84 cj 7.5 lcog - Page 6 - JeepForum.com
 1Likes
post #76 of 1130 Old 09-22-2013, 07:09 PM Thread Starter
84jeepcj7rock
Time to start putting the back end together. As I said before, couldn't find a deal on a rear tub section, so I'm going to make my own panels to go in. I plan on covering most of the work with corner armor and the belt rails for the soft top
84jeepcj7rock is offline
post #77 of 1130 Old 09-22-2013, 07:14 PM Thread Starter
84jeepcj7rock
As you can see here, I've got the inner sections done. The rear shock towers come into passenger compartment a little. If you look under the floor section, there is a 4" gap down to the rear section of frame. I will raise that section of frame since a fuel cell will go in behind the rear seat.
post #78 of 1130 Old 09-22-2013, 07:19 PM Thread Starter
84jeepcj7rock
For someone who hates sheet metal work, I'm pretty proud of making this side panel. I clamped the flat sheet between two pieces of angle and beat it with a rubber mallet. Where I needed to make a really sharp bend, I scored it with a cut off wheel on a 4.5" grinder, then went back an welded up the score and ground it flush. Should have spent the money on another tub. Lol
post #79 of 1130 Old 09-22-2013, 07:54 PM
freaknajeep
1971 DJ
lookin good bruh..I got jack and squat done today...no wait I did get the big dj cleaned out and no longer a storage area for parts for little dj...lol...
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline
post #80 of 1130 Old 09-22-2013, 09:29 PM Thread Starter
84jeepcj7rock
Here is a better pic
post #81 of 1130 Old 09-22-2013, 09:30 PM Thread Starter
84jeepcj7rock
It official, grinding and welding on Line-X will take years off of your life. This stuff sucks.
post #82 of 1130 Old 09-22-2013, 09:32 PM Thread Starter
84jeepcj7rock
post #83 of 1130 Old 09-22-2013, 09:34 PM Thread Starter
84jeepcj7rock
Still have a lot to do before I can weld the back, but I wanted to see what it would look like.
post #84 of 1130 Old 09-22-2013, 11:26 PM
TechJeeper
Keep it up I like where its going. Frame off custom is the only way to get what you want sometimes.
TechJeeper is offline
post #85 of 1130 Old 09-22-2013, 11:37 PM
freaknajeep
1971 DJ
what model miller you got it looks a lot like the one I have...only in tru redneck fashion I sometimes carry mine around in the wheelbarrow...lol
post #86 of 1130 Old 09-23-2013, 05:21 AM Thread Starter
84jeepcj7rock
I have a millermatic 175 that I run on 230 amps. Also have a miller spectrum 375 X treme plasma that I love
post #87 of 1130 Old 09-23-2013, 05:44 AM
freaknajeep
1971 DJ
ha..i knew it looked like the one I have...lol..kinda wishing I had bought a different plasma cutter....I hade longevity...it used to work awesome then it died...lol...which is ok I guess its still under warrantee...but they want 160$ to ship it to and from cali to fix it...its also my tig so I need to send it off but hard to justify that expense at the moment...
post #88 of 1130 Old 09-23-2013, 07:56 AM
TechJeeper
A set of scrambler corner armor blanks would let you cover all that up and locate your wheel well exactly where you want it.
post #89 of 1130 Old 09-23-2013, 09:36 AM Thread Starter
84jeepcj7rock
I am going to order some LJ blanks to save a little coin vs. CJ8
post #90 of 1130 Old 09-23-2013, 10:31 AM Thread Starter
84jeepcj7rock
Brown Santa came today. 17gal RCI fuel cell. Should fit nicely between the rear shock towers. That weight will help keep the rear tires planted w/o being too far back
