92 yj build - Page 14 - JeepForum.com
post #196 of 607 Old 12-30-2008, 09:44 PM Thread Starter
bigsquat
i didnt notice that before, thanks, i forgot the spacer when i changed springs. i wonder if it will be a problem?
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #197 of 607 Old 12-31-2008, 02:16 AM Thread Starter
bigsquat
the test drive went good. i put the rear tire on a rock and it had the same flex as before. i thought it might bind a little ,but it seems fine. the tire went into the flare,so i guess it's time to do the tj flairs.
bigsquat is offline
post #198 of 607 Old 12-31-2008, 05:04 PM Thread Starter
bigsquat
well i couldn't find the pipe i needed to extend my front ds. i took it to the local guy here and he talked me out of just lengthening it and sold me on a bigger and bad er slip yoke assembly
bigsquat is offline
post #199 of 607 Old 01-01-2009, 12:48 AM
snkwired
how much that set you back?
snkwired is offline
post #200 of 607 Old 01-01-2009, 03:44 PM Thread Starter
bigsquat
he gave me a deal, $185 + tax, which i thought was good.
bigsquat is offline
post #201 of 607 Old 01-01-2009, 07:43 PM Thread Starter
bigsquat
i put the front ds on and drove up wentworth to take the kids to the snow. the road is plowed up until there are no more houses,and them its all snow and ice. i went in a little ways and if i got out of the ruts then the jeep would go sideways and slide. the snow had froze hard and any off camber would send the jeep sideways. i decided to not travel in to far since i have no winch. we just hung around the end of the road and watched people go in. and have a big snow ball fight. its nice to have the snow line just minutes from our house.
snow trip 001.jpg   snow trip 002.jpg   snow trip 006.jpg   snow trip 008.jpg   snow trip 013.jpg
bigsquat is offline
post #202 of 607 Old 01-02-2009, 12:06 AM
snkwired
makes make wanna get money faster so i can lift and go play
snkwired is offline
post #203 of 607 Old 01-10-2009, 08:12 PM Thread Starter
bigsquat
I picked up my birthday present a little early, a smitty built winch.
i found some 1/4" steel and started to fab the mounting plate.
i wasn't sure how i was going to secure the back bolts. instead of putting the nuts on the inside of the frame i welded some nuts to some 1/4" square washers ,that will be welded on the top of the frame.
the square washers will also make the plate level and high enough to clear that little factory gusset in the front.
it got late so ill be at again tomorrow
bigsquat is offline
post #204 of 607 Old 01-11-2009, 01:22 AM
snkwired
nice looking. can't wait to see it installed
snkwired is offline
post #205 of 607 Old 01-11-2009, 04:58 AM
glenno
glenno's Avatar
Thanks for sharing the build
Gave me a lot of ideas for my own YJ. As said above, can't wait to see the finished project.
glenno is offline
post #206 of 607 Old 01-11-2009, 09:20 AM Thread Starter
bigsquat
thanks guys, i will have to come up with another way to hold my jack untill i make a rear bumper and tire carrier.
bigsquat is offline
post #207 of 607 Old 01-11-2009, 10:50 AM
RockWoRM
RockWoRM's Avatar
Very cool idea! Are those grade 8 nuts? Nice you're so close to the con! Planning any trips this season?
Nice build up!
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #208 of 607 Old 01-11-2009, 02:02 PM Thread Starter
bigsquat
they were grade 8 before i welded on them, who knows now.
yes i will be doing some trips to the con, its been since the early 90's tho since i was past wentworth springs or loon lake dam. right now from george town you can go to ucle tom's cabin, but it gets dicey past that. so i here. from the ice house road side it's plowed ,but they push the snow in a big pile towards the trail. my next trip is a presidents weekend bash at pismo.
i have old wheeling friends from the bay area that im am trying to get back with as well as going a club up here.
i don't want to do the con solo.
bigsquat is offline
post #209 of 607 Old 01-11-2009, 02:07 PM
visa
yes you do, you can go up to 3.54 only with that carrier ,at least thats what ive been told. . i got mine used for $40 and im using all the bearings and shims from the old carrier. i did buy new seals and have extra shims.get a spare set of carrier bearings and grind the center out so they slip on for easy set up. then just put the other bearings on. this saves a lot of time
you can put both your shims on one side and it will work, but you might as well do it right.
visa is offline
post #210 of 607 Old 01-11-2009, 02:25 PM Thread Starter
bigsquat
hello visa, that was a while ago when i did the diff's. but thanks for the input.
bigsquat is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
