Well i finally think i have most of the parts and tools to start upgrading the yj. The plan is to change the gearing from 3.54 to 4.10,add aussies front and back.,replace the dana 35 with a 44,slipyoke eliminator,home made posilock,Add another 2" off lift to the existing 4" lift with 6" booms and lowering the spring perches 2".Also going to install a hand throttle,replace the dana 30 wheel joints ,use a cut down front driveline from a xj for the rear of the yj.i need to repaint at least the right front fender or maybe the whole jeep.Ill try to post pics as i go.
