92 yj build - Page 6 - JeepForum.com
post #76 of 607 Old 10-24-2008, 04:20 PM Thread Starter
bigsquat
I will have to raise the jeep a lot higher to get the wheels back on. I sure wish i had a lift. Maybe some bigger logs. I was a little afraid of using the rounds but its way more sturdy than jack stands.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #77 of 607 Old 10-24-2008, 10:09 PM Thread Starter
bigsquat
Here are some pics of the muffler swop and shock location
92jeep muffler 006.jpg   92jeep muffler 007.jpg   92jeep muffler 008.jpg   92jeep muffler 009.jpg   92jeep muffler 011.jpg
bigsquat is offline
post #78 of 607 Old 10-24-2008, 10:14 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Nice going! You're really getting a LOT of work done.
I wish I could get myself motivated to get some of my ideas in action.....
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #79 of 607 Old 10-24-2008, 10:26 PM Thread Starter
bigsquat
Thanks Max, tommoro the wheels go on and i can get the rear driveline cut down. I checked the front driveline and it wont require any modes , or to the skid plate. I thought for sure I was going to have to cut a notch in the skid .
bigsquat is offline
post #80 of 607 Old 10-26-2008, 09:07 PM Thread Starter
bigsquat
I got the rear and front brakes on, steering stabilizer, drag link, rear brake lines,front shocks,tires,oil in the diffs, transfercase,and more. I put the jeep on the ground for the first time and the hight is exactly what i was after. Now i can get the rear driveline measured. I left the front off because i noticed one of the u-joints was a little tight.I really want to drive it to see if the home made perch extenions will work out, or will i go into a death wobble and die a firey death!the to do list is getting shorter, finish posi-loc,hand throttle,rear driveline, install hard top, paint right front fender and one hard door,high lift jack mount, cut down front bumper, and add some tow hooks.If i had the money i would by front and rear bumpers ,winch, and a rubicon rack but the budjet is at its limit.
92jeep tires 006.jpg   92jeep tires 008.jpg   92jeep tires 012.jpg   92jeep tires 007.jpg
bigsquat is offline
post #81 of 607 Old 10-27-2008, 02:23 AM Thread Starter
bigsquat
I want to build some rock sliders and want to get ride of those little flair extensions. besides getting tj style flairs is there a way to trim the front fender to look good with out that little extension.
bigsquat is offline
post #82 of 607 Old 10-27-2008, 11:47 AM Thread Starter
bigsquat
why is one tire an inch taller. there on the same width rim and the have exactly this same # on the side
bigsquat is offline
post #83 of 607 Old 10-27-2008, 12:24 PM
richmond1273
one tire is more worn than the other, different manufacturers... there are lots of possibilities. looks pretty good, good job making upgrades on budget, not all of us have a lot of cash laying around.
1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears
3" Rough Country suspension 33x12.50 Mastercraft MT
2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears
richmond1273 is offline
post #84 of 607 Old 10-27-2008, 12:28 PM Thread Starter
bigsquat
diff manufacturers, but both are new, i just thought that a tire with the same #s on the side should be the same size
bigsquat is offline
post #85 of 607 Old 10-27-2008, 02:54 PM
makaioM3
They should be, but unfortunatley they almost never are the same. I've had problems before switching tire manufactures on a vehicle where the fit was already at the max. One manufactures tires would fit fine, and anothers would rub like crazy, to the point of cutting the sidewall.
I try to research a tires true size by looking at the manufactures website for the measured true size before purchase now.
Great build and write up BTW.
97 TJ 4.0 Automatic
makaioM3 is offline
post #86 of 607 Old 10-27-2008, 09:30 PM Thread Starter
bigsquat
today i took the rear driveline to the shop to get it shortend. $60. I here u guys get it done for $35 back east, cost of living thing i guess. I finished the posi-lock and cant wait try it. it still needs the vac lines pluged or removed and heat shrink done on the cable entrance to the posi-loc.
92 jeep posi-loc 002.jpg   92 jeep posi-loc 003.jpg   92 jeep posi-loc 004.jpg   92 jeep posi-loc 005.jpg
bigsquat is offline
post #87 of 607 Old 10-28-2008, 08:57 PM Thread Starter
bigsquat
I set the rear pinion angle today. I was told to point the rear yoke str8 at the transfercase yoke and then down 1 degree for axle wrap up. This sounds easy but at first i didnt know how to get it exactly. So i took a string and taped it to the center line of both yokes. Note that the yokes must be perfectly level. and the jeep sitting on the ground at ride height. Once i got it perfect with the square i put an angle finder on the rear yoke and then moved it down 1 degree. then i tightened the u bolts and welded the perches. the cv shaft will run at 17 degrees witch is a lot less than i thought it would be. 22 degrees would be the max for this stock cv joint.
92 jeep driveshaft angle 001.jpg   92 jeep driveshaft angle 003.jpg   92 jeep driveshaft angle 006.jpg
bigsquat is offline
post #88 of 607 Old 10-28-2008, 11:09 PM Thread Starter
bigsquat
after the perches it was time to do the lower shock mounts. I cut down the old mounts to get them up and away from the rocks. By raising them i had to angle them in to not have the shock bottom out .I have them in the farthest in position ,but i have two more outboard adjustments.
bigsquat is offline
post #89 of 607 Old 10-28-2008, 11:20 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Dude, your build rocks!
It's good that you're doing something with it daily. Building a Jeep is like pushing a Sherman tank, MOMENTUM IS EVERYTHING!!!
Mean Max is offline
post #90 of 607 Old 10-29-2008, 01:38 AM Thread Starter
bigsquat
Your right about that! Its been like a real job, except i like doing this one. I should be doing some fishing instead of laying under my jeep every day
bigsquat is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 10:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 11:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
