92 yj build - Page 34 - JeepForum.com
post #496 of 607 Old 07-23-2011, 10:50 PM Thread Starter
bigsquat
the round dom is 1-1/4 id and 1-3/4 od. the square tube is 2 in. i decided to add some 2-1/2" to lower the perches a little more so i can cut down the 6" shackles to 5"
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #497 of 607 Old 07-23-2011, 11:49 PM
rogerhill
WORK IT SQUAT. lol.
Keep on it man. I'm still planning on building the rockers like yours.
rogerhill is offline
post #498 of 607 Old 07-24-2011, 10:41 AM Thread Starter
bigsquat
once the rockers go on you will piece of mind when you tackle those big boulders
bigsquat is offline
post #499 of 607 Old 07-25-2011, 09:22 PM
rogerhill
like liberals?
post #500 of 607 Old 07-26-2011, 11:02 PM Thread Starter
bigsquat
i finished the front hangers! since there lower i took the 5" shackles off the back and replaced the 6" ones on the front. i had put the 5" on the back to help correct pinion angle but i need the extra lift so i put the 6" back on and tomorro ill correct the pinion angle with steel shims that will be welded to the perches. i hate aluminum shims,they squish or crack and work loose.
the pic still has the 6" shackels installed, the 5" look much better
bigsquat is offline
post #501 of 607 Old 07-26-2011, 11:09 PM Thread Starter
bigsquat
i also got the doors painted. not an exact mach but close enough. the bummer is that after i put them on a neighbor's dog jumped up on both doors to say hi to me and scratched both!
bigsquat is offline
post #502 of 607 Old 07-26-2011, 11:13 PM Thread Starter
bigsquat
i was thinking about painting the chrome rims black. what do you guys think?
bigsquat is offline
post #503 of 607 Old 07-27-2011, 12:01 AM
rogerhill
paint them
post #504 of 607 Old 07-27-2011, 04:34 PM
Goobersbro
Paint them Bob.
My marshmallow build
Goobersbro is offline
post #505 of 607 Old 08-02-2011, 01:15 AM Thread Starter
bigsquat
i took the jeep wheeling with a bunch of jf members and had a good time for the most part. i had a problem with the right rear brake. the backing plate bent from the rear shoe driving to hard into the top pin. im not sure what caused it but it wasnt the first time its messed up. im thinking about a disc brake converson.
WHEN will i ever get it all dialed in!
bigsquat is offline
post #506 of 607 Old 08-03-2011, 04:53 PM Thread Starter
bigsquat
i did some research and it looks like the best and CHEAPEST options is to use 95-2001 explorer calipers,backiing plate, 2 passenger exploder soft lines, tera flex preload spacer, zj disc's, the spring out of a zj proportional valve. off to the junk yard!
bigsquat is offline
post #507 of 607 Old 08-06-2011, 11:35 AM
Tylerzap
Cool YJ man.
Tylerzap is offline
post #508 of 607 Old 08-06-2011, 06:31 PM Thread Starter
bigsquat
Originally Posted by Tylerzap View Post
Cool YJ man.
maybe if i put ac in! thanks for peeking
bigsquat is offline
post #509 of 607 Old 08-10-2011, 08:21 PM Thread Starter
bigsquat
picked up the stuff from the junk yard($150) the bearings and seals from napa($140) spacers from tera flex($34) $14 was shipping! cable clamps from home depot. its priceir than i thought but im committed to it now.
bigsquat is offline
post #510 of 607 Old 08-10-2011, 10:28 PM
rogerhill
I'm watching this. I want to do this.... my rear brakes need to be replaced anyhow
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
