87 xj Rubicon ready in 2 years? Hopefully! - Page 2 - JeepForum.com
post #16 of 60 Old 11-11-2011, 06:31 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
SWEEET! Got the drivers side rear quarter trimmed up! Al the hared fender cutting is done! The rest when i get tires and lift should be pretty easy.
Here is the line I foolowed for cutting out the quarter. Used a Dye Grinder and started Cutting. I followed the taped line and then once that was established I cut on around the inside.
In the second picture i left enough of the inside sheet metal so I could poound it flat and use it as a welding surface.
On the 3rd Pic you can see the cover for my gas lines. I was able to cut it up with the dye grinder and "massaged" it into place so i could keep the access point usable. Then i just used some self tapping screws to finish it off.
And on the last pic it is all done and primed! Ready for some seam seal!
Drivers side fender trim 002.jpg   Drivers side fender trim 006.jpg   Drivers side fender trim 011.jpg   Drivers side fender trim 014.jpg
My Jeep Build!
Nik-Nak is offline
post #17 of 60 Old 11-11-2011, 06:47 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Got the 4.0 back from the shop today too! On Monday hope to start getting it put back together and get the Overhaouled drive train ready for the swap!
Few pics after the fender trim!
Drivers side fender trim 017.jpg   Drivers side fender trim 020.jpg   Drivers side fender trim 021.jpg
My Jeep Build!
Nik-Nak is offline
post #18 of 60 Old 11-21-2011, 12:58 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Got the Motor back from the machine shop! Since my jeep is an 87' and the motor i am overhauling is an 90' it has a signifacant horse power increase from 150 to 177!!!! The motor is bored 3000ths over and should bump me to about 185 HP!
Here are some pictures of progression!
Jeep Pics from Phone 2 539.jpg   Motor overhaul 001 (5).jpg   Jeep Pics from Phone 2 985.jpg   Jeep Pics from Phone 2 1100.jpg   Motor overhaul 001 (19).jpg
My Jeep Build!
Nik-Nak is offline
post #19 of 60 Old 11-21-2011, 01:00 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Should Have the whole Powertrain ready to be swapped into my jeep by the first of the year! Pretty excited to have a reliable power train back the jeep. The current 4.0 has 230,000 miles and needless to say burns a lot of oil and does not have much pep!
My Jeep Build!
Nik-Nak is offline
post #20 of 60 Old 11-21-2011, 04:25 PM
Gh0st
Love the blue on the motor
To hell and back.
Gh0st is offline
post #21 of 60 Old 11-21-2011, 05:00 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
MOPAR Blue! Its going to be pretty until the first time I get to take it off road!
My Jeep Build!
Nik-Nak is offline
post #22 of 60 Old 11-22-2011, 01:52 AM
bldeagle10
what all did you have done with the rebuild and about how much did it run you if you dont mind me asking. my motor has 330,000 miles on it and I am in need of a rebuild, but I'm on a college budget.
1999 XJ Cherokee SE 4.0 330k miles, DD, 2" spacers Chili Pepper Red
FS: 2000 XJ 4.0 ECU pm for details!
Build Thread:
Originally Posted by egodfrey View Post
my diffs and unibody rails have more scrapes then an emo-girls arm
bldeagle10 is offline
post #23 of 60 Old 11-22-2011, 09:02 AM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
The Motor is a 4.0L srtaight 6. Took it to the machine shop where they did a valve job on the head, Bored the block .030 over, turned the crankshaft rod and main journals. Purchased a "rebuild Kit" specific for the oversize bore that came with the correct size pistons, new rings, timing chain, oil pump, all new gaskets through the whole motor. Had to purchase seperately a water pump, spark plug and wires, Distributor cap and rotor, and thermostat.
I am into the motor about $1100.00. That does not include the paint i purchased to make it look PURTY!
Keep in mind I have done all the work my self. Just to pull and replace a motor costs about 8 hours at $80.00 dollars and hour. To reasemble the motor your looking at about an additional 4-6 hours at the same price. So the cost for labor on a job like this is around $1100.00 as well.
If you can do the work yourself and be without a motor for a while you save BIG! Good Luck
Here are a few pics of the finshed motor before I put it in!
My Jeep Build!
Nik-Nak is offline
post #24 of 60 Old 04-14-2012, 02:44 PM
Benderff
Benderff's Avatar
Stop slacking and get to work on that thing!
Benderff is offline
post #25 of 60 Old 07-01-2013, 05:17 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Have not posted anything forever! Got the Motor I rebuilt stuffed in last year and Due to the old wiring on an 87' jeep cherokee I have had all sorts of issues keeping it running. Knock on wood I do believe I have all the issues dealt with and she has been running good with no issues until two weeks ago when the transmission went out. The AW4 is currently getting a rebuild and purchased an oversized tranny cooler and bigger lines to go with it! Have done a lot of little things-Cut fenders, warrior product roof rack, A 3 1/2" tuff country lift and new heavy duty rear leafs to hold me over Until I can save up for my 4 1/2" long arm from Clayton Off Road!
My Jeep Build!
Nik-Nak is offline
post #26 of 60 Old 07-01-2013, 05:20 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Purchased LED bulbs that work in the 1157 and 1057 sockets, they were around $18.00 dollars each but I should not have to replace bulbs anytime soon!!!
My Jeep Build!
Nik-Nak is offline
post #27 of 60 Old 07-01-2013, 05:24 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Cut down the front bumper and relocated the filter under my overflow tank in the engine compartment.
Phone5-22-133237.jpg   Phone5-22-133236.jpg   Phone5-22-133234.jpg   Phone5-22-133231.jpg
My Jeep Build!
Nik-Nak is offline
post #28 of 60 Old 07-01-2013, 05:28 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Here is how it sat before the 3 1/2" lift.
You can see the new roof rack from warrior products too! its a nice rack!
TriptoCoastwithMindyLauraandBecky5-18-13004.jpg   TriptoCoastwithMindyLauraandBecky5-18-13003.jpg   TriptoCoastwithMindyLauraandBecky5-18-13002.jpg   TriptoCoastwithMindyLauraandBecky5-18-13001.jpg
My Jeep Build!
Nik-Nak is offline
post #29 of 60 Old 07-01-2013, 05:37 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Here is the current state; 3 1/2 inch tuff country lift ( needed something to hold me over until I can afford the Clayton off road lift), Warrior products Roof rack, Led lights all the way around, Rebuilt 1990 4.0L bored 3000ths over, Replaced almost every sensor known to man on the motor, Currently having the tranny rebuilt by Jaspers and will be upgrading the tranny cooling system. Obviously not going to have this baby Rubicon Ready since my two year dead line is next month but I am definately going to keep chipping away!
Here are some pics after the lift!
Now I need some bigger tires!
Phone5-22-133789.jpg   Phone5-22-133720.jpg   Phone5-22-133716.jpg   Phone5-22-133714.jpg   Phone5-22-133712.jpg
My Jeep Build!
Nik-Nak is offline
post #30 of 60 Old 07-01-2013, 05:40 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Finally a little Jeep build Progress! And way overdue update to my lame build thread! LOL!
My Jeep Build!
Nik-Nak is offline
My TJ LCOG build "Uncharted" IceKnight Jeep Builds 276 09-19-2016 04:27 PM
getting ready to rebuild Tinman12 Jeep Builds 0 11-18-2010 06:48 PM
Trail Ready *One Pic* thejafe Jeep Builds 7 04-11-2008 04:40 PM
'01 TJ ready for more mods! BigTimber Jeep Builds 2 02-27-2005 08:13 PM
ready for the snow Hal Jeep Builds 6 12-02-2004 10:41 PM
