92 yj build - Page 21 - JeepForum.com
post #301 of 607 Old 03-31-2009, 03:04 PM Thread Starter
bigsquat
if your 31's would fit my cheroke ill trade you for the ones that came on my jeep
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #302 of 607 Old 03-31-2009, 05:31 PM
Goobersbro
naa thanks for the offer by the time im ready for new tires i will be ready for my 33s rite now i could throw 33s on there but i have enough issues with the 31s not having low enough gearing let alone 33s but thanks man
My marshmallow build
Goobersbro is offline
post #303 of 607 Old 04-17-2009, 10:35 PM Thread Starter
bigsquat
today i started working on a few little things like grinding down the stops so i could get a little more turning radius. i was able to get a little more out of it before the tires would rub on the springs. i was going to adjust my steering wheel as well . i put a string all the way around the jeep to get the tires str8 ,when i noticed the driver side rear tire wasnt parralell. the rear passenger wasnt bad. and i noticed i had toe out instead of toe in on the front tires. it appears as tho the rear rc springs arnt the same distance from the spring pin to the spring eye. one is about 3/8 to a 1/2" different. that might explain some of the rear steer i have been having. im not sure what do about it. maybe swap the pass to the driver side and see if that helps.
bigsquat is offline
post #304 of 607 Old 04-17-2009, 10:38 PM
yjcrawlr
Could one of the springs be flipped around. I know the springs should be the same both ways but maybe the rc's have a front and rear of the spring.
90 YJ 102 in wb stretch, SOA, dana 60, 14 bolt welded,4.56s, 37in Parnelli jones dirt grips, currie twin stick dana 300, york oba, tractor link traction bar, full custom armor,poison spyder tube fenders, 95Cherokee High Output 4.0
2014 JKU, modified Rubicon Rails, RC stubby with warn 8000m, 2" leveling springs and OME trim spacers, Superchips Flashcal, Spidertrax wheel spacers, rubi shocks, and Lots more mods soon!!!
yjcrawlr is offline
post #305 of 607 Old 04-17-2009, 10:51 PM Thread Starter
bigsquat
if i remember right doesnt the side that goes to the fixed sping hanger have a bigger eye than the shackle side?
bigsquat is offline
post #306 of 607 Old 05-02-2009, 09:19 PM Thread Starter
bigsquat
Today im starting to build a rear bumper with swing out tire carrier, and rack with gas and water cans. The challenge is to use the scrap and junk i have been hording. I found some 3x3x 1/4" square stock, a couple ladder racks,amd an old trailer axle. Now to make them work.
bigsquat is offline
post #307 of 607 Old 05-06-2009, 10:14 PM Thread Starter
bigsquat
I removed the old bumper and started with the bumper.
92 jeep rear bumper 004.jpg   92 jeep rear bumper 007.jpg   92 jeep rear bumper 005.jpg   92 jeep rear bumper 008.jpg
bigsquat is offline
post #308 of 607 Old 05-06-2009, 11:54 PM
CaptainJaxx
Yes, that is correct.
CaptainJaxx is offline
post #309 of 607 Old 05-06-2009, 11:56 PM
Goobersbro
lol thats dirty you gonna have your bumper done before me im still waiting on my tax return the day i get it im cashing it and buying my steel
post #310 of 607 Old 05-07-2009, 12:49 AM Thread Starter
bigsquat
i still have to work out the spare height and rack height. also where to put to pivot point on the bumper.
bigsquat is offline
post #311 of 607 Old 05-07-2009, 12:53 AM
Goobersbro
heres the specs im using
For a bumper 58" long. Center the hole for the pivot approx 7.25" from the passenger end. use a 2.75" diameter pivot tube and make the arm about 41" long. If you use a smaller tube for the pivot, you'll want to lengthen the arm a bit to make up for the difference.
now give or take some depending upon the length of the bumper
post #312 of 607 Old 05-07-2009, 01:10 AM Thread Starter
bigsquat
thanks mines 56"
bigsquat is offline
post #313 of 607 Old 05-07-2009, 01:11 AM
Goobersbro
so that would be like 6.25" anywho hurry up and get it done so i can see some pics
real quick question though that i havnt figured out yet for myself how did you mount it to the factory plate im trying to decide if i want to weld some brackets on the back and drill it or bolt it on or just weld it i cant decide
post #314 of 607 Old 05-07-2009, 10:55 PM Thread Starter
bigsquat
today i didnt make much headway. the hub im using was a real pain to cut out of the brake drum. its almost an inch thick,so my torch wouldnt cut it. i had to grind it out. it took a least two hours! it is beefy tho.
im thinking of using the old tire carrier and mount it to some framework.
bigsquat is offline
post #315 of 607 Old 05-07-2009, 11:05 PM
Goobersbro
did you buy a bearing kit and spindle for that or what and what kind of latch are you planning on running???
Here is the beering kit and spindle im looking at running is this what you used or did you do something different
http://www.etrailer.com/mm5/merchant...t_Code=BK1-100
http://www.etrailer.com/mm5/merchant...Category_Code=
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 10:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 11:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
