92 yj build - Page 2 - JeepForum.com
post #16 of 607 Old 10-03-2008, 09:55 AM Thread Starter
bigsquat
thanks r1627, ill do that. by the way i want to keep the water out so im going to seal the cable entrance with silicone but the cable isnt very waterproof it self. What do i do? maybe slide some tubing over it a few feet up?
bigsquat is offline
post #17 of 607 Old 10-03-2008, 10:02 AM
JaikYJ
That looks like its going to be alot of fun, I wish I had a table of goodies like that in my garage!
87 YJ(sold), 97 TJ(sold), 99 TJ(daily)
03 R1 (fun)68 Mustang Coupe(summer)
67 Fastback(resto)
JaikYJ is offline
post #18 of 607 Old 10-03-2008, 10:03 AM
Brandon_YJ
1987 YJ Wrangler
Originally Posted by bigsquat View Post
do the booms look familiar brandon?
Yeah, and thanks
There's surface rust on them though, is that something that happened while at your place or are those fingerprints of mine that oxidized in transit?
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #19 of 607 Old 10-03-2008, 10:04 AM
champelite210
You need a bigger table.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #20 of 607 Old 10-03-2008, 10:05 AM Thread Starter
bigsquat
i wish i had a bigger garage! trying to install all this stuff in the gravel on a slope wont be fun. and we are getting our first rain of the season today.
bigsquat is offline
post #21 of 607 Old 10-03-2008, 10:07 AM Thread Starter
bigsquat
the rust was on them when i opened the box. u must have just ate taco's.
bigsquat is offline
post #22 of 607 Old 10-03-2008, 10:18 AM
r1627
On that Napa cable there isnt much you can do to weather proof it. i used a rubber cap over the fitting that i threaded into the block. I saw a better cable on mcmaster carr for 10 bucks more but i had the Napa cable already.
r1627 is offline
post #23 of 607 Old 10-03-2008, 10:45 AM
Brandon_YJ
1987 YJ Wrangler
Nope, haven't had tacos in quite a while.
Interesting though, it looks like fingerprints from the pictures. I think I'm going to have to start oiling them as I pack them.
Thanks for inadvertantly bringing that to my attention.
in a (text only)
post #24 of 607 Old 10-03-2008, 01:21 PM Thread Starter
bigsquat
now that i have your prints i think ill enter it into the criminal justice system. i went out to start working on the 44 then the wife showed up and it seems that spiltting wood was on the new agenda! maybe the jeep will seem some personal time tonight.
bigsquat is offline
post #25 of 607 Old 10-03-2008, 04:14 PM
AuroraJeep
Here is a link to a posi-lock write with that same cable. I am digging the build. What size tires?
99 TJ
91 YJ sold
AuroraJeep is offline
post #26 of 607 Old 10-03-2008, 04:21 PM
Brandon_YJ
1987 YJ Wrangler
too late
in a (text only)
post #27 of 607 Old 10-03-2008, 09:57 PM Thread Starter
bigsquat
Aurorajeep , ilove the posilock write up.thanks . do you get any water in through the cable sheath? you can silicone the cable entrance but the rest of the cable isn't weather proof. and my tires are going to be 33" like i have on it now but with an aggressive tread.
bigsquat is offline
post #28 of 607 Old 10-03-2008, 10:23 PM Thread Starter
bigsquat
well i did the honey do list and got back to the jeep. I cleaned the 44 and made a brass punch out of an old king pin that i braised the end and ground down. I installed the pinion races with the correct shims under the big race.My old pinion was a +3 and the new was a 0, so i subtracted .003 from the existing shim pack.If the old pinion was -3 and the new +2 then i would add .005, you want it to add to 0.That was the easy part, to set the pinion preload took forever!!!!!!!I measured the old preload shims and tried that. NO go ,it was to loose. THEN i pulled it apart and took off .005,now to tight! i went back and forth 6 times before i got it.I think i didn't get the races seated all the way at first.,and it threw my calcs out.you got to have everything completely clean or a spec of dirt can mess up your readings.By the way do this without the seal installed ,then when u know u got it pull of the yoke and install the seal. You should have 5 to 10 inch pounds of tork. tomorrow the carrier bearings.
bigsquat is offline
post #29 of 607 Old 10-03-2008, 10:26 PM Thread Starter
bigsquat
here are some more pics
bigsquat is offline
post #30 of 607 Old 10-04-2008, 09:24 AM Thread Starter
bigsquat
Ok ,i got a couple hours of sleep and going to sneek out to the garage befor the boss gets up.I noticed that the small shims that go behind the front pinion bearing got chewed up. they had the thinest shim against the shaft and its not a very big surface area there. i think that its better to put the thickest shim there to prevent it from being squeezed out. BY THE WAY IM NOT BY ANY MEANS AN EXPERT ON ANYTHING , U GUYS PLEASE CHECK OUT ALL THE ADVICE I GIVE. I HAVE ONLY INVENTED OR STOLE IDEAS FROM YOU GUYS. (NO FORMAL TRAINING)ill try to do anything, mainly because im to cheep to pay someone.
bigsquat is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
