88 Cummanche Frame off rebuild. - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 88 Cummanche Frame off rebuild.
Rough Country Jeep Suspension Deals at Rockridge 4WD!G2 Disc Brake Conversion Kit for Jeep Wrangler YJ TJ LJ ChIron Cross Customer JK and TJ Wrangler Bumpers now at ROCK
Unread 12-07-2012, 04:27 AM   #1
DallastheJeeper
DallastheJeeper's Avatar
This is a project that all my friends think is crazy but Im determined to finish it (kinda have to at this point) so though this build will go slow I will finish it!! Money allowing before summer of 2013.
Here is a little background:
I bought my Comanche when I was 15 for $300, its what got me hooked onto Jeeps. It served me well until the frame rotted out and I was forced to put it into hibernation and bought a TJ and then a LJ.
Last year the car club im in started renting a very large shop and that's when I decided to bring the Comanche back to life. I found a local Jeep scrap yard and purchased a 87 Comanche with a near perfect frame. I then proceeded to cut the frames out from underneath both trucks (The guys in the club think in crazy!)
Enjoy!
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|____________________/||__/----|
#5-06 Salvage Rebuild LJ
Metalcloak Bumper, Overline fenders and Corner guards.
3.5" Sus Lift
1'' Body lift and engine lift
#4-98 TJ Sahara RIP :(
#3-42 GPW Project. Currently on hold Sand blasted the body and it was held together by screen and bondo so new Tub needed
#2-88 Comanche Currently getting a frame off rebuild and a 4bt.
#1-1994 Power Wheels Wrangler
DallastheJeeper is offline   Reply With Quote Quick reply to this message
Unread 12-07-2012, 04:33 AM   #2
DallastheJeeper
Here are some pics of the Manche before I started to cut it up.
From Cummanche
From Cummanche
From Cummanche
3.5" Sus Lift
Unread 12-07-2012, 04:39 AM   #3
DallastheJeeper
At a local Junk yard I found this commanche. It was a 4 cyl. We drug it out of the yard which was a pita because the steering was locked up and we had to make some tight turns.
[IMG]
From Cummanche
[/IMG]
[IMG]
From Cummanche
[/IMG]
[IMG]
From Cummanche
[/IMG]
3.5" Sus Lift
Unread 12-07-2012, 04:51 AM   #4
DallastheJeeper
I then removed the frame from the parts commanche. Not a easy task.
Bed Removal
From Cummanche
From Cummanche
Frame is impeccable!
https://lh4.googleusercontent.com/-g...2002.39.34.jpg
Using the high lift to assist
8 hours later and countless sawsall blades later behold the frame
3.5" Sus Lift
Unread 12-07-2012, 05:05 AM   #5
DallastheJeeper
Next came tearing down the comanche.
Bed off, not much left of the frame.
Half a truck!
3.5" Sus Lift
Unread 12-07-2012, 05:15 AM   #6
DallastheJeeper
While Casual cruising CL I found it! The highly sought after Cummin 4BT!! It was still in the panel van which was a chore to get it out of since it had to come out the side door. The 4bt came with a T19 4sd which I cant use because its not long enough so the shifter would be in the dash. The 4BT had 170k ish on it and a leaky head gasket.
3.5" Sus Lift
Unread 12-07-2012, 05:23 AM   #7
DallastheJeeper
4 BT down to the short block.
The head which during a trip to the machine shop for valve guides was found to be cracked
3.5" Sus Lift
Unread 12-07-2012, 05:35 AM   #8
DallastheJeeper
In July I had a lifter fail on my LJ at 34k miles. I believe it was caused by low ZZDP Levels in the oil. So I put in a 505 Performance stage 1 cam. The cam issue set me back quite a bit so progress on the Cummanche came to a abrupt halt. In sptember i started back at school and slowly started working on the manche again. I picked up a Dana 60 rear and Dana 44 front out of a J20 (Pics to Come), they are full width 66" so it will have a wide stance. I just finished sand blasting the Frame and bottom of the cab so I will post more pics soon.
3.5" Sus Lift
Unread 11-27-2013, 03:56 AM   #9
DallastheJeeper
Project had a little break but many many updates to come!
This is not just another failed 4bt swap thread!
3.5" Sus Lift
Unread 01-06-2014, 12:49 AM   #10
SOWEGA TJ
updates?
SOWEGA TJ is offline   Reply With Quote Quick reply to this message
Unread 01-06-2014, 09:16 PM   #11
ZSXJ430
Hey man, any pictures and updates? I too am curious.
On Order: 2015 Trailhawk V6
ZSXJ430 is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 12:48 AM   #12
DallastheJeeper
Alright its about time for an update!
I have had allot on my plate; school,work,Girlfriend, working on the wrangler, working on the Cummanche and a internship with Metalcloak in cali. So this build thread has been low on the priorities but il get caught up. Though I am a little short on pics as i tend to just work and forget to take pictures.
Here are a couple pics of my summer in cali wheeling the Rubicon
I purchased axles from a 80 J20. Front is a dana44 and rear is dana 60.
Front axle was stripped down, sand blasted, rubicon express truss/brackets, Coated in POR 15, hubs rebuilt,new brakes, new u joints and cross over steering.
Rear axle got stripped down, new brakes and is under the Jeep. Once i set the pinion angle i will weld on the barns truss and leaf spring perches.
3.5" Sus Lift
Unread 11-14-2014, 12:52 AM   #13
DallastheJeeper
Made long arms for the front out 2'' .25" wall DOM With MetalCloak Duroflex joints.
3.5" Sus Lift
Unread 11-14-2014, 12:57 AM   #14
thevanillaninja
That's awesome. Keep up the work, I'd love to see this thing done!
02 Overland
89 XJ 4.0/aw4/242 // 87 Parts XJ
01 WR250 // 10 Sportsman 400HO
MK2 USCG, Kodiak, AK
thevanillaninja is offline   Reply With Quote Quick reply to this message
Unread 11-14-2014, 01:01 AM   #15
DallastheJeeper
After lots of cutting, sand blasting, welding and wondering why I started this project. I now have the cab on the frame, half the floors in, control arm brackets on, and frame mostly plated.
3.5" Sus Lift
