92 yj build - Page 23 - JeepForum.com
post #331 of 607 Old 06-02-2009, 09:50 AM Thread Starter
bigsquat
I decided to start doing the on board air . Sticking with the low buck theme, i took a ac compressor of a taurus parts car i have. It would be easier to use a cherokee one but it would cost at least $40. So i had to make some brackets to get it to mount. It looks like ill need to ad a idler pulley so the new belt will have enough contact on the alternator pulley. I should be able to use one off a cherokee from the picnpull. I still have to figure out how im going to attach the hoses. im hoping that i can use some compression fittings. After looking at my pic's, i really need to detail the engine bay out.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #332 of 607 Old 06-02-2009, 09:57 AM Thread Starter
bigsquat
i think ill use whats in this diagram that one of you guy's made for the hook up. im going to use my rear bumper as the tank.
bigsquat is offline
post #333 of 607 Old 06-02-2009, 03:45 PM
SteveJcoYJ
thats probably what the second thing you ever used on the jeep from the taurus
SteveJcoYJ is offline
post #334 of 607 Old 06-02-2009, 08:29 PM Thread Starter
bigsquat
im trying to think of what else i have taken off it? i did just steel the battery from it. not that mine was bad , but i noticed it was only 450 cold cranking amps and the taurus had a brand new 850! . it just fit with a little modifying on the top strap.
bigsquat is offline
post #335 of 607 Old 06-06-2009, 09:22 PM Thread Starter
bigsquat
i did a little work on the oba, i made a bracket and mounted the manifold. i picked up a breather for the filter. the inline oiler i got is pretty small, i wonder if it will be a big pain to keep oil in it. i still have to get a check valve and safety valve .
bigsquat is offline
post #336 of 607 Old 06-07-2009, 07:43 PM Thread Starter
bigsquat
i had to work today so not much on the oba, i did run the 3/8" air line inside the frame and out to the rear bumper. ill weld in a bung tomorrow. i also wired a toggle switch to the compressor via the pressure switch. i put it on a 15 amp fuse. ill pick up a tj belt and see if it works. if not then ill have to add an idler. Tuesday is the safety sw. and check valve.
bigsquat is offline
post #337 of 607 Old 06-07-2009, 08:25 PM
magnumcherokee
1992 XJ Cherokee
OBA is coming along nice and LOVE the home made swing out tire carrier/can rack set up. Very cool and good ideas!!
92 XJ sport 4.0L HO auto 231 Rustys 4.5"(gained 5") SA lift, ROR Adj TB, AR23 wheels, 33x12.50 MT Baja MTZs, doorless when sun shining
magnumcherokee is offline
post #338 of 607 Old 06-07-2009, 09:06 PM Thread Starter
bigsquat
thanks, im cheap so i have to make everything. rear setups can be over 700 and oba from kilby is 1150. i dont have much over a 100 between the 2
bigsquat is offline
post #339 of 607 Old 06-08-2009, 06:11 PM
magnumcherokee
1992 XJ Cherokee
That is the best, cheap and built by you!! Way cool, nice work!
post #340 of 607 Old 06-08-2009, 06:30 PM
yjcrawlr
I will definitely have to quote you again on this. Looks good! I couldn't agree with you more that is why I have the junkyard york =$40 and the junkyard bracket=$free. If your sanden craps out let me know and I will give you the top secret junkyard bracket info.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #341 of 607 Old 06-08-2009, 09:16 PM Thread Starter
bigsquat
you got my curiosity up!
bigsquat is offline
post #342 of 607 Old 06-09-2009, 11:11 PM Thread Starter
bigsquat
i went to auto zone and bought the tj belt. i routed it like a tj does so i wouldnt have to add another idler. it would work except that the taurus ac pump sits up higher than a jeep ac pump. so auto zone let me try a few until one worked. the third time was a charm. it ended up only being an inch longer than a tj, 92" instead of 91".
i then drove to Graingers and picked up the safety and check valves. i thru the switch on and it started pumping air and the belt seems to be tracking perfect. i then heard a loud hissing from the rear of the jeep. i forgot that i had a hole in the bumper where the latch fits into!. i plugged the rear line and tried again. worked great. i deflated my spare and filled it back up in no time. while i was at it i grabbed an air tool and gave it a try. keep in mind the rear bumper(tank) wasnt hooked up. it ran fast for a few seconds and then slowed a lot. i was a little disappointed until i went in the house and realized that the hole time i filled my tire and ran the impact i was idling! tomorrow ill fix the hole and turn up the rpm. one thing im not sure of is if i have the oil er in the right direction. and will it work with the low pressure thats going thru it? it was designed to run downstream of the compressor under high pressure to oil air tools. ill have to make sure its working properly before i run it much. i did squirt some air tool oil in the intake b4 i tested it.
bigsquat is offline
post #343 of 607 Old 06-10-2009, 10:48 PM Thread Starter
bigsquat
the oba is pretty much complete, i got rid of the cut off valve going to the rear bumper, i replaced it with a quick connect. i also welded up the end of a male fitting that will be in place to keep dirt out of the female quick connect. im still not sure about the oil er, but the oil level is down a little, so it must be working. you can see the belt is run different than a normal yj as to not need a second idler
bigsquat is offline
post #344 of 607 Old 06-11-2009, 12:38 PM
connor0770
hey bob. so is your rear bumper air-tight, and thats what you are using as your air tank? or is there actually a tank inside of it or what. im a little confused.
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #345 of 607 Old 06-11-2009, 01:40 PM Thread Starter
bigsquat
its air tight now, for the most part. i wasnt to careful when i was grinding down the welds and i had a few small leaks on the ends. they didnt show up untill i fixed the 1/2 hole where the swing out locking pin is. i get a few bubbles from the fitting where the air hose is attached, but after 3 passes with the welder i gave up. there is no tank inside the bumper ,it is itself the tank. basically a traveling bomb waiting to go off.
bigsquat is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
