92 yj build - Page 17 - JeepForum.com
post #241 of 607 Old 02-06-2009, 12:13 AM
Goobersbro
lol thats really funny
My marshmallow build
Goobersbro is offline
post #242 of 607 Old 02-06-2009, 12:39 AM Thread Starter
bigsquat
i found a good way to get rid of the runs(in my paint) ill try it tomorrow, if it works ill post the process
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #243 of 607 Old 02-06-2009, 12:45 AM
Goobersbro
okay cool how did you know how to find the color to match your jeep im looking at painting some hinges and and my grill this summer. I have a booth i might be able to get a hold of just want to know what color to use
post #244 of 607 Old 02-06-2009, 01:24 AM Thread Starter
bigsquat
i went done to a local paint supplier and he looked around for a paint code, but couldnt find it. it wasa repaint anyway. he showed me what he thought it was so we went with it. since my paint is a little faded its a little off,but not to bad. they can color match, but its exspensive.
bigsquat is offline
post #245 of 607 Old 02-06-2009, 01:26 AM
Goobersbro
hmm interesting yea i would like to get my grill and some hinges painted and then get a clear coat and then a protective coat on it those protective coats are amazing my parents have one on there truck and it rocks it holds up really good also
post #246 of 607 Old 02-06-2009, 01:33 AM Thread Starter
bigsquat
i just used a single stage paint for mine. i have done base/clear coat jobs ,but not a protective coat.
bigsquat is offline
post #247 of 607 Old 02-06-2009, 01:39 AM
Goobersbro
yea man there amazing they protect really well and they make washing it so simple like i can take a spray bottle and get bird crap off
post #248 of 607 Old 02-06-2009, 02:58 PM Thread Starter
bigsquat
I removed the runs or sags today. here is how i did it. take a single edge razor. using a screwdriver and burnish the end. it makes it into a mini scraper. the end is bent over. you then put scotch tape over the ends. this keeps it of the surrounding paint. just drag it across the run until your happy with the amount removed. then take polishing compound and buff it out. then i apply swirl remover and it looked pretty good . it is a little time consuming and i could of removed more paint but since its not a show car it was good enough. i went ahead and used the swirl remover on the rest of the jeep. in the pic of the hood you can see to the front is a little dull and to the right you can see how it shined up nice. i like single stag paint for this reason. clear coats are generally to thin and once the sun degrades them there toast.
bigsquat is offline
post #249 of 607 Old 02-06-2009, 03:01 PM Thread Starter
bigsquat
more pics....
92jeep paint repair 001.jpg   92jeep paint repair 004.jpg   92jeep paint repair 003.jpg   92jeep paint repair 005.jpg   92jeep paint repair 007.jpg
bigsquat is offline
post #250 of 607 Old 02-06-2009, 06:40 PM Thread Starter
bigsquat
do you guys think that 3x3 angle would work for sliders? i happen to have enough of it to do it. it might be a little tricky to mount .
bigsquat is offline
post #251 of 607 Old 02-06-2009, 11:04 PM
Barrio
The only thing I hate about your YJ is that its not mine. lol
I think if your skilled enough give it a shot for the sliders.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #252 of 607 Old 02-07-2009, 12:03 AM Thread Starter
bigsquat
what till its finished then ill let you have it. on the sliders ,the reason i am a little hesitant using 3" is because off the inside tub and bottom lip mounting points are limited with 3" material. i am also putting a 1- 1/2 " pipe that's cut in half along the bottom of the slider. if that makes any sense. i would have to weld studs at that point to the back of the slider's where the pipe mounts.
bigsquat is offline
post #253 of 607 Old 02-09-2009, 05:59 PM Thread Starter
bigsquat
my rear tire is still rubbing when i go over an obstacle even with the new 6" wide flare. i should have mounted them higher up i guess. i lined up the bottom of the flares to the tub as per instructions. what do you think about a 1" body lift?
bigsquat is offline
post #254 of 607 Old 02-09-2009, 06:09 PM
Goobersbro
thats what i plan on doing this summer i want to go with a 1.25" body lift though. The only thing that has been holding me back was some people say you have to notch inside the tub so that you can shift into 2 4 and reverse and if i do mine i want to do it without messing with the carpet
post #255 of 607 Old 02-09-2009, 06:21 PM
tommanns
I'm running into the same issue myself... if you're not too keen on the BL, you can always put some extended bumpstops in there remember.
lllllll
tommanns is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
