'86 Comanche Engine Swap - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > '86 Comanche Engine Swap
Dan's Old as Dirt Birthday Sale!GEARSHADE Pocket Tops in stock and available at ROCKRIDGE Yukon Ultimate 35 axle kit for c/clip axles with Yukon Zip
Unread 07-29-2014, 11:50 AM   #1
ClassicMark
1986 MJ Comanche
I am looking to swap out my 2.8l engine. It is starting to knock and I need to figure out the best swap for this engine. I know that the 3.4 is the easiest... but there are power issues and longevity issues with it.
I am planning on doing a complete swap, engine, trans, transfer if needed. I want to keep the front and rear axles for now.
I have seen multiple threads on many forums about swaps but there are issues raised about engines not fitting in the '86 but they fit in the '87 and later. I don't mind the work and can deal with the cost that will be incurred IF I know that everything will fit and will be compatible.
Any and all help would be greatly appreciated.
ClassicMark is offline   Reply With Quote
