92 yj build - Page 5 - JeepForum.com
post #61 of 607 Old 10-21-2008, 11:14 AM Thread Starter
bigsquat
When setting the d44 pinion angle, i was going to aim it str8 at the transfercase yoke then turn down 1 degree to allow for axle wrap up under load. Or should i go 2 degrees?
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #62 of 607 Old 10-21-2008, 09:06 PM Thread Starter
bigsquat
I spent the better part of today making a rear upper shock truss. It only gives me 3 spots for adjustment.I still have to decide where to mount the lower end, to stay away from the rocks and give me a lot of travel.The truss wasnt exactly what i intended to do but i wanted to use material i had laying around. Since i had no u-bolts to mount it to the existing shock location i had to come up with an alternitive,which was to cut the eye off one of the existing shocks and weld it to a channel thats bolted to the truss.I think it came out good enough.
bigsquat is offline
post #63 of 607 Old 10-21-2008, 09:09 PM Thread Starter
bigsquat
some pics, they didnt go thru the 1st time
bigsquat is offline
post #64 of 607 Old 10-22-2008, 11:49 AM Thread Starter
bigsquat
Today its another sunny day so i hope i can take the front end apart and back together. put in the 4.10, aussie,and posilock.
bigsquat is offline
post #65 of 607 Old 10-23-2008, 01:46 AM Thread Starter
bigsquat
Before i started on the d30 i painted the shock truss and installed it. It apears i will have to turn my muffler upside down to put the outlet closer to the frame. This will give me room for the pass shock to angle in.I did get to the d30 and changed the gears ,seals and put the aussie in.
92yj shocks 005.jpg   92yj shocks 007.jpg   92yj shocks 008.jpg   92yj shocks 006.jpg   92 jeep d30 001.jpg
bigsquat is offline
post #66 of 607 Old 10-23-2008, 01:58 AM Thread Starter
bigsquat
The seals took a little work to get in the d30.I made some tools to help, i havent done them before ,but it wasnt bad. I should get the front assembly in tommorrow.Pismo is getting closer, i will probably skip the posi-lock tillafter the trip, the vac still works.
92 jeep d30 002.jpg   92 jeep d30 003.jpg   92 jeep d30 006.jpg   92 jeep d30 005.jpg
bigsquat is offline
post #67 of 607 Old 10-23-2008, 11:57 AM Thread Starter
bigsquat
Stayed up till 4 last nite ,so im getting a late start. (Poker)I should get the d30 under the jeep today, then i can get the tires on and put some weight on the axles. Then i can measure for driveline or lines.What is the best setup on the slip yokes? ive heard just have them in the middle of ther travel.I think that i would have them favor the closed position more because it seems like they will travel more out than in. Am i correct in this thinking? Do u think ill have to extend the front with a 6" lift?
bigsquat is offline
post #68 of 607 Old 10-23-2008, 04:39 PM Thread Starter
bigsquat
slipyoke setup
ill try one more time .whats the best gap measurement for the slip yoke gap?
bigsquat is offline
post #69 of 607 Old 10-23-2008, 04:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Dude that shock mounting bar looks sweet! Excellent!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #70 of 607 Old 10-23-2008, 04:46 PM Thread Starter
bigsquat
thanks , i was going to copy some others id seen ,but that would mean i would have to go buy parts. Since I'm cheap i made it from whats lying around.But the same prince able as others
bigsquat is offline
post #71 of 607 Old 10-24-2008, 12:33 AM Thread Starter
bigsquat
posilock
I decided to go ahead with the posilock. I had a hard time finding the right spring, but I got a free one from the local brake shop. those guys keep barrels of old brake parts that they dont mind giving up. It was a spring that goes inside a wheel cylinder.It has beveled washers on the ends which centers itself perfect .I read a lot of the threads on doing this and they are quit good. I did however didnt see any that addressed all i wanted to do. I want to get rid of the vac diaphram ( because its ugly) ,and have the dash 4x4 lite work,so i had to make the shaft slide in its normal way but seal the end wth out the diaframe housing. I cut the shaft down and solderd a 1/2 copper pipe end fitting on what was left of the diaphram housing. There is a small o-ring on the shaft which i had to take of becuase it would hydroloc the shaft. once removed the shaft slid freely.
92jeep posi-lock 006.jpg   92jeep posi-lock 008.jpg   92jeep posi-lock 009.jpg   92jeep posi-lock 004.jpg
bigsquat is offline
post #72 of 607 Old 10-24-2008, 08:56 AM
Brads_nky_yj
question for ya, where did you order all the greasable bolts for the shackles from and did it come with all of them? Thanks
93 YJ - SOLD
Brads_nky_yj is offline
post #73 of 607 Old 10-24-2008, 10:17 AM Thread Starter
bigsquat
I got the bolts from jeep camping .com, ther located in placerville ca. James cossey the ceo is very helpfull for parts and info.
bigsquat is offline
post #74 of 607 Old 10-24-2008, 10:51 AM Thread Starter
bigsquat
I went ahead and install new greaseable axle u joints. I just need to paint the d30 and its ready to install.
bigsquat is offline
post #75 of 607 Old 10-24-2008, 03:44 PM Thread Starter
bigsquat
I painted the d30 and set in place this morning.I still have to bolt everything up. Its starting to take shape.I went and cut out the muffler and turned it over to get the outlet close to the frame and away from the new shock location. It seems the old track bar mount is in the way of the tail pipe now , so ill sawzall it off.
bigsquat is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 10:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 11:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
