-   Jeep Builds (http://www.jeepforum.com/forum/f22/)
-   -   90 yj frame swap and build up (http://www.jeepforum.com/forum/f22/90-yj-frame-swap-build-up-1434246/)
lovett86 11-03-2012 06:56 AM
started a new build thread
picked up a frame for 100 bucks, guy threw in a plastic tank with it
http://i1094.photobucket.com/albums/...tt86/002-7.jpg
went back a couple weeks later and picked up a cj dash and speedo, cable
http://i1094.photobucket.com/albums/...tt86/007-7.jpg
this is the jeep as it is sitting now
[IMG]http://i1094.photobucket.com/albums/...tt86/001-4.jpg[/IMG]
the frame does need a bit of repair at the passenger rear rail, will post pics after its repaired
lovett86 11-03-2012 02:51 PM
found a 2nd bad spot in the frame after i took a hammer to the hole thing so i fixed it first
http://i1094.photobucket.com/albums/...tt86/002-8.jpg
this is the passenger side rail, still needs a bit of work
http://i1094.photobucket.com/albums/...tt86/001-5.jpg
lovett86 11-05-2012 08:24 PM
a bit more work on the frame
http://i1094.photobucket.com/albums/...vett86/021.jpg
http://i1094.photobucket.com/albums/...vett86/020.jpg
found this little guy too
http://i1094.photobucket.com/albums/...vett86/019.jpg
wont be long before its all fixed
lovett86 11-10-2012 04:52 PM
left side of cross member
http://i1094.photobucket.com/albums/...tt86/004-9.jpg
right side
http://i1094.photobucket.com/albums/...t86/003-10.jpg
rear all fixed up
http://i1094.photobucket.com/albums/...t86/005-11.jpg
little hole patched up
http://i1094.photobucket.com/albums/...tt86/006-6.jpg
rear track bar mount ground off
http://i1094.photobucket.com/albums/...tt86/008-7.jpg
front track bar mount ground off
http://i1094.photobucket.com/albums/...tt86/007-8.jpg
i just have to clean up the threads in the frame for the skid plate and then grind down the frame and paint it
lovett86 11-21-2012 08:19 PM
got alot of grinding done on the frame, hoping to have it primerd next week
lovett86 01-10-2013 08:55 PM
finally got some primer on the frame
http://i1094.photobucket.com/albums/...pse3ac7094.jpg
Copperhead89 01-11-2013 03:12 AM
What did you do with all of that heavy surface rust before priming it?
lovett86 01-11-2013 04:14 PM
lots of grinding discs and a big wire wheel on the grinder and i got some metal cleaner from work, id of rather sandblasted it, but i dont have one so i had to work with what i had
lovett86 02-03-2013 04:07 PM
New frame is painted and ready for swap. Body is off the jeep and ready to go. Will have pics tomorrow
lovett86 02-16-2013 02:26 PM
no pics yet, but the whole drive train is stripped down to nothing
lovett86 02-21-2013 06:59 PM
http://i1094.photobucket.com/albums/...ps52d75095.jpg
http://i1094.photobucket.com/albums/...pscd0bf1a4.jpg
http://i1094.photobucket.com/albums/...ps65194542.jpg
http://i1094.photobucket.com/albums/...ps89e77a35.jpg
http://i1094.photobucket.com/albums/...psfa6e0339.jpg
http://i1094.photobucket.com/albums/...ps3b408e15.jpg
lovett86 02-21-2013 07:02 PM
have the jeep stripped rite apart for now, will be assembling on the new frame soon, have cleaned up and painted a bunch of parts, the engine i thought was a 318 is actually a 360, super clean on the inside too
lovett86 04-21-2013 06:26 AM
http://i1094.photobucket.com/albums/...pse8d4dce7.jpg
http://i1094.photobucket.com/albums/...ps376a29c3.jpg
http://i1094.photobucket.com/albums/...ps511a5bd4.jpg
http://i1094.photobucket.com/albums/...ps5b004a36.jpg
http://i1094.photobucket.com/albums/...ps050447c6.jpg
welded in some new nuts for the skid plate and i still have to tighten up some of the u bolts and i forgot a couple shackle bolts at work, but its all most a complete rolling chassis again
Copperhead89 04-22-2013 10:13 AM
You're doing yeoman's work to bring that frame back to life!!:thumbsup:
lovett86 04-27-2013 06:03 PM
thanks, been slow progress on it so far, been working alot on the new house instead of the jeep, wish i could do things differnt with it, but i can only work with what i have
The time now is 05:40 AM.
