88 Comanche more capable - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > 88 Comanche more capable
Attention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONSBds fox ipf 2.0 racing series shocks now available at rockFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-06-2013, 09:44 AM   #1
NYTrailrider
1988 MJ Comanche
Hello all. I have been a member here for a few years, mostly reading and posting newb replies. I bought an 88 Comanche Pioneers 4 years ago and slowly have built it up. Most of it happened in NY, I moved to TN 1 month ago and have gotten a lot more done.
It started out as a 4.0/Peugeot **** box/2wd.
This is how it was before I bought it:
I sanded painted it OD Green:
Result:
I drove it for a year and a half like than before the Peugeot started grinding, So I found an AX-15/NP231/Dana 30 for the front and had a transmission shop install the tranny and transfer case (which I had left together). I installed the axle.
A year after that I put 30's on it.
I moved to TN a month ago, and when I got here I ordered the Zone 4.5" lift kit for the COmanche, and started install last week. As of right now I am repairing the rear brakes lines as they cracked whilst moving them, I have to install the trans case drop included with the kit, then its off to the alignment shop.
88 Comanche AX15/NP231 swap. Zone 4.5" lift Future-Dana 44s, lockers, 36" tires, 4BT swap
NYTrailrider is offline   Reply With Quote
Unread 04-06-2013, 09:48 AM   #2
NYTrailrider
1988 MJ Comanche
Unread 04-06-2013, 09:50 AM   #3
NYTrailrider
1988 MJ Comanche
Unread 04-06-2013, 09:52 AM   #4
NYTrailrider
1988 MJ Comanche
Unread 04-06-2013, 09:52 AM   #5
NYTrailrider
1988 MJ Comanche
Unread 04-06-2013, 09:53 AM   #6
NYTrailrider
1988 MJ Comanche
Next item to tackle after my funds recover:
Bore it out to 5.0?
Unread 04-21-2013, 08:03 PM   #7
NYTrailrider
1988 MJ Comanche
Come awn guys, gimme some MJ luv
Unread 06-17-2013, 05:44 PM   #8
NYTrailrider
1988 MJ Comanche
Brand new shoes for the Manche. 31x10.5x15 Interco SSM16's
SOOOOO LOUD ON THE ROAD but I am very happy.
