92 yj build - Page 28 - JeepForum.com
post #406 of 607 Old 04-14-2010, 08:41 AM
hookedupinc
http://www.jeepforum.com/forum/f12/project-jevy-984905/
"Aw, jis taws a D-sisty aNNa SEE-fortene in air, an-U kin hit da mudHO wit me and Bubby dis weakin."
hookedupinc is offline
post #407 of 607 Old 04-14-2010, 11:44 PM Thread Starter
bigsquat
i took a look under the jeep today and noticed my weld has cracked where i put the gusset on the wrap bar to the cast steel pumpkin. its the 2nd time this has happened . i did some reading on welding cast steel and ill give it another try. this time ill preheat it with a torch and use a low hydrojen rod with my arc welder instead of the mig. and ill let it cool real slow. we will see. ill post a pic tomorro.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #408 of 607 Old 04-17-2010, 04:34 PM Thread Starter
bigsquat
here is the pic, you can see a crack right in the middle of the weld
bigsquat is offline
post #409 of 607 Old 04-17-2010, 11:08 PM Thread Starter
bigsquat
ok i dragged out the old arc welder i bought in 1971. i was afraid when i turned it on that i would electrocute a few mice and set there nests on fire. to my surprise no problems. i havnt used this for a while and did a little test weld to set the amperage and get use to the 7018 rod. it seemed to be ok and then i proceeded to preheat the bracket with a torch after i wire wheeled it. let me tell you that i have lost my touch with the arc welder! it was easy on the test piece laying flat. it was a different story on the axle. being past vertical i new it wouldnt be easy and i didnt know weather to go from bottom up or top down. it seemed to work better from the top down with the force of the arc keeping the puddle up. im not liking the 7018 compared to the 6013 or the 6011 rods. i didnt take a picture of the finish product due to embarrassment. even my spectators chuckled at my ugly weld. im really spoiled by my mig.
bigsquat is offline
post #410 of 607 Old 04-18-2010, 05:02 AM
boredatwork
3 things.
1- that is hilarious.
2- i agree with "that other dude", i read this entire thing and it changed my life.
3- i'm being as serious as an erection problem on valentines day.
im just cheap, and cheap makes you creative. - bigsquat
boredatwork is offline
post #411 of 607 Old 04-18-2010, 05:11 AM
boredatwork
btw... awesome build.
post #412 of 607 Old 04-18-2010, 11:21 AM Thread Starter
bigsquat
thanks, those 2 roosters are all thats left from all the chickens we had. it seems a local bobcat has a "taste like chicken" thing. i almost lost the white one the other night but the dogs saved him from being a late night snack. since there all alone they hang around when i work on the jeep. if they only could hand me tools or even better yet learn how to open the garage fridge and bring me a cold one. by the way i think there gay, which shouldnt surprise you since there california chickens. and ill ship them to you on valentines day!
bigsquat is offline
post #413 of 607 Old 04-18-2010, 11:45 AM
RockWoRM
RockWoRM's Avatar
funny!
that old thing looks like mine.
btw... are you still going to do the RokTrac Rubi TC?
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #414 of 607 Old 04-18-2010, 02:43 PM Thread Starter
bigsquat
Originally Posted by RockWoRM View Post
funny!
if the guy will take my motorcycle in trade for it im going to try it.
bigsquat is offline
post #415 of 607 Old 04-19-2010, 12:42 PM Thread Starter
bigsquat
he didnt want it ,its now for sale, and im selling 4 33" tires on rims as well.
bigsquat is offline
post #416 of 607 Old 04-24-2010, 02:21 AM Thread Starter
bigsquat
sold the bike and the tires! its pretty funny that the bike and the tire buyer showed up at the same time as well as a guy to pick up the 2 roosters(see what happens when you chuckle at your master) he has 15 hens and there going to be happy now.
im buying the rubi case tomorro. he is even going to drop it off!
bigsquat is offline
post #417 of 607 Old 04-24-2010, 02:29 AM
provinT13
How do you bolt the rear shaft up to the rubi? Will you be transferring your sye over?
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #418 of 607 Old 04-24-2010, 02:31 AM Thread Starter
bigsquat
i will have my hands full with this mod. ill probably have issuse with the skid plate and clearances, the speedometer sensor, the linkage, and the 2 output yokes are different than mine . this might be easier if i had a body lift. i wonder if i should do a seperate write up on this or is there a good yj with a rubicase writeup all ready?
i just had to spend the money b4 the wife found a use for it.
bigsquat is offline
post #419 of 607 Old 04-24-2010, 02:39 AM Thread Starter
bigsquat
it already has a sye built in. i have heard that the yoke on my sye will work on the rubi case but im not sure. i think there both 32 spline. as for the front im not sure what ill do there. its set up for a cv style ds i think. ive heard i can order a yoke for that to . i believe the rubi is 1330 size ujoints and my driveshafts are 1310. so i need a 32 spline yokr for the front with a non cv 1310 yoke. this should be fun and i cant wait to try the 4-1 vs the 2.73! i could of changed my ring and pinions instead of going this way but it still wouldnt be as low as the rubi case and my 4:10's. besides i like the 2 high the way it is now.
bigsquat is offline
post #420 of 607 Old 04-24-2010, 02:57 AM
provinT13
Yes keeping your 4.10s and re-gearing the t-case is better than axles. Cheaper, lower reduction and no negative effect to highway speed and rpm's. I think I'll be going with the teralow, but $1,100 is a big chunk of money for me.
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 10:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 11:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
