92 yj build - Page 4 - JeepForum.com
post #46 of 607 Old 10-09-2008, 09:09 PM Thread Starter
bigsquat
I finished the right rear spring hangers and started to proceed with the front .i was going to leave the front end diff assembly in place and do the hangers ,ring and pinion,aussie locker,posi lock,working around it .but since im going to make some u-bolt protecters i think its easier to remove the hole thing.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #47 of 607 Old 10-09-2008, 09:14 PM Thread Starter
bigsquat
when i pulled the axles i noticed that the spares i had aquired from the 87 xj wernt the same. I thought the xj axles would work but they seem to be shorter? What years will work?
bigsquat is offline
post #48 of 607 Old 10-15-2008, 06:42 PM Thread Starter
bigsquat
Ok i guess they will work if i pull the hubs and use the yj hubs.
bigsquat is offline
post #49 of 607 Old 10-15-2008, 06:53 PM Thread Starter
bigsquat
today i painted the booms ,took out the transfercase,and started to install the slipyoke eliminator.the kit is the wrong one!!!!!!! And i got my $39 high lift jack in the mail.
bigsquat is offline
post #50 of 607 Old 10-15-2008, 06:58 PM Thread Starter
bigsquat
i found out why i the jeep would surge when i start out in first gear. i think the extra movement would make the throttle surge back and forth.
bigsquat is offline
post #51 of 607 Old 10-19-2008, 09:05 PM Thread Starter
bigsquat
after some input from a few of you guys i reallized i had the right sye kit. I did have to cut the shiftfork shaft,and remove two caged bearings.Then it went together real nice.I got the transfercase back in and the skid plate.
bigsquat is offline
post #52 of 607 Old 10-19-2008, 09:17 PM Thread Starter
bigsquat
more parts;shocks,bushings, greaseable bolts,hand throttle,steering stablizer,tranny mount,mirror and bearing-seal installer
bigsquat is offline
post #53 of 607 Old 10-20-2008, 01:42 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
Nice set of goodies u have there. xD. where did u get that Hi-Lift for $39?!
Thomas
-1987 YJ
Tompatt is offline
post #54 of 607 Old 10-20-2008, 01:58 PM
roadglide
yeah , I like to know where to get A $39 highlift jack. could be a nockoff, I have seen a smitty built advertised & another kind in JC whitney
roadglide is offline
post #55 of 607 Old 10-20-2008, 02:46 PM Thread Starter
bigsquat
i got the jack from harbor bay freight, its normally 49 but i got a deal. today i removed the old spring bushings and what a pain. iI had to use a torch.
bigsquat is offline
post #56 of 607 Old 10-20-2008, 02:50 PM
provinT13
dam nice work
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #57 of 607 Old 10-20-2008, 02:55 PM Thread Starter
bigsquat
thanks ,we will see if it works, Lunch is over so its time to install the springs(if the paints dry)
bigsquat is offline
post #58 of 607 Old 10-20-2008, 08:44 PM Thread Starter
bigsquat
I got all 4 springs and booms on. looks like there going to articulate real nice.
bigsquat is offline
post #59 of 607 Old 10-20-2008, 08:53 PM Thread Starter
bigsquat
started to install the d44. the perches i bought are not going to work. They are a little to long and will limit my travel.They also will make me lose about 3/4" of lift. I cleaned up the old ones and will be reusing them.
bigsquat is offline
post #60 of 607 Old 10-20-2008, 09:28 PM Thread Starter
bigsquat
Something i did earlier was install some seats out of a 97 cavalier
bigsquat is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
