I have my pieces for my transmission crossmember at work and I loaded up some hardware for it into the car tonight. Hopefully gonna at least tac weld some of it together tomorrow
Haven't really done anything in the last year with the jeep. Just moved it in and out of the drive way. Ordered a gasket kit for the dana 300. Started working on the wiring harness for the engine today and seeing about building a new shifter for it
Cleaned up and degreased the wiring harness for the jeep at work. Going to start removing all of the unnecessary wiring for the computer since il be running a carb set up. I have Monday off from work. Have to do a couple things around the house then I'm spending some time on the jeep again.
Here's a picture of the wiring harness
mostly cleaned up. I already spliced a new trailer wire harness into the rear vehicle harness as well
Did some work on my cj dash. Made a new hole for the yj heater controls. I'm going to make a new switch panel where the cj heater controls originally went. The new switches will be for the extra lights, winch and what ever else gets added. Took a pic of my work bench at work. Brought my jeep parts to work so I'd have something to do since its slowing down at work
Started tearing into the wiring harness for the engine. Printed off the diagram for the headlight upgrade. Already have my relays at home somewhere and will pick up some new sockets for the lights
All zip tied together. Looks like a harness again. Will do more with it once it's in the jeep and the engine is back in. That way I can run all my wires to the proper length and wire up the different sensors for it. Found one relay kit in the garage for the head lights. I will have to pick up another along with the new head light sockets
Didnt find the headlight sockets that I wanted at the parts store so I ordered new one on Amazon along with a new 6 relay,6 fuse under hood box instead of buying another relay with harness. I have lots of relays and fuses. Just needed another relay kit to do the headlight upgrade. Parts should be here in 3 days. Will post pics when they get here.
Finished tidying up a bit of the engine harness at work between jobs. Then loaded it into the car and will start wiring up the jeep once the weather warms up. -26 this week at the coldest according to the weather man.
you have been an insipration - i had to do a full frame swap so i really enjoyed seeing your progress - feel free to see what i am working with.. haha just as rusty
I know this tank came from a yj but I always assumed it was for a fuel injected jeep. I never paid any attention to the wiring before. But it's just 2 wires, 1 for ground and 1 for the level sending unit. Has no fuel pump. So it must have been a 90 or older I'm thinking. I will be running a carbed v8 so I want to buy a new sending unit for it and just need to know what year
of jeep to get one for. Thanks In advance.
My head light sockets and new under hood fuse/realy box came in. Just need some warmer weather now. Il be running all new wiring for the head lights except for the trigger wires for the relays. Those will be the old high/low beam wires from the switch
No updates to report on. It did warm up today. Still in the negatives but my wife's at work so I'm on with our son today. If it stays a warmer next week I may be able to start some wiring on the jeep. I have the new fuse box at work, I'm going to start wiringg up some of the fuses and relays when i have down time in between jobs. Here's the latest pic of the jeep.
May have found a rebuilt York compressor with newer clutch and an idler pulley for an Oba setup. My neighbor has s smaller electric compressor that the motor is gone in for me as well. I'm going to rob the tank, regulator and a few other parts off of it for the system
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
