsquat is offline
post #111 of 607 Old 11-09-2008, 10:59 PM
johnnyfitz14
sweet jeep!!!
johnnyfitz14 is offline
post #112 of 607 Old 11-14-2008, 07:17 PM Thread Starter
bigsquat
Originally Posted by johnnyfitz14 View Post
sweet jeep!!!
thanks johnny,
Today i used the jeep to do a little work behind my house, I had a tree fall last year and after i cut into rounds i couldnt get the big ones up the hill with my riding mower. The jeep pulled them up no problem, maybe i can attach a mower deck to it and have another excuse to drive it . while i was back ther i found a rock to climb.
92 jeep fire wood 003.jpg   92 jeep fire wood 015.jpg   92 jeep fire wood 011.jpg   92 jeep fire wood 008.jpg
bigsquat is offline
post #113 of 607 Old 11-16-2008, 05:10 PM Thread Starter
bigsquat
After i put the hard top on i had all lot of air noise comming from where the hard top meets the windshield. it had a foam wheatherstrip on it already. I didnt want to take the top back off and add a different strip so i just stuffed some backer rod used for caulking bid gaps and it worked perfect.
bigsquat is offline
post #114 of 607 Old 11-16-2008, 05:23 PM
justanotherhemi
Great looking Jeep my friend.
l _____
/l ,[____],
l---L []lllllll[]-
()_)-()_)--o-)_)
justanotherhemi is offline
post #115 of 607 Old 11-16-2008, 06:19 PM Thread Starter
bigsquat
thanks , I still have a lot to do:
Paint
rock sliders
cb
air comp
rear bumper/rack
lighting
sterio/speakers
winch
longer front drive shaft
teralow
storage compartments
more cash would help
any thoughts on air tanks and where to mount for the budget minded?
bigsquat is offline
post #116 of 607 Old 11-16-2008, 07:53 PM
scaffoldman
Great idea
I hope you do not mind, I am going to steal your idea for mounting your hi lift jack. I like it.
scaffoldman is offline
post #117 of 607 Old 11-16-2008, 08:32 PM
snkwired
Originally Posted by bigsquat View Post
Well i finally think i have most of the parts and tools to start upgrading the yj. The plan is to change the gearing from 3.54 to 4.10,add aussies front and back.,replace the dana 35 with a 44,slipyoke eliminator,home made posilock,Add another 2" off lift to the existing 4" lift with 6" booms and lowering the spring perches 2".Also going to install a hand throttle,replace the dana 30 wheel joints ,use a cut down front driveline from a xj for the rear of the yj.i need to repaint at least the right front fender or maybe the whole jeep.Ill try to post pics as i go.
man do i need some money. glad to see you plan everything out instead if jumping in and going broke half way done.
snkwired is offline
post #118 of 607 Old 11-16-2008, 08:53 PM Thread Starter
bigsquat
the high lift was mounted using 1/2" threaded rod and some nuts and washers. I only had 1 wingnut so i made one from a u-joint strap welded to a 1/2" nut. the threaded rod comes in 10' lengths and comes in handy to have for projects. make sure you use a torch to help when bending the rod, it will not work good otherwise. Under the plastic jeep cover there is to 1/2" threaded holes just waiting to be used for this set up. I used a uni-bit to cut the plastic. Ill have to change it up when i get a winch.
bigsquat is offline
post #119 of 607 Old 11-16-2008, 08:56 PM Thread Starter
bigsquat
Thats what credit cards are for!
bigsquat is offline
post #120 of 607 Old 11-17-2008, 12:12 AM
snkwired
LOL yes well i am already to far in debt on the CC's. do you happen to have the dimentions for your rear shock mount bracket you made?
snkwired is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
