Quantcast 89 YJ built with Wag parts - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 89 YJ built with Wag parts
Old 08-23-2007, 04:38 PM   #1
learfxr
I bought my 89YJ with the engine and transmission removed. The prev owner wanted to V8 the YJ and gave up. I kept the 4.2L and bought a 80 Wagoneer to supply the transmission, trans case and axles. This is the first of the driving pics. I still have to have the front axle geared and locked. The parts are sitting in a box, just have to get the money to pay the shop to do the work.
1989 YJ Islander
TBI350 4L60E BDS lift.
Wag axles, 38 TSL's, 4.56 gears
1995 ZJ Orvis Edition 5.2L
3" lift and 32's.
learfxr is offline   Reply With Quote
Old 08-23-2007, 04:41 PM   #2
learfxr
1989 YJ Islander
3" lift and 32's.
Old 08-23-2007, 04:44 PM   #3
learfxr
This is what it looked like for a while. I'm ready to start playing with it now. Had it for over a year and barely driven it so far.
1989 YJ Islander
3" lift and 32's.
Old 08-23-2007, 05:59 PM   #4
JEEP97TJ
Nice Jeep. Looks good. Keep us updated
Blacksburg, VA
JEEP97TJ is offline   Reply With Quote
Old 08-23-2007, 07:55 PM   #5
speedracer2536
im gonna be putting a waggy 44 in the front of my yj. my dana 30 just wont cut it anymore. got a writeup you used or any tips
93 yj lifted locked and ready to rock
6.5"soa 35's lockers beadlocks,8.8
and some other junk here and there
www.krawltex.com
if your in austin look them up best guys to deal with hands down
speedracer2536 is offline   Reply With Quote
Old 08-23-2007, 10:33 PM   #6
learfxr
Found a few D44 install tips online. I just did a search on the web and found a few tips. I stayed SUA, so it was easier. I filled the perch holes with a welder, then added some 1/2" steel next to the pads. The springs are 1/2" off from a Wag, so add some metal, drill new holes and sit it on the springs. Wasn't bad. My YJ has a BDS lift with a drop pitman arm, so I had it reamed to fit the Wag TRE on the steering. Got long lines from Napa to replace stock front lines. My front lines were too tight and had to cut the end off. Pax side I flared a new fitting and went on, the LH side I installed a new hard line and hand bent it.
1989 YJ Islander
3" lift and 32's.
Glock Forum
