84 cj 7.5 lcog - Page 7 - JeepForum.com
 1Likes
post #91 of 1130 Old 09-23-2013, 10:09 AM
freaknajeep
1971 DJ
sweet tank...get it from summt?...im getting ready to order one from them for the daily....they didn't have an alum. one that would fit here I wanted so im having to settle for the abs tank...and my son live somewhere near you I think..ackworth and where you are are close correct?
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline
post #92 of 1130 Old 09-23-2013, 12:13 PM Thread Starter
84jeepcj7rock
Yeah the tank came from Summit. We have a store in Atlanta. There are so many shiny things its hard not to buy anything. I live near Kennesaw Mountain which is about 10 miles from Acworth.
84jeepcj7rock is offline
post #93 of 1130 Old 09-24-2013, 04:53 AM Thread Starter
84jeepcj7rock
Since I decided to raise the rear frame section to hug the bottom of the tub I had to make a decision. I can drop it back down to go under the rear lip of the tub or I can French the tub aroun the frame. Since the fuel cell is going behind the seat, no since in giving away ground clearance. I will cut another hole in the center for a receiver hitch.
post #94 of 1130 Old 09-24-2013, 04:54 AM Thread Starter
84jeepcj7rock
I will box these areas in an it will be stronger than stock.
post #95 of 1130 Old 09-24-2013, 04:58 AM Thread Starter
84jeepcj7rock
2" rear bumper to match the front. I'll angle the ends at 45 deg and cap them to match the front. The YJ tailgate is toast after backing into a tree on Rattlerock in WindRock ORV. It will get a CJ tailgate
post #96 of 1130 Old 09-24-2013, 05:05 AM Thread Starter
84jeepcj7rock
I have several more pics of the rear frame section and body mounts but the file size is too large. Anyhow, here is the progress. Hope to have the rear section welded on this week.
post #97 of 1130 Old 09-24-2013, 05:10 AM Thread Starter
84jeepcj7rock
I have heard a lot of discussion on this forum re: rear axle width especially concerning the 8.8 axle swap. Everybody seems concerned about having an axle that is 1-2" narrow in the rear. I like having my rear axle narrow. It help to navigate tight sections o trail. I know that if I can get my front tires through, then I can get my rear through. Even in the middle of a tight turn.
post #98 of 1130 Old 09-24-2013, 05:20 AM
freaknajeep
1971 DJ
Aww yea...looking nice and clean
I measured my clearance the other day for some reason...32" to frame 36" to rockers and 14" to diffs...I tried to stay low but I don't guess it's too bad for an ouch gravity hurts rig...Aaay
post #99 of 1130 Old 09-24-2013, 05:42 AM
freaknajeep
1971 DJ
That's a real good point...one I hadn't really thought of, being that I run such large aggressive tires on my 44 front, I had to make sacrifices...one is unroll I can dump buttloads of cash into it I can't locker up...and here's the main loss to prevent blowing axle joints I only use 5.75 inches of my almost 8 lock to lock...so I tend to 3 point turn a lot....and have relied heavily on my sliders in the past to help me navigate tight spots...most of my wheeling experience has been in moderately hilly river bottoms/flood areas terrorised by large groups of 4wheelers...so my rig is slightly designed towards that in that the rear tires are offset by almost 6"(as if using outers only on a dually setup) per side to stagger tracking in heavily rutted areas....never thought about going narrower to accomplish same result....so thanks, definitely going to check out axle options on narrowing my 60...wife's gonna strangle me...and sorry for the long winded narrative...
post #100 of 1130 Old 09-24-2013, 08:03 PM Thread Starter
84jeepcj7rock
All lined up. Decided to use the rails from the soft top to help line everything up before I started welding. Did I mention how much I hate dealing with Line-X.
post #101 of 1130 Old 09-24-2013, 08:05 PM Thread Starter
84jeepcj7rock
She is all back together. I drew an arc to see how far up I could cut before I got into the wheel well on the inside.
post #102 of 1130 Old 09-24-2013, 08:08 PM Thread Starter
84jeepcj7rock
PS. The hole behind the wheel opening I where I used to run the exhaust out of the side. I used a TJ gas filler to fill in around the exhaust. Used to get some funny looks from people trying to figure out how my gas tank wAs making noise. Lol
post #103 of 1130 Old 09-25-2013, 04:01 PM
freaknajeep
1971 DJ
and the jeep gods bowed their heads in approval...amen brother.......anyways so how could a jeeper from a different line come across one possibly two of those dead monkey stickers...im assuming its the one of curious georges head in a pool of blood and the eyes x'ed out...or is that a different dead monkey sticker?...please I got to have em if those are the ones...I grew up on curious George..i read all his adventures
post #104 of 1130 Old 09-26-2013, 07:11 AM Thread Starter
84jeepcj7rock
Sundowner is the man with the Monkeys.
post #105 of 1130 Old 09-26-2013, 07:16 AM Thread Starter
84jeepcj7rock
She is getting there.
Things left to do.
Mount front coil overs
Plumb hydro assist steering
Fill fluids
Get exhaust run
Fill shocks w Nitro
Test drive and play w spring rates
Mount resivoirs
