92 yj build - Page 16 - JeepForum.com
post #226 of 607 Old 02-02-2009, 08:34 PM Thread Starter
bigsquat
another beautiful day in God's country! I got the flares started finally. When cutting open the fender in the front i decided to weld the seem up. I got the front almost done. i had to go to the dentist so i will start again tomorrow
92 jeep pocket flares 001.jpg   92 jeep pocket flares 003.jpg   92 jeep pocket flares 004.jpg   92 jeep pocket flares 006.jpg   92 jeep pocket flares 007.jpg
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #227 of 607 Old 02-02-2009, 08:38 PM Thread Starter
bigsquat
more pics ......
92 jeep pocket flares 008.jpg   92 jeep pocket flares 009.jpg   92 jeep pocket flares 010.jpg   92 jeep pocket flares 012.jpg
bigsquat is offline
post #228 of 607 Old 02-04-2009, 12:47 AM Thread Starter
bigsquat
i finished the flares finally. when cutting the sheet metal i left some for making tabs to bend over to hold the plastic inner fender wheel. i didn't have to do any welding on the back like i did the front. now to paint the fender!
and then ill make some sliders. the to do list is getting smaller.
92 jeep pocket flares 014.jpg   92 jeep pocket flares 015.jpg   92 jeep pocket flares 018.jpg   92 jeep pocket flares 021.jpg   92 jeep pocket flares 019.jpg
bigsquat is offline
post #229 of 607 Old 02-04-2009, 08:22 PM Thread Starter
bigsquat
i painted the fender---yea! all was well untill i noticed i used a slow reducer, whoops.
it was bought when it was a hundred degrees out. ythe darn paint just wouldnt set up. it looked good untill about 10 minutes after the 3rd coat. then the bugs showed up and a run started. i can fix it , but i should have bought some fast reducer. the cat will be on it next!
92jeep fender paint 005.jpg   92jeep fender paint 001.jpg   92jeep fender paint 004.jpg   92jeep fender paint 007.jpg   92jeep fender paint 008.jpg
bigsquat is offline
post #230 of 607 Old 02-05-2009, 12:02 AM Thread Starter
bigsquat
now for the sliders , i have to decide if i want to but them to the flares, go under the flares, or under and notch the flares?
bigsquat is offline
post #231 of 607 Old 02-05-2009, 12:19 AM
Maryland95YJ
My favorite part of your build is that you took the time to do everything 100% right. No shortcuts. I feel like when I work on my jeep I want it done too fast, sometimes done to limited time, but generally impatient. Great job and don't stop.
Maryland95YJ is offline
post #232 of 607 Old 02-05-2009, 12:59 AM Thread Starter
bigsquat
thanks, its getting close to almost done. we know it never ends, and sacrifices made between what we want and what we can afford make us upgrade some things again at a later date.
bigsquat is offline
post #233 of 607 Old 02-05-2009, 01:03 AM
Goobersbro
Yae you finally painted that fender!!! just made my day lol its comming along nice. Way to go with those fenders too good find
My marshmallow build
Goobersbro is offline
post #234 of 607 Old 02-05-2009, 01:29 AM Thread Starter
bigsquat
now nowone will find me at pismo, i told them i would be the red yj with one black fender. i still have 2 different colored doors!
bigsquat is offline
post #235 of 607 Old 02-05-2009, 01:32 AM
Goobersbro
wow
wow man why did you have to tell me that.... now im going to have to bug you about the doors beeing different colors
post #236 of 607 Old 02-05-2009, 01:44 AM Thread Starter
bigsquat
in did a poll a while ago as to whether to do the black door red or the red door black. you know sometimes i forget there different colors. you cant see them at the same time and i like both looks and still haven't decided . the reviews were mixed .
bigsquat is offline
post #237 of 607 Old 02-05-2009, 01:55 AM
Goobersbro
i think the black look pretty sick but then again i also like the clean look like with no decals and all the same color so yea i can see that being a hard choice. Personally i think on yours the black doors look better or even do the lower part of the door red and that little cut in part black
post #238 of 607 Old 02-05-2009, 02:01 AM Thread Starter
bigsquat
now you had to give me another option!
when i put the sliders on they will be black also and there not going to go up more than 4" on the side. so there will be a strip of red below the door. just something else to throw in the mix
bigsquat is offline
post #239 of 607 Old 02-05-2009, 02:15 AM
Goobersbro
yea if you do the rock sliders you totally should paint the door red and fill in the area around the door handle black
post #240 of 607 Old 02-06-2009, 01:11 AM Thread Starter
bigsquat
when i got up this morning i went to remove the masking paper and sure enough the cat had to see if the paint was dry! the good part it was, he did leave some prints.
bigsquat is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 10:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 11:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
