87 xj Rubicon ready in 2 years? Hopefully! - JeepForum.com
post #1 of 60 Old 10-21-2011, 05:49 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
So I am adding this now over 2 years later! LOL! This has been way more expensive than what I thought it would be and I dont have a money tree! My plans when I started this were to refresh the motor and get a lift and bolt on some tires. Newby thoughts at the time! As I have been working on my jeep and reading jeepforum, cherokeeforum, naxja, I have learned that A lot goes into this! I have spent a lot of time and money the first two years just getting the drive train reliable. Now that I have that completed time to spend some money on it to make it trail worthy!
Whats Done
Rebuilt 1990 renix 4.0 bored .30 over
Rebuilt AW4 by Jaspers
Countless dollars spent on diagnosing no start issues, random dieing issues
Replaced just about every sensor a renix era Cherokee has
5" Leaf Springs From Clayton Off Road with Drop Shackles and 7 Degree Shim
Adjustable Upper and Lower Control Arms and Trac Bar by www.ironman4x4fab.com
JCR Rear Quarter Armor with LED light upgrade
JCR DIY front bumper and Super winch
Rustys Oil pan and transfer case skid plates
Hack and tap SYE on Np242 Transfer case
Future plans
Install Recently Purchased 2008 Jk HpD30 and D44 Axles
Buy 35" tires-Cant Wait!!!
Rear bumper
Set of Rock Rails by JCR
On board air
This is my Daily Driver!
My best friend took me with him this year to the Rubicon trail! What an experience. I have a couple of jeeps so its time to start building! Hope to have my XJ ready by 2013! Wish me luck!
First things first; pull a motor and start the overhaul!
I have a choice between an NP231 or an NP242 transfer case; Still undecided on wich one to use.
Here are a few pics of the engine pull!
Last edited by Nik-Nak; 12-17-2013 at 02:02 PM. Reason: Add some more specs for interest and see if people might read my thread!
Nik-Nak is offline
post #2 of 60 Old 10-21-2011, 08:31 PM
Benderff
Benderff's Avatar
Sweet dude! I can't wait to see how it goes. After a little reading i'd say to for the NP231. Are both transmissions the same?
Benderff is offline
post #3 of 60 Old 10-25-2011, 05:37 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Got the motor broke down and I should be getting it off to get overhauled by the end of this week! Its dirty! Found a SYE for my np231 and will start in on that real soon!
Nik-Nak is offline
post #4 of 60 Old 10-25-2011, 10:55 PM
Benderff
Benderff's Avatar
Hey dude, some random thoughts I had.
Can you list info on the two XJ's you are working with? Do they have the same transmission? I'm not sure if you will have to do any computer work? Maybe someone will know and post up some info.
They both should have a High Pinion front axle. You should be able to save the shafts from the extra axle for spares. You could sell the extra housing for 80-100 around here.
Are both rear axles D44's? I know the XJs also had 8.25, and D35 rears. If they are the same you could have a set of spare shafts also. And a housing or whole axle to sell down the road.
Benderff is offline
post #5 of 60 Old 10-25-2011, 11:05 PM
Benderff
Benderff's Avatar
Some of the parts we have talked about.
Front end-
Lower Control arms (2) http://shop.savvyoffroad.com/product.sc?productId=17&categoryId=2
Upper Control arms (2) http://shop.savvyoffroad.com/product.sc?productId=18&categoryId=2
Springs
Longer brake lines
Swaybar disconnects
Front bump stops http://shop.savvyoffroad.com/product.sc?productId=22&categoryId=2
Adjustable Front track bar http://shop.savvyoffroad.com/product.sc?productId=78&categoryId=2
ZJ Tie Rod
Some extras that would be great
Upper JJ housing kit http://shop.savvyoffroad.com/product.sc?productId=16&categoryId=2
Lower arm brackets
D30 inner sleeve
Aussie locker?
Need to check the ball joints and unit bearings
Rear end-
Leaf springs
SYE kit
Shorten, balance , and rebuild your extra driveshaft
Rear locker?
Currie's Johnny Joints are the ****. With the upper housing, making JJ's all around the front you almost eliminate any chance of death wobble. Your front will feel solid, and flex great.
Everything at Savvy is 10% off also. If you bought a bunch at once that would be more off. Or you could buy as you could and swap in stuff like the arms over time then adjust them when you lift with the springs.
Benderff is offline
post #6 of 60 Old 10-28-2011, 04:48 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Finally got the motor broke down and ready to be sent to the machine shop and get all the brackets, oil pan, valve cover cleaned! Here are a few pics of the 4 door 87 XJ I am going to build. Have to get some "stock" pics in here so we can see the progress!!!!
Also a picture of the tag on my rear end letting me know it is a Dana 44! Pretty lucky considering I bought the jeep for $200.00 Bones!
I got the other jeep for $200.00 bucks as well. Going to find out what the rear is on it--Hopefully a Dana 44 as well so i can hace some spair parts
Nik-Nak is offline
post #7 of 60 Old 10-28-2011, 05:23 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
This uploading pictures thing is a pain in the A#@!!
Here are a couple more!
Nik-Nak is offline
post #8 of 60 Old 11-04-2011, 09:05 AM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Started trimming on the fenders. Started with the front!
Here is the front before......
And After....
Looks better already!
Nik-Nak is offline
post #9 of 60 Old 11-04-2011, 09:08 AM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Hopefully have some pics posted of the rear quarter panel cuts soon! These are fun! I like the welding and cutting!
Nik-Nak is offline
post #10 of 60 Old 11-09-2011, 04:25 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Strated Cuttingon the rear quarters. Got the passenger side cut out and the fill piece welded in. Hopefully i will het the Drivers side done on Friday! Then Seam seal and undercoat and another task done......of MANY!!!!
Here are a few pictures of the before and after. Just welded in the fill piece today and got it primered but did not take any pics.
Rear fender cut 002.jpg   Rear fender cut 007.jpg   Rear fender cut 009.jpg   Rear fender cut 012.jpg   Rear fender cut 014.jpg
Nik-Nak is offline
post #11 of 60 Old 11-09-2011, 04:45 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Test Test!
My Jeep Build!
Nik-Nak is offline
post #12 of 60 Old 11-09-2011, 07:06 PM
Benderff
Benderff's Avatar
Originally Posted by Nik-Nak
Test Test!
Testys Testys 1, 2, 3?
Benderff is offline
post #13 of 60 Old 11-10-2011, 02:17 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
LOL! I was seeing if i had figured out how to get my Build thread posted each time I make a comment.
My Jeep Build!
Nik-Nak is offline
post #14 of 60 Old 11-11-2011, 04:47 PM
Benderff
Benderff's Avatar
Dude... Screw it.. Do this- http://www.pirate4x4.com/forum/showthread.php?t=507763
I didn't see much around for doing a tummy tuck, with out hacking into the unibody.
Benderff is offline
post #15 of 60 Old 11-11-2011, 06:24 PM Thread Starter
Nik-Nak
Nik-Nak's Avatar
1987 XJ Cherokee
Holy cow that would be sick! If I did not need it roght now for a daily driver I would so do that! Maybe in the future!
My Jeep Build!
Nik-Nak is offline
My TJ LCOG build "Uncharted" IceKnight Jeep Builds 276 09-19-2016 04:27 PM
getting ready to rebuild Tinman12 Jeep Builds 0 11-18-2010 06:48 PM
Trail Ready *One Pic* thejafe Jeep Builds 7 04-11-2008 04:40 PM
'01 TJ ready for more mods! BigTimber Jeep Builds 2 02-27-2005 08:13 PM
ready for the snow Hal Jeep Builds 6 12-02-2004 10:41 PM
