92 yj build - Page 7 - JeepForum.com
post #91 of 607 Old 10-29-2008, 09:41 AM
culli2799
great work
culli2799 is offline
post #92 of 607 Old 10-29-2008, 10:10 AM Thread Starter
bigsquat
Originally Posted by culli2799 View Post
great work
thanks and welcome to the forum
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #93 of 607 Old 10-29-2008, 10:32 AM Thread Starter
bigsquat
will it looks to be another sunny day in california,(i saw it snowing back east on the news today, hee hee,) To drive this thing all i have to do is install the drivelines and bleed the rear brakes. I still need to paint the fender and door, install hand throttle, make some sliders, etc, but they can wait. the new rear cv shaft does seem small but it came wth the donner veh so it will work for now. Ill upgrade later and kep this one as a trail spare.
bigsquat is offline
post #94 of 607 Old 10-29-2008, 12:57 PM
01blackws6
Dude this is an awesome build I hope I find a deal on a jeep pretty soon I need one!!!. Why don't you upload the pics to photobucket.com so you can show them on the thread
01blackws6 is offline
post #95 of 607 Old 10-29-2008, 05:16 PM Thread Starter
bigsquat
Thanks, the pics use to come up i thought, mybe something has changed. i did sign up for photo bucket but never used it. when i would want a pic i would just clip on the attachments and down load from my comp pic file. so how do i use photo bucket?
bigsquat is offline
post #96 of 607 Old 10-29-2008, 05:55 PM Thread Starter
bigsquat
I test drove the jeep today. It has a pretty bad bumpsteer. Ill have to address that soon . ill try using photo bucket to show the near finished project.
bigsquat is offline
post #97 of 607 Old 10-29-2008, 06:24 PM Thread Starter
bigsquat
there is a trail a mile from me and it has a spot that drops in and out of a small ravine. Before i upgraded everything one of my front and the oppissite real wheel would spin, and id have to make 3 attempts to get out. now i just idled rite up and out , what a difference! The bad is if i put it in 4X4 with out posilocing the front diff it almost does a left turn when i gas it.Thats because the assuie is locking up the left wheel and the rite is just rolling free.ITs fine When both are locked in. I thought i could drive it around safly in 2 low but not the case. if i had an open front diff i guess it would work.The ride is a lot softer now to,Must have something to do with the 6" shackels?
bigsquat is offline
post #98 of 607 Old 10-30-2008, 02:21 PM
richmond1273
by extending your fixed mount for the springs on the front did that mess with you caster angle any? i guess adding the longer shackles could have offset that though. just thought i'd ask.
1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears
3" Rough Country suspension 33x12.50 Mastercraft MT
2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears
richmond1273 is offline
post #99 of 607 Old 10-30-2008, 10:24 PM Thread Starter
bigsquat
The caster stayed the same. Thats the advantage of doing it that way, but time will tell if it puts to much stress on the frame? I only drove it once and at first was discourged. Im hopefull that the tie rod flip will correct it. I have to drill out the tapered holes in the knockle to 3/4" and put in the new inserts so the taper is on the top of the knuckle. then flip the tie rod to the top.It looks like ill have to drill out the tie rod where the drag link connects and the stering stablizer. so i need 4 inserts. the inserts are $9 each, if you dont have a 3/4 drill bit its another $38. If this doesnt correct it then i can get a high steer Knuckle for a little under $400 ,yikes!
bigsquat is offline
post #100 of 607 Old 10-31-2008, 09:51 PM Thread Starter
bigsquat
The 3/4 bit was to big ,If anbody does the inserts do a test hole on some scrape metal and try the insert first ( must be a tight fit)
I pounded in the inserts, cut some metal off the track bar lower support to clear the tie rod and stering stabelizer. I then put grade 8 washers under the nuts per scotty 4x4.
I did a test drive and it worked great, no more bump steer!
92 jeep tie rod flip 001.jpg   92 jeep tie rod flip 002.jpg   92 jeep tie rod flip 005.jpg   92 jeep tie rod flip 009.jpg   92 jeep tie rod flip 010.jpg
bigsquat is offline
post #101 of 607 Old 11-01-2008, 03:06 PM Thread Starter
bigsquat
I put the hard top on just in time. It started raining as i was bolting down. I hope it quits by Thursday for the pismo trip. I have two diff color doors . the black doesnt look to bad but ill have to match the red on sooner or later.The door came off a 89 but it fit ok. It was bare so i had to get a mirror, door handle window crank from 4wheelparts supply. I temporarily made a inside door panel out of some paneling .
bigsquat is offline
post #102 of 607 Old 11-03-2008, 09:20 PM Thread Starter
bigsquat
Today i put the hand throttle in. It was pretty easy. I did go with a piece of chain from the end of the cable to the throttle lever. When i went str8 to the lever without it the cable i didn't like the way it bent back when i used the foot pedal.It also had a tendency to push the cable sheath out of the adjuster.
I started to work on the front bumper. I'm going to cut it down, add some recovery shackles , and a winch plate,and some kind of a bar above the bumper
92 jeep hand throttle 002.jpg   92 jeep hand throttle 001.jpg   92 jeep front bumper 001.jpg   92 jeep front bumper 004.jpg   92 jeep front bumper 005.jpg
bigsquat is offline
post #103 of 607 Old 11-04-2008, 07:35 PM Thread Starter
bigsquat
I finished the front bumper and got it mountrd up, It came out pretty good , but im sure thats a matter of opinion. I just cant see blowing a few hundred on a bumper. the stock bumper seems stout enough if you add some support.
I cut it down , boxed it in , bent a hoop,and welded it up
92 jeep front bumper 008.jpg   92 jeep front bumper 009.jpg   92 jeep front bumper 010.jpg   92 jeep front bumper 011.jpg   92 jeep front bumper 012.jpg
bigsquat is offline
post #104 of 607 Old 11-04-2008, 08:16 PM Thread Starter
bigsquat
here some more pics, it was getting dark so some of the pics wern't so good.
I still have to make a winch plate.
92 jeep front bumper 013.jpg   92 jeep front bumper 014.jpg   92 jeep front bumper 015.jpg   92 jeep front bumper 018.jpg
bigsquat is offline
post #105 of 607 Old 11-04-2008, 08:23 PM
SleddinJeeper
Very impressive!!!! I never thought about doing that to a stock front bumper. Also impressed that you made such a nice bar using the Harbor Freight bender!
1995 Rio Grande, 4in ProComp suspension lift, 2in BL, 35in All Terrains on 15x10 Street Locks, NHOR front bumper with stinger, NHOR rear stinger/tire carrier, NHOR rock sliders
SleddinJeeper is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 10:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 11:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
